05-19-2021, 11:19 PM | #1 |
Rep 39
AA Catted DP CEL?
Ran the AA Catted DP for about 5 months now, ~3.5k miles. Car got a CEL today and got code 180001 "Catalytic Converter: Efficiency below limit value"
Anyone else getting CEL with this DP? My car is not/never was tuned! Today's the first day it got pretty hot here in NYC since i've added the DP- not sure if heat has anything to do with it? Any help would be appreciated |
05-19-2021, 11:44 PM | #2 |
Rep 1,452
Clear it, see if it comes back. Contact AA if it does.
2022 CT4-V Blackwing 6-speed
05-20-2021, 09:02 AM | #3 |
Rep 190,687
+1
They'll take care of it if the cat failed. I know they updated their cats no too long to a newer version
kianf2264.00 |
05-20-2021, 09:51 AM | #4 |
Rep 39
05-20-2021, 10:16 AM | #5 |
Rep 111
Bimmerlink did not work for me either. I used a $10 app called ODB Fusion. It works but it resets your adaptations.
Rogue SSK, AWE Exhaust
05-20-2021, 01:30 PM | #6 | |
Rep 942
I've got one of these too so im curious what happens. |
05-20-2021, 04:11 PM | #7 |
Rep 4,876
I cannot comment if AA units will give the CEL, but many high flow cat units do. And yes, it seems higher temps do cause the CEL to trigger (hotter exhaust temps probably?)
You might need to get one of those right-angle O2 offset adapters off Amazon for the lower O2 sensor to get it out of the stream. |
05-20-2021, 09:08 PM | #8 | |
Rep 25
05-20-2021, 09:53 PM | #9 | |
Rep 39
91 degrees on Sunday so lets see what happens, i'll report back |
Wires1645.50 |
05-20-2021, 09:54 PM | #10 |
Rep 463
Yes, primary O2 sensor calibrates the secondary O2 sensor. Will it work to eliminate CEL possibly? Will it ruin calibration yes.... enough to harm engine? Not sure but probably not worth it. For anyone else thats about to challenge me on this LOL, watch youtube videos that explain how BMW uses a wideband O2 on these cars.
05-20-2021, 10:22 PM | #11 | |
Rep 25
drivef30111.00 |
05-21-2021, 03:24 PM | #14 |
Rep 4,876
05-21-2021, 03:31 PM | #15 | |
Rep 4,876
If the emission system is doing it's job correctly the cats have burnt off any fuel so the secondary O2 shouldn't see any residual. The offset adapter just takes the tip of the O2 sensor out of the flow. It's still seeing the same exhaust though. |
05-23-2021, 12:05 AM | #16 | |
Rep 39
05-23-2021, 02:37 AM | #17 | |
Rep 463
All I said was the secondary calibrates the primary o2. For example, just because the car will run without the MAF plugged in doesn't mean the car will suffer in someway... The MAF calibrates other aspects of the. Similarly, the secondary O2 calibrates the primary for the reasons mentioned in the video. As I also said in my other comment, its probably not going to ruin the engine but might affect some aspects of the car. Ill give you another whiff of the pie, without giving you the whole pie... since you dont like watching videos."using a Bosch algorithm which takes the post cat sensor information to compensate for aging on the primary 02 sensors" and "The post-cat sensors are used to calibrate a 1.0 lambda for the widebands. The narrow bands are extremely accurate around stoich (1.0 lambda)." you can find the threads I found this at and read more into why a spacer isnt the best idea. Hopefully you can find these threads and the thousands others and "enlighten those people" on how this DOCUMENTED fact is null and void; and that your testing + experience of others, is the only thing people should follow as engineers are overpaid for the technology they put into cars. Last edited by drivef30; 05-23-2021 at 02:45 AM.. |
05-23-2021, 09:37 AM | #18 | |
Rep 4,876
Again, if that video WAS ACCURATE then NOBODY could run their car catless. It would lean out the car and it just wouldn't run, and it would be tossing a ton of codes around invalid fuel trim values. But heh, believe what you want! |
BMWILUVU809.00 |
05-23-2021, 10:06 AM | #19 | |
Rep 39
How do you like the AA downpipe on the untuned car? Most people run downpipes with a stage 1 tune, so I'm curious what gains you've noticed? |
05-23-2021, 06:44 PM | #20 | |
Rep 39
Tbh, I haven't noticed much performance wise, but the car is much louder than before. Just riding out my factory warranty before I tune stage 2. I just couldn't resist buying the AA DP, intake and chargepipe from xph during their black friday sale. |
05-24-2021, 11:08 AM | #21 | |
Rep 39
05-24-2021, 11:29 AM | #22 | |
Rep 1,597
Wires1645.50 |
