04-26-2021, 07:06 PM | #1 |
Rep 816
Drives: Bmw 335i f30 N55 ( sold)
SOS malfunction
Soooo I haven't had bluetooth/hands free/middle console USB for a while now.
I found a used combox on eBay and I was told it was plug and play. I installed it today and it was plug and play. My Bluetooth and everything works now.... but. Now I have a sos malfunction and if I call someone vis hands free I can hear them talking but they can't hear me. From one problem to the next. Anyone help
2012 bmw 335i sedan
VRSF catless DP VRSF 5? HD IC Stock intake(had open before and was sick of noise) BMS CP 550i 351m rims with 275/245 set up. No tune as of yet. |
04-29-2021, 12:57 PM | #2 |
Rep 816
Bump
2012 bmw 335i sedan
04-29-2021, 02:49 PM | #4 |
Rep 816
It did. Everything worked and then when it stopped bmw told me I needed a new combox so I bought a used one and everything works except I have the new issue. But I talk to a few coding guys and they said they may have to just go In the combox settings and code the feature to work as the other box might not have it. My voice command button and all that works
2012 bmw 335i sedan
04-30-2021, 11:29 AM | #5 |
Rep 688
Drives: 22 TR X3MC
You have to code the new com box
2022 X3M Comp
2013 335i xDrive (Sold) |
04-30-2021, 12:57 PM | #6 |
Rep 816
Yeah i have an appt In a few hours from a local shop that's going to try coding and see if it fixed the issue, stay tuned! Hopefully I fix it and can help someone else that has this as well!
2012 bmw 335i sedan
04-30-2021, 06:21 PM | #7 |
Rep 816
They couldn't figure it out so
I gotta take my car back sometime so they can have more time to mess with the coding, this is extremely frustrating
2012 bmw 335i sedan
05-02-2021, 07:50 AM | #8 |
Rep 48
The "SOS Malfunction" error can have many reasons. bad CAN connection.
Wrong/bad microphone wiring. Wrong/bad emergency speaker connection. Wrong/bad emergency antenna connection. If using ISTA shows the error. Calculate measurement plan. This should show an option to check your Combox and all connected modules. If your car came without and combox and you retrofitted one. You need to reroute the microphone wire from HU to COMBOX. Last edited by Tuerkay; 05-02-2021 at 08:02 AM.. |
05-02-2021, 02:41 PM | #9 | |
Rep 816
2012 bmw 335i sedan
05-02-2021, 03:19 PM | #10 |
Rep 48
Did your hands free mic work at some point with the new combox or did the SOS Error and non working Mic happen right after installing the new combox?
If the issues appeared right after installation, you can wait for a new appointment or you could check one thing yourself and maybe safe some money and time. Get Esys, connect to car, read coding of Combox_Media and Combox_eCall and check number of microphones. If the Mic worked with your old combox and stopped working with the new, mic settings could be coded differently in new combox. media -> 3000 General_Parameters -> USED_MICROPHONES ecall -> 3001 Telematics -> USED_MICROPHONES If you have two Microphones installed in car ceiling, both should be set to "Stereo". If there is only one, both should be set to "Mono". |
Tpriest7893212.00 |
05-03-2021, 01:19 PM | #11 | |
Rep 816
2012 bmw 335i sedan
