BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > DIY Complete Guide to full LED bulb swap for the F30s with halogen headlights
      12-04-2018, 06:35 PM   #111
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
I didn't have any problems fitting the drivers in the housings, but with the lows I cut the top off the housings to get access, my post explains it.
      12-06-2018, 03:05 PM   #112
Hammer Werke
Drives: '15 328d Touring
I tried coding it another time. I switched some items back to normal, coded it, and then coded it back to LED etc. Knock on wood but I haven't noticed it flickering again.
I'll be keeping my eye on the market as new bulbs come and go monthly. I want some fanless legit Lumileds. We'll see.
      12-30-2018, 12:15 PM   #113
Hammer Werke
Question about the front signal light bulb change. I changed my bulbs to the orange Osram Leds and they look great but now I get a lighting malfunction error when I start up.
Which bimmercode things do I change?
Sidemarkers? Indicator?
Little confused on this. I think I changed both to LED (checks off) but maybe one of them is causing the error for me....Thanks for the help.
      12-30-2018, 04:13 PM   #114
crimson_king
Drives: 2014 328i F30 Manual Trans
Ok, go back and code sidemarkers back to how they were and only change the front indicators as these should be for the signal lights
      12-30-2018, 05:10 PM   #115
Billfitz
Billfitz's Avatar
I can only say what I changed using E-Sys:
Code front turn signals for LED-Bulb replacing halogen bulbs:
FEM 3061FRA_V_L_KALTUEBERWACHUNG set to: nicht_aktiv
3061FRA_V_L_WARMUEBERWACHUNG set to: nicht_aktiv
3061FRA_V_L_IS_LED set to: aktiv
3061FRA_V_R_KALTUEBERWACHUNG set to: nicht_aktiv
3061FRA_V_R_WARMUEBERWACHUNG set to: nicht_aktiv
3061FRA_V_R_IS_LED set to: aktiv
      12-31-2018, 04:30 AM   #116
crimson_king
Here you go
      01-03-2019, 09:50 PM   #117
PKR
Drives: 2014 F31
Is there another 6000k (not 6500) alternative to the RoadSun H7 that was originally posted?
      01-03-2019, 10:00 PM   #118
crimson_king
There is, but recently I have been getting the headlight malfunction error so I am thinking of going fanless. Maybe trying the beamtech ones since they are fanless and pretty cheap:
https://rover.ebay.com/rover/0/0/0?m...2F132735805038
      01-05-2019, 02:33 AM   #119
JonF3015
Drives: 2015 F30 328i
Amazing job on this. Has anyone used DEPO ANGEL EYES HALO RINGS PROJECTOR HEADLIGHTS doing this swap? I'm thinking about doing all this here real soon.
Jon
      01-05-2019, 10:09 AM   #120
Billfitz
Billfitz's Avatar
I can't see the fan causing an error. I can see the fan failing, causing the bulb to burn out. That, and the potential for fan noise, is why I didn't use fan cooled bulbs. I did get an error message a few weeks ago, but it cleared immediately and hasn't come back again. I haven't bothered to use my OBD diagnostic to see which bulb caused the message. I'll do that when I do my spring upkeep and detailing chores.
      01-05-2019, 03:41 PM   #121
crimson_king
Interesting, I was getting the error like every five mins while driving with the headlights on so I went back to halogen low best only for now
      01-05-2019, 04:25 PM   #122
Billfitz
Billfitz's Avatar
I got a generic 'lighting malfunction' message on my iDrive screen, saying to check out the lighting system, not a specific bulb. It was at night and my headlights were operating normally. I acknowledged the message by pressing the controller, it went away and it hasn't come back on since then.
      01-05-2019, 04:30 PM   #123
crimson_king
Hmm that's exactly the same message I was getting, but it was happening very frequently when the headlights were on and my headlights would flash when the message popped up so I just decided to go back to halogens for now
      01-05-2019, 05:22 PM   #124
Billfitz
Billfitz's Avatar
I just checked my lights and one of the front turn signals is out. Odd that the warning only flashed the one time. Whatever is with your lights I can't say. Do you have drive ballasts? Mine do, and they never threw a warning even before I coded out the warm and cold checks.
      01-05-2019, 06:05 PM   #125
crimson_king
What exactly are the drive ballasts?
      01-05-2019, 10:10 PM   #126
Billfitz
Billfitz's Avatar
If you have to ask I guess you don't have them. Have a look at this link to the bulbs I used:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
      01-10-2019, 12:10 PM   #127
PKR
Drives: 2014 F31
Confused
I'm confused Billfitz ... abit earlier you wrote that you don't use fan cooled bulbs ... but the ones you point to are fan cooled.
      01-10-2019, 02:17 PM   #128
Billfitz
Billfitz's Avatar
Those are not fan cooled, heat sinks only.
      01-10-2019, 02:34 PM   #129
PKR
Drives: 2014 F31
OK, got it. Thanks
... and the drive ballasts are included .... or ?
      01-10-2019, 02:45 PM   #130
Billfitz
Billfitz's Avatar
They are on the linked bulbs. Look at the pictures of what's included.
Scrolling down the page I see the description mentions a fan, but there is none.
      01-11-2019, 01:24 PM   #131
testcodes
Drives: BMW 328i
I replaced mine a while back using the beamtech ones:
https://www.ebay.com/itm/2xH11-H7-H1...72.m2749.l2649
my cutoff is horrible though, kinda looks like the one from @hakisalapaki
https://f30.bimmerpost.com/forums/sh...1&postcount=54
mine's a bit worse, the left side is aimed way lower than the right so the cutoff is also uneven. the left is already adjusted to the highest it would go, while the right still has space to move up/down
I'm going to try to see if I can fix this this weekend. Any tips on what I should do? I guess some ideas:
1. I've read the headlights will not adjust up/down if its too far left/right. I'll try adjusting left/right first then adjust up/down
2. Does the way the bulb sits in the housing affect how high it aims? I noticed the bulb on my left is mounted like a millimeter or two higher than the right (comparing against the cutoff metal thingy)
3. Hopefully I wouldn't have to, but I guess I can try switching left and right bulbs
4. Finally last resort would be to buy a new pair of bulbs
      01-11-2019, 01:49 PM   #132
Billfitz
Billfitz's Avatar
It does. The H7 mounting clips are very flimsy, as the halogen bulbs weigh practically nothing. The LEDs are heavy, due to the heatsinks. I used high temp RTV to firmly secure the LEDs. With the low beams that made it necessary to cut access to reach the mounts, as noted in my LED thread.
