11-09-2020, 04:18 PM | #1 |
Rep 255
Low oil warning after 1000 miles?
So last couple months I've been facing this problem where I've been driving and received a low oil warning "minimum oil level, top off 1 quart". Both times have been after around few weeks to a month after the last oil change which is usually around 1000 miles.
From doing my research seems like it could be valve cover/valve cover gasket? But there are no signs of oil leak anywhere and just got a new oil change (drain/refill) today at the shop which they said my valve cover looked perfect with no leaks. They said I was missing 1.5 quarts since the last oil change with them though which was about 3 weeks. Where could the oil be going? Everything is running fine and after running/installing the upgraded turbo I haven't had this issue with oil for the last 10k till recently. I have been noticing smoke occasionally Coming from exhaust tips for a minute or so once I power it off but smells like gasoline mainly, not coolant.! Is there anybody else with this issue especially running upgraded turbo? |
11-09-2020, 04:44 PM | #2 |
Rep 1,239
Could it be blow by? Extra boost from a bigger turbo and the standard breather set up cant cope? Not really heard of it being an issue on the b58's tho
11-09-2020, 04:49 PM | #3 |
Rep 255
That's what I was thinking too but I've been running relatively low boost/power compared to others with upgraded turbo and this wasn't an issue with the upgraded turbo before.. Plus 1.5 quarts in a few weeks seems crazy for turbo blowby..
11-09-2020, 05:00 PM | #4 | |
Rep 1,239
Have you wipped of the pipe going into the throttle body? Check for oil there? Same if you have a bore scope pop it down and look at the compressor housing for oil. what sorta miles were covered in that few weeks? |
11-09-2020, 05:18 PM | #5 | ||
Rep 255
About 1000 miles I'd say since last oil change before low oil warning came on. |
11-09-2020, 05:22 PM | #6 | |
Rep 1,454
2022 CT4-V Blackwing 6-speed
11-09-2020, 06:06 PM | #7 | |
Rep 40
Your new turbo could be eating the oil. |
11-09-2020, 06:19 PM | #8 | |
Rep 1,239
01-17-2021, 01:27 AM | #9 |
Rep 255
Update: Used liqui moly 5W-40 and the problem went away but a month and a half later what do you know, minimum oil warning light again after 2k miles.
Clearly the 5W-40 lasted longer than the 0w-20 by far but the oil is still disappearing somewhere. I'll be running a compression test and leak down test if needed and checking the intake for oil when I can but does anyone have any other insight? Not sure if my inconsistent weird ticking along with one or two pops from the engine bay one day (never did that sound again) has anything to do with this. |
kianf2264.00 |
01-18-2021, 04:04 PM | #11 | |
Rep 467
No smoke while idling correct? PCV issue? PS What tuning platform and how many miles on the Pure 800? How many lbs of boost, if you don't mind me asking. |
01-18-2021, 04:29 PM | #12 |
Rep 749
Drives: F31 320d xDrive M Sport
Do you get the warning a few weeks after you top it up as well? Or only a few weeks after you get it back from the oil change?
If the first, clearly leaking from somewhere. If the latter, then maybe they're just not filling it up with the correct amount or to the correct level. Or filling it to the level on the dipstick, but not topping it up after the engine is run and the oil settles again.
01-18-2021, 05:30 PM | #14 | ||
Rep 255
Car actually smokes a lot when driving these days, I contributed that to the cold weather though and being catless? I just tried leaving it in idle for 10+ minutes and it was smoking white smoke a bit near the end but the smell is not oil smell just smells sweet and like raw fuel. I'm running Jordan tuned and hitting around 21 PSI on average peak WOT, wasn't able to push it anymore with the 92 octane here hindering me sadly. I'll be happy if it's a PCV issue or a valve cover gasket compared to something more serious lol. Not looking like I'm getting much symptoms of either above issues tho as car is running pretty solid. |
01-18-2021, 05:37 PM | #15 | |
Rep 255
01-29-2021, 03:06 PM | #16 |
Rep 255
So i took my car to the shop and they did some testing on the PCV and turns out my PCV is perfectly fine. Next step will be compression testing when i replace my spark plugs since they are somewhat due for change anyways.
03-17-2022, 08:47 PM | #18 |
Rep 180
Do you have a oil catch can?
AFE Filter | BMS Intake Pipe
CTS DP | CTS CP | CTS Heat Exchanger PTP Turbo Blanket | AEM WMI Kit | Custom Exhaust PJ ACN91 + Meth tune| XHP Stage 3 |
03-18-2022, 03:07 AM | #20 |
Rep 255
Turned out my engine had failing piston ringlands which was leaking the oil. Eventually got a compression test which found cylinder 3 was 16-20 psi lower than the rest. Ended up getting a new engine from Germany and couldn't be happier with how it performs.
I'd highly recommend getting a compression test if you have any doubts for peace of mind. |
B58557.50 |
03-18-2022, 08:22 PM | #21 | |
Rep 180
03-23-2022, 05:29 PM | #22 | ||
Rep 255
