10-27-2021, 06:50 PM | #133 |
Rep 693
Can someone explain whether there are f30 years without flex discs? Looked under my 2016 with local
Mechanic and he says this model has no guibo. I honestly couldn't see it either. There was a rigid metal structure in its place.
Bimmercode best coding options (Basic and Advanced):
https://g20.bimmerpost.com/forums/sh...5#post29807925 |
10-27-2021, 07:02 PM | #134 |
Rep 1,521
Some guibos are metal with rubber inserts, however BMW discontinued using those and went back to all-rubber guibos. There will always be a guibo between the transmission output flange and the driveshaft, however the rear part of the D/S can be connected to the differential either with a guibo or insert nut depending on model.
10-27-2021, 07:26 PM | #135 | |
Rep 1,521
gnolivos319.00 |
10-27-2021, 07:45 PM | #136 | |
Rep 1,521
gnolivos319.00 |
10-27-2021, 10:22 PM | #137 | ||
Rep 1,833
10-28-2021, 07:29 AM | #139 | |
Rep 15,858
I'd be looking for something rotating at a constant rpm. (Possibly engine/ancillaries, or gearbox related). |
gnolivos319.00 |
10-28-2021, 07:34 AM | #140 | |
Rep 1,833
i still think this might be some sort of a resonating vibration, the low rpm vibration to me makes me think it's a harmonic vibration from exhaust or engine. possibly something is touching. but im not an expert
gnolivos319.00 |
10-28-2021, 07:37 AM | #141 |
Rep 15,858
10-28-2021, 08:56 AM | #142 | |
Rep 15,858
Look for the simple possibilities first. For example, does the engine move about more than expected, when out of gear and throttle blipped and revved through the critical rpm? Any odd vibrations in that scenario? |
gnolivos319.00 |
10-28-2021, 09:26 AM | #143 |
Rep 15,858
I see you have xDrive. I hope it isn't a transfer box issue developing. With inspections, has anyone suggested it could be?
10-28-2021, 10:02 AM | #144 |
Rep 1,833
I'm not sure if a transfer case would only cause a cabin vibration at a low rpm, i would expect there to be an audible noise as well. correct me if i'm wrong, but wouldnt it also be felt in steering wheel, not just the pedals and floor?
10-28-2021, 10:28 AM | #145 | |
Rep 15,858
More an "exploring the options" we have, when it is not the usual road speed type vibration. Doesn't seem to fit a normal fault finding path. Not in a BMW, but I've known transmission bearings cause a similar thing. So 'if' it is transfer box related, may not be the normal type of failure. Torque Convertors can do some odd things as well. But again, not showing the typical first indication of that is the issue either. An unusual one to try and identify, unless someone has come across this before. |
gnolivos319.00 |
10-30-2021, 02:54 PM | #146 |
Rep 5
I'm also seeing the same vibration. It becomes noticeable (i.e. passenger seat and phone mount start to shake) around 80mph under a heavy right foot and most often occurs in sport mode.
Initially put it down to a bad wheel alignment or uneven tyre pressures but the behaviour is not consistent and sometimes I can creep up to same speed or faster without noticing anything, especially in comfort mode. Booked into the local indie in a couple of weeks for an oil service and I've asked them to take a look at the transfer box and driveshafts to see if there's anything obvious. |
gnolivos319.00 |
11-15-2021, 05:14 PM | #147 |
Rep 9
Vibration - BMW F31 330d
Hi Everybody,
I join to your club, I have vibration too, with a special low noise, between 115 and 135 km/h ( 70 to 87,5 miles/h). I have tried three set of tyress and wheels, my differential replaced to a new one, but the vibration stayed with us. My mechanics say, my ZF8hp70 automaic transmission can cause these sympthons, but I have doubt. The vibration doesn't depend on he gears, I can feel and hear in tne 6th, 7th and 8th gear too, between 115 and 135 km/h speed. The driveshaft looks very good, the middle bearing is not loose, the front and rear guibo look good. I hear the voice stronger and I feel a small smooth vibration on the steering wheel, especially during acceleration and by riding upwards. Front of my driveshaf I have metal guibo, maybe it is too rigid or inflexible, a newer and full rubber maybe can eliminate the vibration? Best regards, Daniel |
11-17-2021, 09:29 AM | #148 | |
Rep 6
12-04-2021, 04:18 PM | #150 |
Rep 9
Maybe the solution?
Hi Everybody!
Maybe I found the answer, the solution against the vibration? At first I changed the differential to a newsy one, the newer differential had about 4.000s km. Nothing changed. I was first upset, but to know, that my differential is near to a new one, for only 350 Eur, it made me calmer. Today we have changed the driveshaft too, the older one (which was in my car, made in 2012 and has 250.000 km) looked nice, no symptons at the joint. Something changed, but not so much. (Ps: the new driveshaft made in 2018, took into a test car in 2019, but only for a few kilometres, so it is perfect). The guibo at the back is new, the front one is still the metal one, with small bushes, looked perfect, too. The bushes were hard fit to the metal guibo, they didn't moved and they didn't looked overused, so I let them in the guibo. And now the main point. After we took down the original driveshaft, (and before we took up the new driveshaft), we started the engine without driveshaft, I took the ZF Gearshift into "D" posiion, and I pushed the gas. After a time we felt a very small vibration for a short time (1 or 2 seconds), and my mechanic hold the automaic gearbox with his hands (from the inspection pit) and he felt the vibration too (when the Gearbox was in higher gear). We stopped the engine and my mechanic started to pull up and down very hard with his hands the outshaft of the Automatic Gearbox. It had a little play a slack in the direction up and down. So. My car produces the same sympthons with a new differential and driveshaft (but something changed, I dont hear the specioal annoying voice so hard, but it is in still present) and I feel vibration on the steering wheel from 120-140 km/hours) and we felt today under the repar time vibraition at the Zf8hp70, and a slack, a play at the outshaft, so I started to suspect to the ZF8hp70. Maybe an oil change for the gearbox, or a total restoration for the ZF 8hp70 (included the outshaft and the planetary gears) can solve the problem? We have a common parameter by our cars. All of us have a ZF8hp, as I know, but I dont know, do you have a slack or play by the outshaft of the ZF8hp70? Thanks, Daniel |
12-31-2021, 05:57 AM | #151 |
Rep 3
Just adding my car to the heap of vibrational frustration. 2014 F31 328d ZF8 130k km. Vibration and noise at ~ 120-130 kph Driving me nuts! Sure hope Daniel is onto something with his transmission theory. Seems we're all throwing parts and $ at a mystery.
01-01-2022, 04:08 PM | #152 |
Rep 9
Hello Oilburner,
since then I have changed my "guibo", you can find close to the ZF8hp, because the original one was a metal (Aluminium) guibo (with small rubber insets). I thought, the metal guibo can not absorb so much vibration, as the rubber one. After the replacement, I feel nothing changed, so unfortunately I have to hold my opinion, that the responsible part of the system is the ZF 8hp70 Transmission. It is interesting, because I feel the virbration on the steering wheel too, beside the annoying noise. (I have no x-drive). I started to wander to change the engine mounts, but my engine stays in its proper position in spite of hard acceleraion, and by cold start there is no sharp shocking, etc. I am not sure, that by the outshaft of the gearbox is it normal to be a little lash or play? If not, it can be stated with great certainty, that the bearing at the outshaft of the transmission, or the whole bearing of the transmissions shaft is the responsible. It is sad, because I thought one of the strongest part of the F31 is the 8hp70... And some interesting facts. I went to an ZF Service, the mechanic heard the problem and he said, "it is not the ZF Gearbox, it is the driveshaft. When a gearbox goes wrong, it has another sympthoms." I think in most cases it is right, but it is an unusual symphtom and problem... |
JBH661235.50 |
01-01-2022, 06:30 PM | #153 | |
Rep 1,521
JBH661235.50 |
