BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Expensive Paperweight (my tcb retrofit)
European Auto Source (EAS)
      01-08-2019, 08:37 AM   #1
midnightf30
midnightf30's Avatar
Drives: 2014 F30 328i BASE
2014 BMW 328i  [0.00]
So I retrofitted a TCB from a car with the options that I wanted and that went all well and dandy (pita) but I finished doing the combox to tcb repin, as well as running the wires to the front back of headunit and connecting the TCB via kcan2 POST emulator so there would NOT be a vin mismatch between NBT and TCB, anyway coded what was needed and went on my merry way to go ahead and give everything a start. Now I don't know if i did something wrong or if I just have the most impeccable timing to do this retrofit when servers are down but does anyone know or can anyway chime on if connected drive is down for them too or if they have done this retrofit. Happy days to everyone
      01-08-2019, 12:56 PM   #2
Crazy_1201
Drives: E90 320d
You should get a set of FSC codes for the NBT to match the TCB VIN, erase the NBT FSC codes, code the NBT to the TCB VIN and import the new FSC codes.
Basically NBT Vin and FSC need to match TCB
      01-08-2019, 01:16 PM   #3
midnightf30
Hey thanks so even though the TCB is recognizing the vin from the DONOR vin as the same as the original NBT it belonged to, is that not enough? That was the whole reason why I ran two extra wires from the TCB directly to the emulator. Just as extra precaution I didn't even plug in the TCB till I was able to code the NBT with the TCB donor vin options and donor vin itself. Also the original donor vin the NBT used match the option codes from factory of the new donor vin I used to match the TCB.
      01-08-2019, 02:50 PM   #4
Crazy_1201
Drives: E90 320d
As far as I am aware TCB vin cannot be reprogrammed. And you also need FSC to match. So basically read TCB vin inject it into NBT. Get a FSC repair kit for vin of TCB inject that into NBT.
Youd then need an NBT emulator between car and NBT.
FSC codes are vin specific
      01-08-2019, 03:12 PM   #5
midnightf30
You'd then need an NBT emulator between car and NBT.
No it cannot be reprogrammed but yes I did cafd injection with donor vin prior to putting the car back together so it had already been done and yes it is connected via kcan2 between emulator and nbt already, I don't know where to find a fsc repair kit though is it done through esys or ista?
      01-08-2019, 03:24 PM   #6
Crazy_1201
Drives: E90 320d
Fsc can be done through esys. Its basically activation codes for certain bmw features.
Where to obtain them from? Best to ask Shawnsheridan on this forum
      01-08-2019, 03:30 PM   #7
Crazy_1201
Drives: E90 320d
https://f30.bimmerpost.com/forums/sh...d.php?t=838915
This thread explains a bit more regarding fsc codes
      01-08-2019, 04:30 PM   #8
midnightf30
Fsc can be done through esys. It's basically activation codes for certain bmw features.
Alright I will give shawn a ask but apart from that, is this the reason that the head unit is saying maintenance is being done on bmws website after doing the cellular data and sim connection, I'm able to actually log into bmw online in my car from connecteddrive and I actually added it to mybmw account but I just can't add it to connecteddrive app because the car doesn't receive the message with the pin.
Is a FSC repair kit really needed at this stage I was hoping to be able add my car to connected drive at least before I go paying big bucks because I don't want to pay only for the FSCs not to be the actually cause of this current issue.
shawnsheridan
Edit: these are things I exactly did
-removed old combox
-repinned 26 pin combox connector
And ran 5 wires from the connector to the quadlock behind NBT
-spliced kcan H and kcan L in between the emulator and the NBT and ran green usb fakra
-added donor options to vo and vo coded NBT with new donor vin from TCB
-connected TCB
-TCB recognizes by esys
-NBT recognizes and changes connected drive menu
-NBT responds to hitting BMW ONLINE by bringing up "transferring cellular sim network something something something (lol)"
-after a little bit of waiting it says "MAINTENANCE, website is going under maintenance" and it's been like that for the week
      01-08-2019, 06:19 PM   #9
Crazy_1201
Drives: E90 320d
Fair play. Best to wait for Shawn to get back to you.
Also does your navigation still work?
Was your car originally specced with NBT and connecteddrive?
      01-08-2019, 06:21 PM   #10
midnightf30
Yep I appreciate the help though
      01-08-2019, 08:25 PM   #11
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
shawnsheridan
-removed old combox
-connected TCB
I have never retrofitted any Telematics Unit, so I am not a good one to ask.
That said, for retrofitted TCB to work, besides correct hardware / wiring:
1) Leave Donor VIN in TCB
2) Change the VIN of the NBT to match the Donor TCB VIN and load FSC's for VIN of TCB/NBT (Donor ATM VIN)
3) Use an emulator that allows VIN of car to be different than VIN of TCB/NBT.
TCB of course needs active Subscriptions for desired services as well (RTTI, etc.).
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
      01-08-2019, 10:45 PM   #12
midnightf30
shawnsheridan
-removed old combox
-connected TCB
Hey thanks anyway (wanted to say it personally because before I started posting reading your stuff helped me in other things I worked at coding wise up to now but anyway, I did one and two and three but how do you load the FSC's from the donor onto the nbt? And yea i will once I know it's working I know for sure the subscription is done BUT the TCB donor originally had everything I wanted so hopefully gonna get it to work, just gotta figure out if bmw actually is under maintenance or something on my end isn't right because I can login to bmw online from I drive and my time even updated from the TCB, but it's just trying to access store and bmw online show maintenance and I believe this is why the pin isn't being received by my car from the connected app under messages.
      01-09-2019, 08:44 AM   #13
shawnsheridan
...I did one and two and three but how do you load the FSC's from the donor onto the nbt?
You need the original FSC Code Set, and then all FSC Codes must be imported / Activated in Head Unit using E-Sys. PM sent.
      01-11-2019, 12:29 AM   #14
midnightf30
Didn't want to open a new thread if I didn't have to but any insight on why this is happening:
The vin on literal idrive it is blank but when hooking to esys and checking fsc and and tool32 it already reports the vin I wanted it to have stored already but why isn't it showing on head-unit itself?
      01-11-2019, 12:44 PM   #15
Jhnblckwood
Drives: F30 2014 320i xdrive
Did u ever try selecting update bmw assist?
      01-11-2019, 01:02 PM   #16
midnightf30
Yea I tried doing that still nothing lol I tried looking through tool32 for like a "write vin" job but couldn't find one.
      01-11-2019, 01:26 PM   #17
Jhnblckwood
And u matched up the number in the vin folder to the hex values and it is the donor vin u wanted? Maybe tcb n nbt need to b on same istep andr istep updated?? Idk
      01-11-2019, 02:55 PM   #18
midnightf30
For which one nbt or tcb, the tcb has the correct one in that vin folder but I can't find anything related to vin via esys whether I use "vin" or "vehicle identification number" or the German translation. I virginized the NBT and I imported FSC which went great even reads the vin through check fsc as donor. But I don't know if there's a process for the vin that I'be got to do. Maybe shawnsheridan has some insight, helped me initially with the virginization.
