12-26-2020, 09:34 AM | #1 |
Rep 1,782
PWG 335 Pure Stage 1 fueling
Good morning all, I hope everyone had a nice Christmas.
As the title suggests, I'm needing to gather enough fuel to run my PS1 efficiently and optimally and I already know my fuel pump is going to be limiting me. My question is which fuel pump to pick. I have studied the TTFS, Dorchester and Spool performance and was looking g for best value for money but also easiest to work with and tune as well as what is actually needed, 150/180 etc. My car currently has the OEM updated LPFP which I was told is flex fuel capable and so far have had no issues loading up with ethanol. I do not really run ethanol of I can help it. My goal for this car is quick and reliable daily with around 400-450 HP that you can get in and drive. Given the above, would it be wise to spring for the larger volume fuel pump or just get the lower volume and save a few $$? Also I'll need some spark plug advice as I was running NGK 2 step colder plugs and honestly didn't love them. I think the burn was too cool for my application and gap should have been adjusted. I'm about to run a stock set of plugs for right now before I retune the car with hopes of a HPFP install in the future. For the time being my car is FBO w/PS1 on regular BM3 OTS stage 2 map. Would it be fine to run the OEM bosch plugs with their factory gap of around .035-.038 or will it give me problem off the bat? Thank you guys for the input.
13' 335i M Sport. EBII/Coral Red 6MT. RPI GT exhaust, Resonator delete, PS1, GFB DV , BM3 Stage 2, ER CP, VRSF DP, VRSF 5.5in Stepped FMIC, Dinan Shockware. Carbon M Performance rear diffuser. M4 trunk lip. Conti DWS06 225/40/19 and 255/35/19
12-26-2020, 10:24 AM | #3 |
Rep 1,782
See I've heard differs and I've heard the same. I really want some owners of this setup to chime in as it puzzles me as well. Tuners are more than welcome as well.
12-26-2020, 10:44 AM | #4 |
Rep 1,105
Need a little more information:
Do you plan to use any ethanol or meth? Will you get a custom tune? Will you eventually go to a bigger turbo? |
12-26-2020, 11:07 PM | #5 |
Rep 1,782
I will get a custom tune yes, I guess I should have stated that as well. My idea is to Max it out and dial it back a bit. Additionally I was going to run the N52 exhaust cams on the car and tune those into the ps1. No meth no ethanol or not very regularly.
12-26-2020, 11:24 PM | #6 | |
Rep 7,606
The tricky thing is you say ethanol 'not very regularly'. I think you need to make a decision now, because running ethanol or not is going to be the deciding factor on whether or not you need a HPFP for your setup. You can probably get away with a light ethanol mix if you are just looking for a little extra octane, but it completely depends on how much boost your custome tune is going to run, and you would likely be at the limit of the stock HPFP in that case. If you dont mind spending the money to future proof your build and have the ability to run ethanol whenever you want and not worry about being at the HPFP limit, get a upgraded HPFP and be done with it. Stage 1 HPFP is more than enough for a PS1 even with moderately high ethanol mixes. Also, if you go custom tune, running an ethanol mix is really what will let you get the most out of your turbo upgrade, especially if your pump gas isnt the greatest, so consider that as well. |
harkes1078.00 |
12-27-2020, 01:51 AM | #7 | ||
Rep 1,782
12-27-2020, 09:21 AM | #8 |
Rep 1,105
If you have access to E85 then I'd suggest getting at least a stage 1 HPFP. You will yield more power with a ethanol mix in the E30-E40 range. I'm not sure when BM3 will start selling there new board package but once it does theoretically you won't need a custom tune. So if your banking on getting that hardware from BM3 I'd suggest holding off on thr custom tune but still purchase and upgraded HPFP.
12-27-2020, 01:00 PM | #9 |
Rep 529
Did you already buy the ps1? Just wondering because if you are thinking about getting an upgraded hpfp that costs twice as much as a ps1 it doesn't really sound like you are on a tight budget here and in that case might as well just get ps2
2013 F30 335i xDrive M-Sport 6MT (FBO/BM3 custom tune by HCP, 91 oct, 550i clutch, xDelete)
12-27-2020, 07:52 PM | #10 |
Rep 2,357
You can run 17psi to redline with PS2 and stock HPFP on 93. That is more power than you will ever make on the PS1. If response is key then the PS1 is a better choice though. I sometimes miss the instant torque with the stock/PS1. With the PS2 you need to be above 3k.
(A Dane in China) Last edited by harkes; 12-27-2020 at 08:00 PM.. |
12-29-2020, 11:44 AM | #11 |
Rep 1,782
Turbo has been in my car for 10k+ miles. I didn't want pure stage 2 I'm not building a drag car. I have 134k miles on this car. I drive it 15k a year. I want to get in, start it and drive it and have it perform like a stock turbo car with the light power bump. I'm very well aware that there are "better" options however that's subjective and I wasn't asking that to start with.
12-29-2020, 11:52 AM | #12 |
Rep 1,782
Ideally my thought process was ability to switch fueling on the fly without having to worry about the fueling demand from the pump on engine. I have been following BM3 advances and am very pleased with what they are doing. I will eventually integrate a FF analyzer into the lines and try to utilize the BM3 adaptability feature when it's ready. Why do I want a HPFP? Because I prefer over built than under built.
I'm not here to be the fastest 1/4 mile, stoplight or YouTube sensation. I want to get in the damn car, start it without worrying if some shit is going to break and then drive it like I stole it. I don't feel my requirements are overreaching. Everybody has to make their point PS1 is "pOiNtLeSs" however 400-450 HP is more than enough. Besides I've driven PS2 cars and I like where my power comes on line vs the PS2. It has a distinct lag. And the car I drove was tuned by Shoup (or however you spell it)
harkes1078.00 |
12-29-2020, 05:21 PM | #13 | |
Rep 529
How do you like the ps1? Was it worth it and a noticeable gain over stock turbo stg 2 fbo? Also what tune are you currently running?
12-29-2020, 08:12 PM | #14 | |
Rep 2,357
(A Dane in China) |
rjd_F301999.50 |
12-30-2020, 10:18 PM | #15 |
Rep 3,680
Turbo lag really doesn't bother me much, but that instant torque is certainly tempting. Was the difference between stock turbo and PS1 super noticeable, assuming same tune (or did you run PS1 with a custom tune)? If I can run pump and make around 400whp on PS1 that is definitely a tempting option, especially considering the price advantage.
12-31-2020, 01:33 AM | #16 | |
Rep 2,357
(A Dane in China) |
rjd_F301999.50 |
12-31-2020, 12:36 PM | #18 | ||
Rep 529
12-31-2020, 10:53 PM | #19 | |||
Rep 2,357
(A Dane in China) |
12-31-2020, 11:39 PM | #20 | ||||
Rep 529
01-01-2021, 01:30 AM | #21 | |||||
Rep 2,357
I have done this with the PS2 but with around 19psi instead.
(A Dane in China) |
aps335.50 Chicken_Joe606.00 |
01-07-2021, 12:48 AM | #22 | |||
Rep 1,782
akgambino271.50 |
