BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Rear view and top view at the same time?
      04-16-2020, 03:17 PM   #1
psyki
E36fiend
Drives: 2014 435i xDrive
2014 435i xDrive  [0.00]
2014 X5  [0.00]
Was watching a video demonstrating the Cross Traffic Assistant in a car that has NBT EVO (ID6) and the screen showed the rear view and top view at the same time. Is this possible in our cars??
      04-17-2020, 10:36 PM   #2
MFNATIK
Blocked from G80/G82 for having an opinion
MFNATIK's Avatar
Drives: Trek Domane
This is the most ideal view. Wonder if this is a hardware feature?
      04-17-2020, 11:22 PM   #3
psyki
E36fiend
2014 X5  [0.00]
I believe the vehicles that have this feature have ICAM(2) for cameras and also BDC so I'm not sure it can be retrofit. Then again guys have put these systems into the E90 platform so anything is possible.
      04-17-2020, 11:37 PM   #4
MFNATIK
MFNATIK's Avatar
Drives: Trek Domane
Must be bc I haven't seen any of the coding guys offer this as a software switch the can flip
      04-18-2020, 12:13 AM   #5
IK6SPEED
Drives: BMW M3 / AH3
Yep, if they have been put in an E90, than it certainly could be retrofitted in a F3x.
If it is iDrive 7.0, then I doubt at this time it could be retrofitted into either.
      04-18-2020, 01:07 AM   #6
psyki
E36fiend
2014 X5  [0.00]
The video I saw was clearly id6, plus in the NBT Evo coding there are entries where you can select which video hardware is installed, our cars have TRSVC whereas the G20 has ICAM. But since newer cars use BDC for many of the functions that FEM controls in our cars (among others) I don't know how much you'd need to retrofit just to get a new module to work.
      04-18-2020, 01:19 AM   #7
IK6SPEED
Link to E90 install?
      04-20-2020, 05:56 PM   #8
psyki
E36fiend
2014 X5  [0.00]
I went back and found the thread but looking at it again I believe it is ICAM from an F15, not the G series ICAM2 that I suspect supports the dual top-view and rear view. Furthermore, the poster seems to be unable to actually code it due to it requiring a BDC module which our cars don't have, at least not without a substantial amount of extra work to bench code it.
https://www.e90post.com/forums/showp...&postcount=192
IK6SPEED4488.00
