12-02-2020, 07:28 AM | #1 |
Rep 3,430
Bluetooth audio - quieter than other sources - why?
Maybe one of the more tech-minded amongst you can help explain something that has always bugged me... and that is why is it that audio over bluetooth is so much quieter than using other sources.?
I used to think this was an iDrive thing, but it is the same in most any car I have tried... I appreciate that bluetooth standards mean that there is a limit as to how much data can be transmitted, and this impacts if you are streaming hi-res, but this should not affect volume.. should it..? Thoughts..?
CAR HISTORY - Golf GTI 245 - F30 340i M Sport - F30 330d M Sport MPPK - F30 320d Sport - 997 Gen2 GT3 - 987 Cayman S - 986 Boxster S - Ibiza Cupra - Polo 16v - E30 M3 (Official GB import) - Integra 16v - Mk2 Polo S - Mk1 Golf C
12-02-2020, 07:36 AM | #2 |
Rep 6,940
Have you tried turning up the volume on your phone while it is playing via Bluetooth?
With a USB connection the volume is at a present level on mine and unaffected by the phone's volume buttons, but when playing via Bluetooth the phone's volume buttons do work. |
12-02-2020, 07:57 AM | #3 |
Rep 8,081
Yes the Bluetooth connection is like headphones / external speaker so the both the volume of the phone and the volume of the playback device have an effect.
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
12-02-2020, 08:01 AM | #4 |
Rep 2,068
Exactly this. Phone volume once paired & connected needs turning to maximum. Next time it connects, it will remember this setting. Software updates usually reset it, so you'll probably have to do it again in this case. Until the next time.
/// BM3 + M-Power ///
12-02-2020, 08:51 AM | #6 |
Rep 3,430
Sorry, I can't hear you, something made me deaf recently...
KRS_SN13433.00 |
12-02-2020, 08:54 AM | #7 | |
Rep 3,430
I was playing about with using CarPlay over bluetooth, as opposed to a USB connection... I shall try establishing the bluetooth connection again...
12-02-2020, 09:31 AM | #8 |
Rep 584
You shouldn't have any such issues using CarPlay because, if I remember correctly, it utilises both Bluetooth and WiFi so the volume on the head unit controls everything (waits expectingly for someone to point out where I've gone wrong......😳!)
12-02-2020, 11:05 AM | #9 | |
Rep 3,430
But, as far as I can see, CarPlay connects either over USB or Bluetooth... Not every car has a live wifi link... Edit - I am talking rubbish... I obviously did not try it with CarPlay as, as far as I can see, my VW does not support wireless CarPlay (bluetooth) so my problems are simply when using the bluetooth audio source... sorry for the confusion...
12-02-2020, 01:53 PM | #10 |
Rep 2,273
I think it's deliberate, because as you'll discover, when you crank up the volume on both phone and car it is SERIOUSLY loud. The bluetooth device defaults to a low volume in case your car (or whatever else it connects to) is already at max.
12-04-2020, 07:20 AM | #11 | ||
Rep 1,445
Anyway, to your point, if I get in the car and choose not to use CarPlay and connect my phone via Bluetooth I have the same issue as you...volume is determined as much by the head unit as the volume on the phone. Just treat bluetooth audio to the car in the same was as you would to a set of Bluetooth headphones.
Gone: G05 X5 40d M Sport, F15 X5 30d M Sport, F30 330d xDrive, F21 M135i, E87 123d
