12-22-2016, 10:17 PM | #1 |
Rep 15
OEM Roof Bars Whistle
Hey all,
Searched for a while but couldnt find a definitive answer. I have the base bars from BMW and they have a definite whistle. Ive literally tried sticking my hand out the window and sunroof to cover certain parts of the bars to isolate it, however no luck. Anyone know of where the whistle comes from or how to best eliminate it? |
12-22-2016, 10:20 PM | #2 |
I want to drive a Zamboni
1131
Rep 5,557
Drives: 13 E93 M3 18 F80 M3 16 K71
You can either get the Thule or Whispar bars from Yakima to reduce the whistle. OEM version is always making noise.
18 F80 Imola Red 6MT
16 K71 F800GT Montego Blue 13 E93 M3 Melbourne Red 2000 E46,2006 E90,09 E82,13 E93 328i,14 F30 335i,18 F80 M3 My next vehicle would be a Zamboni |
12-22-2016, 10:53 PM | #3 |
Rep 524
I have Thule aeroblades and even they make a tiny bit of noise when going highway speeds. Never tried oem bars but if my aeroblades make a bit of noise I can only imagine how loud oem bars are
Only thing you can do is buy new bars, or buy a wind fairing which should help a bit |
12-22-2016, 11:23 PM | #4 | |
Rep 774
12-23-2016, 08:43 AM | #6 |
Rep 938
Another one for the Thule aero bars. I used to have OEM bars on my 1 series (E87), and they made a ton of noise.
I've now got a set of Thule bars on my F31 and while I can hear some noise, it's not that bad. I've also got a Dynamic 800 roof box too and for what it is, it's fairly quiet.
Current car: 2017 BMW G30 520d M-Sport, BMW F46 218d Grand Tourer
Previous cars: 1989 BMW E30 316i, 1998 BMW E36 323i Coupe M Sport, 2009 BMW E87 116d, 2013 BMW F31 320d M-Sport |
12-23-2016, 08:45 AM | #7 |
Rep 4,983
I have the Thule aeroblades and they whistle too, depending on exactly where you place them. I got the air foil, and the whistling went away.
<b>2023 M5C SRG|Aragon || 2018 Macan GTS</b>
2019 F90 Comp MBB|Black (sold) 2018 F80 ZCP TB|SS (sold) 2015 F30 335 AW|CR (sold) 2015 F31 MG|CR (sold) 2011 E90 JB|Oyster (sold) |
12-25-2016, 05:00 PM | #9 |
Rep 52
I just went with the OEM bars. I got them on sale at the dealer and they were cheaper than the alternatives.
The only time they are on the roof is when I have my box or other things on the roof, and that is almost all the time. And the Thule Force Alpine box I have makes way more noise then the bars. So does the kayak in the summer or bikes or nearly anything I put up there. |
SteveInfante604.00 |
06-13-2018, 08:26 PM | #10 |
Rep 2
Roof rack noise fix
The noise on my vehicle was due to the square vent under the roof rack bar near the screw fixing the cross bar to the vertical strut.
It occurred from 30-65km/hr. For some reason... presumably due to a slightly larger hole and/or more laminar airflow in that region, it was only the front passenger side hole. Buy some weathershield sealant strip. I got a pack to seal up to a 8mm gap, which was more than required. I cut a strip 1" long, took off the roof rack and vertical strut and stuck it over just that hole. The roof rack can still close over the weather strip. Problem solved. I did not cover the other holes in case they are required for drainage. |
03-11-2019, 04:19 PM | #12 |
PPRSWCE
654
Rep 1,848
Bump.
So its not in the budget to get new bars. I'd consider the fairing if thats a definitive answer. But hoping for more DIY mods to reduce the noise. |
04-13-2019, 05:13 PM | #13 |
PPRSWCE
654
Rep 1,848
Added the omni fairing. Needed some bolts from the hardware store to make it compatible with the OEM rack but it works like a charm now.
whisper quiet! |
04-15-2019, 04:32 PM | #14 |
Rep 3,030
Fairing is the way to go boys, I lost patience last winter with my rack and sold it altogether. That whistling was so annoying.
Pretty sure the drag effects gas mileage too.
2016 BMW F80 ZCP
Instagram : 7IM3LESS https://instagram.com/7im3less?igshid=YmMyMTA2M2Y= |
05-15-2020, 10:11 AM | #15 |
Rep 1
05-15-2020, 01:30 PM | #16 |
Rep 48
I put some hot glue on the gaps between the plastic part and the crossbar. Read it from a fellow member awhile ago but it works. Also had an OEM rack.
05-15-2020, 01:44 PM | #17 |
Rep 681
I have Thule Aerobars on my wagon and they whistle quietly at surface road speeds. But once you get above 40ish mph, it goes away.
2016 328ix F31 - SOLD!
2006 997.1 C4S |
Shred Sled74.00 |
07-01-2020, 03:34 PM | #19 |
David
786
Rep 2,009
Lol to the people blaming OEM bars but they're actually one of the most quiet bars. I hear almost nothing unless my sunroof shade is open (Yes it isolates almost all the noise)
I only drive 80-90mph on the highway and it's almost silent I have a wagon with rails so I can move the placement wherever, the fixed placement on sedans is what must be causing the flow to be not smooth |
07-03-2020, 11:28 AM | #20 |
Rep 26
If you have OEM (or Thule aeros) and dont wish to have some sort of deflector:
Buy an extra strip of the rubber bit that fits in the T track.....if you use you roof attachments (eg kayak) in the same place all the time, cut your spare strip into pieces that fit exactly between the (eg Kayak) supports.......... In both my sets of roof bars it it the empty slots that whistle, not the bar with rubber strip in place (and my Thule aeros are worse than OEM) Worth a thought anyway |
07-16-2020, 06:48 PM | #22 |
Rep 5,456
Drives: F30
