08-01-2021, 09:56 AM | #15929 |
Rep 40,848
PM sent.
08-02-2021, 11:17 AM | #15930 |
Rep 8
hello shawn,
iam new here and trying to program my car after replaced BDC. the old BDC flooded. my car X1 F48 with ilevel factory F056 20-07-550 i using chinnese icom, itools radar and esys 3.27 and i have copy psdz data from authorized with i level F056 21-03-552. always get error VCM_Backup_Ethernet. TargetSelector: Project=F025_21_03_545_V_004_000_000, VehicleInfo=F025 connection via VIN vehicle specific parameter i choose series i step and i cant choose istep (shipm) dan istep (target) in KIS/SVT target sorry for my english and i cant descript it well. i think you can help me to solve it. |
08-02-2021, 11:27 AM | #15931 | |
Rep 40,848
08-03-2021, 09:24 AM | #15932 |
Rep 8
shawnsheridan10457.50 |
08-03-2021, 10:02 AM | #15933 |
Rep 40,848
Your Receive PM function is disabled. PM me when working.
08-03-2021, 11:26 PM | #15934 |
Rep 379
Hello Guys,
Any help would be much appreciated. My car is a 2016 328i with stock grey brembo four piston at front and normal single piston break at the rear. Installed M Performance brakes today and coded DSC by adding SPBR but the brakes still feel too spongy. Its taking more than 50% of the pedal travel to stop the car and feels worst than my stock. Also it feels like all four brake calipers are holding up the wheel even after I let go of the brake pedal. Couple of observation ... 1. After I have added SPBR, under aftermarket retrofit I see SPBR_19_ZOLL_SPORTBRAKE instead of 18 2. Under DSC module FDL is there only for front and set to initwerte 0 and rear is not present. Any help please. Thanks.
Click appreciate if this post has helped you
Retrofits: NBT evo ID6, 6wb cluster, heated steering wheel, HUD, Kafas2 with LDW, SLI, HBA, FCW and pedestrian warning, LCW, Surround View, Parking Assist and ACC with Stop |
08-06-2021, 02:17 PM | #15935 |
Rep 193
It's been a while since I've done any coding but the last I looked into it (back in 2019 I believe) I thought e-sys was no longer working/the guy shut it down. Is it back? What am I missing
08-06-2021, 02:20 PM | #15936 |
Rep 40,848
Coding is alive and well. PM sent.
08-08-2021, 11:56 AM | #15937 |
Rep 521
I think I need the latest files - I was trying to use my old copy of e-sys, launcher, and psdzdata, and it just kept prompting me to create a token every time I tried to launch using launcher.
08-08-2021, 12:12 PM | #15938 |
Rep 40,848
PM sent.
Araemo190.50 |
08-12-2021, 10:52 AM | #15941 |
Rep 40,848
PM sent.
08-18-2021, 09:54 AM | #15943 |
Rep 40,848
And you entered the .est PIN and it does not take, it keeps popping up?
08-18-2021, 11:38 AM | #15945 |
Rep 40,848
You must do exactly as follows:
1) Install ESysLauncherPROSetup_2.8.2_Build_162b.msi 2) Copy the attached "BFU_XODE.EST" to C:\EC-Apps\ESG\E-Sys 3) Run Launcher PRO from Desktop Icon 4) Hit "+" to Add E-Sys location to Launcher PRO 5) Hit "OK" to accept E-Sys in Default Location 6) Hit the "..." and set EST Path to: C:\EC-Apps\ESG\E-Sys\BFU_XODE.EST 7) Enter PIN: 12345678 8) Select the Hammer / Wrench Icon and Activation Code Window Appear 9) Enter Activation Code: B1G_F*CK_Y0U_paulX_**************_dconer_ebayselle rs.-Your_lack_of_decency_creativity_and_imagination_is _reprehensible.-Your$greed$even_more_repugnant_and_despicable 10) Select "Activate Now" 11) Select "Launch Now" to use E-Sys Launcher to launch E-Sys.
08-19-2021, 07:30 PM | #15948 |
Rep 40,848
All that is needed there is:
