06-20-2018, 10:57 AM | #23 |
Rep 434
That's like the perfect fitment in my opinion! Can't wait for mine now haha
2014 335i 6MT /// Mineral Gray - Red Coral
| M Perf Spoiler | M Perf Lip & Diffuser | M Perf Grilles | M Perf Side Splitters | M Perf CF & Alcantra Interior Trim | | Wagner Evo II FMIC | VRSF DP | AA CP | CTS Turbo Intake | MHD Stage 2 Tune | H&R Sports | Bilstein B8s | |
09-19-2018, 09:39 PM | #24 |
Rep 161
Download the APP named AliExpress , you can find some after market tips . copied M performance carbon fiber tip . Not original , but made well . [IMG][/IMG]
09-20-2018, 05:15 PM | #25 |
Rep 37
09-20-2018, 06:12 PM | #26 |
Rep 552
I purchased a pair of rep CF MPE tips, sized the same as OEM ones I believe (92mm out, 67mm inlet). Currently have older style MPE /w chrome tips. Plan on getting the new ones welded on once they arrive.
If you are considering these, make sure you get the correct size inlet to fit your current muffler. Many of these tips are around ~62mm inlet which I believe is too small for MPE. |
09-21-2018, 04:53 AM | #27 |
Rep 232
I just wish there was someone else that made a slip-on, with BMS type fitment, but slightly higher quality. I like the adaptability of the BMS slip-on, but I don't care for the look or discoloration after a bit of use. I did buy a set of really nice looking carbon tips from eBay (wasn't cheap, about $70 a piece X 2 for N55 exhaust), and they did slip on and allow you to clamp it on, but I would of had to cut the little fitment nipple on the OEM exhaust, which I didn't want to do, especially since I planned on swapping out the exhaust in the near future. Based on the crazy prices for OEM M carbon tips or OEM chrome/blk tips, it just makes more sense, to me at least, to simply buy an aftermarket exhaust altogether. So that's where I am at this point. I'm waiting and shopping for a pre-owned, reasonably priced, exhaust system. I'm kind of open as to which brand, but preferably an MPE, AA, or AWE. I have a hi-flo cat, plan to keep the factory resonator, so just looking for an axleback with minimal drone, as this is still our family car (technically wife's car).
09-21-2018, 10:08 AM | #28 | |
Rep 161
But if you choose right size , then will be fit |
09-27-2018, 12:10 AM | #30 |
Rep 161
10-02-2018, 08:05 PM | #31 |
Rep 552
Received my rep tips in the mail today. Plan on getting my MPE chrome tips either removed or cut off and then installing these. Happy with the size - same exact size as the OEM CF MPE tips from what I've read. Took me a while to find some that were just about identical.
Inner diameter: 67mm Outer diameter: 92mm |
10-03-2018, 12:57 AM | #32 | |
Rep 310
2008 E90 M3 6-Speed - Sold
2013 F30 335i MSport 6-Speed - Current |
10-03-2018, 10:23 AM | #33 | |
Rep 621
10-03-2018, 07:37 PM | #35 |
Rep 121
I have MPE on my 340i. I've tried alot of the aftermarket options and they didn't really fit properly.
Soooooo... I welded the tips on. |
10-04-2018, 12:09 AM | #36 |
Rep 621
10-05-2018, 07:27 AM | #37 | |
Rep 1,348
2k15 335i Msport xdrive 6spd
10-05-2018, 07:28 AM | #38 | |
Rep 1,348
10-05-2018, 08:54 AM | #39 |
Rep 105
Damn those replica carbon fiber M performance tips look nice. A decent exhaust option would be the $900 M Performance muffler on eBay (some dealership sells it without tips for $1000 + 10% eBay coupon) and then buy these tips
10-05-2018, 07:02 PM | #40 |
Rep 552
The tips fit but it wasn't that smooth of a process. The muffler shop had to drill out my chrome MPE tips (riveted on), then cut off the tailpipe ends that those were riveted to. The tips then slid on, but they still had to be welded to ensure they wouldn't move. You could probably clamp them on in some circumstances but the muffler shop advised against it when they showed me that they weren't tight enough. Either way, it was a very reasonably priced mod for my MPE. Any decent muffler shop should be able to take care of this for you for less than $100. Both tips can be found for $100 shipped if you order from Aliexpress. I also had them install stiffer rubber exhaust hangers so that my tips would not hang as low as they were before. Will post pics this evening.
10-05-2018, 07:06 PM | #41 |
Rep 552
You will need to pop off your current exhaust tips with a rubber mallet and then measure the inner diameter of the pipe. Then find some tips that fit those dimensions on Aliexpress or Ebay. I am guessing yours are about 63mm but recommend measuring to be sure.
10-05-2018, 09:19 PM | #42 | |
Rep 310
weird that your MPE tips were riveted on... older version? my Mpe tips uses a hex screw to lock into place
10-05-2018, 09:44 PM | #43 | ||
Rep 552
