09-17-2019, 03:45 PM | #1 |
Rep 29
Undo-ed Adaptive headlight DIY and now getting an error.
Hi,
I just undo-ed the Adaptive light DIY and went back to original halogen light. I'm sure I correctly undo all the cabling (headlight connectors and the fem body). The halogen lighting does work fine: DRL, low & high beam, parking lamps, fog lights are all functioning okay. For the coding 1. I removed 522 and 524. Briefly, I deleted 522, 524 from the FA's SALAPA and hit 'Apply changes' then wrote FA & FP from the VCM Master tab. 2. I did VO code FEM_BODY. Right click the FEM_BODY and select code. 3. I checked the CAFD under the FEM_BODY so all the Adaptive related setting are set to 'disable' 4. Just to be sure I FDL_Code the CAFD. My problem is I'm getting an error on my dash saying "Adaptive headlight malfunction." Please help. How do I get rid of this error? Last edited by thornfrog; 09-17-2019 at 05:55 PM.. |
09-17-2019, 05:43 PM | #3 |
Rep 29
09-17-2019, 06:16 PM | #4 |
Car Hypochondriac
335
Rep 901
So you checked all of these?
LWR_AHL_TYP = auto./dyn. LWR+AHL = 03 C_FLC_ENA = F030disable (LWR, Leveling sensor) C_AFS_ENA = F030enable (Light Distribution) C_BLC_ENA = F030enable (AHL) C_CLC_ENA = F030enable (Cornering light) These are the values I found for the xenon retrofit. I'm not sure what the original values are. |
09-17-2019, 06:26 PM | #5 | |
Rep 29
Original values are LWR_AHL_TYP = ohne. LWR+AHL = 00 C_FLC_ENA = F030disable (LWR, Leveling sensor) C_AFS_ENA = F030disable (Light Distribution) C_BLC_ENA = F030disable (AHL) C_CLC_ENA = F030disable (Cornering light) |
09-17-2019, 11:27 PM | #6 |
Rep 10,473
Take it to Dealer and have them update to the newest iStep. Should do this every year or two anyway.
This will reset all your coding mistakes and set it up properly with all the factory options - including the factory halogens. |
09-18-2019, 03:58 PM | #8 |
Rep 263
I had the same issue when I went back from retrofitted AHL xenon to normal xenon lights. I was checking everything several times, but always had the malfunction as you have mentioned. Finally simply disconnecting and reconnecting the battery solved the problem.
I took until late night and I had to return my company car the next morning to the dealer |
03-31-2023, 01:34 PM | #9 | |
Rep 5
will these codings work if I want to disable my retrofitted adaptive xenon? Tired of looking at the error every time I want a ride |
03-31-2023, 02:33 PM | #10 |
Rep 2,047
Better to use esys to remove 524 from FA and vo code FEM
Eschmacher334.50 |
