06-29-2021, 12:39 PM | #15886 |
Rep 40,769
PM sent.
07-02-2021, 12:47 AM | #15887 |
Rep 216
Hey Shawn -
New to coding on F-series. Did a ton of coding back on my E90. Would you be able to provide the links for an F36? Thanks! |
07-02-2021, 03:13 PM | #15888 |
Rep 40,769
PM sent.
riso198835.50 |
07-03-2021, 08:15 PM | #15889 |
Rep 52
I'm stuck. Having a problem with esys (3.27), am unable to activate FA. Psdz error. The car is a 2018 F32, tried using both available F020 target selectors. No problem connecting or reading SVT. Just can't activate FA. Any ideas?
07-04-2021, 08:51 AM | #15890 |
Rep 40,769
Error is from FP Generation not Activation, and it clearly shows why. It shows you have 3 Option Codes in FA that are not valid for your vehicle Type Code with a 0717 Build Date.
07-04-2021, 11:08 AM | #15891 |
Rep 52
Thanks for the response. I don't know how this could happen? The car is stock/ I haven't changed anything yet. How should I proceed?
07-04-2021, 11:38 AM | #15892 |
Rep 40,769
Why are you generating FP? You should be able to activate FA and use it. Make sure you run with Admin rights, and use default memory setting on E-Sys Launcher.
07-04-2021, 11:52 AM | #15893 | |
Rep 52
I don't understand why there are option code and build date conflicts when the car was configured this way from the factory? Do I need to modify the FA by deleting those 3 SALAPA elements? |
07-04-2021, 11:57 AM | #15894 | |
Rep 40,769
07-04-2021, 02:27 PM | #15895 | |
Rep 52
Looking at the attached image I'm guessing someone has flashed the car recently (I just bought the car a month ago)... The psdz data I have is older than the cars. Can you please send me a link to newer psdz data if you have it? Thanks |
07-04-2021, 02:29 PM | #15896 | |
Rep 40,769
mikewhiskey28.50 |
07-05-2021, 12:14 PM | #15899 |
Rep 40,769
PM sent.
07-05-2021, 02:16 PM | #15900 |
Car Hypochondriac
335
Rep 901
I thought I fixed this before, but I have a new laptop, and can't edit my FA.
I'm using the free 2.8.2 launcher pro, esys 3.27.1, psdz from 2018 on windows 10. I get the following when I try to activate or calculate FA: Code:
21-07-05 14:52:47,522 [WARN] [] com.bmw.psdz.api.impl.bf.LogicBF: ERROR: an exception occured in an API method: generateFP(FA pFA) [Thread-24] java.lang.Error: unidentified exception at com.tokenmaster.PSdZAPI.GetCache(Native Method) at com.tokenmaster.ESysLauncher.a(Unknown Source) at com.tokenmaster.ESysLauncher.ProcessFaFp(Unknown Source) at com.bmw.psdz.api.data.fa2fp.FA2FP.parseXML(Unknown Source) at com.bmw.psdz.logic.facade.LogicImpl.generateFP(LogicImpl.java:541) at com.bmw.psdz.facade.LogicBF.generateFP_aroundBody20(LogicBF.java:111) at com.bmw.psdz.facade.LogicBF.generateFP_aroundBody21$advice(LogicBF.java:55) at com.bmw.psdz.facade.LogicBF.generateFP(LogicBF.java:1) at com.bmw.esys.domain.psdz.Psdz.generateFP(Psdz.java:647) at com.bmw.esys.domain.fa.FpLogic.generateFp(FpLogic.java:84) at com.bmw.esys.gui.fa.FpController.generateFp(FpController.java:114) at com.bmw.esys.gui.fa.FpController.execute(FpController.java:146) at com.bmw.esys.gui.AbstractController$ExtensionSupport.executeExtensions(AbstractController.java:117) at com.bmw.esys.gui.AbstractController$ExtensionSupport.executeExtensions(AbstractController.java:98) at com.bmw.esys.gui.AbstractController.executeExtensions(AbstractController.java:201) at com.bmw.esys.gui.fa.FalController.activateFa(FalController.java:144) at com.bmw.esys.gui.fa.FalView$ActivateFaAction.doActionPerformed(FalView.java:111) at com.bmw.esys.gui.AbstractView$AbstractGuiProgressAction$1.init(AbstractView.java:425) at com.bmw.esys.gui.component.DialogProgress$2.construct(DialogProgress.java:152) at com.bmw.esys.gui.component.SwingWorker$2.run(SwingWorker.java:145) at java.lang.Thread.run(Thread.java:744) Does this indicate my psdz is too new?
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327 |
07-05-2021, 02:35 PM | #15901 | |
Rep 40,769
Eschmacher334.50 |
07-05-2021, 02:47 PM | #15902 |
Car Hypochondriac
335
Rep 901
I can't believe that worked, what a silly fix. Thanks Shawn.
07-05-2021, 02:48 PM | #15903 |
Rep 40,769
07-15-2021, 06:03 AM | #15906 | |
Rep 40,769
