07-06-2020, 08:55 AM | #15423 | |
Rep 20
I did that but can't VO code the NAVENTRY as CAFD is not there, I injected one but when I FDL code it, it give me that the .ncd file is not executable so going no where, I started to lean it is either a bad emulator or bad unit |
07-06-2020, 09:00 AM | #15424 | |
Rep 40,762
"not executable" means coding parameter is incompatible.
07-06-2020, 03:14 PM | #15426 |
Rep 40,762
07-06-2020, 04:24 PM | #15427 |
Rep 20
07-06-2020, 04:34 PM | #15428 |
Rep 40,762
07-06-2020, 04:35 PM | #15429 |
Rep 1
ilmgdwwynpop
sildenafil generic vs viagra http://viaqara.com/ - otc viagra
sildenafil generic vs viagra 100mg viagra without a doctor prescription <a href=http://viaqara.com/#>viagra online us</a> order viagra |
07-07-2020, 09:38 AM | #15432 |
Rep 40,762
PM sent.
07-07-2020, 09:41 AM | #15433 |
Rep 40,762
Anything that can be VO Coded can be FDL Codes so long as you know the corresponding FDL Codes.
07-07-2020, 10:17 AM | #15434 | |
Rep 20
I tried to flush so created .ist and .soll and I tried to create new FDL, it was created and I can edit but when coding it is not working I have done all kind of VO coding to many friends so don't think it is compatibility issue, it seems what you stated bad emulator or maybe defective unit Thanks again |
07-07-2020, 10:28 AM | #15435 | |
Rep 40,762
07-07-2020, 03:14 PM | #15436 |
Rep 20
[QUOTE=shawnsheridan;26407114]Bypass Emulator. Set VIN in FA ot match ENTRTNAV Donor VIN, Can you VO Code it then? If you still have Not Executable error, then it is not Emualtor.[/QUOte
What I did in one of my failed attempts was took a copy of FA and customized the unit car (Vin, color ...etc) when I read with that file the car, it give me zero ECU Problem is with the unit in the car, I can't even update the date / Time, but I can see the HU_ENTRYNAV with no CAFD It is extremely weird but when I initially put it on, it was OK and I can even pair my phone then when unplugged to put the emulator, it is just giving me a radio, AUX and no communication what so ever to the car. I feel it is something in the unit maybe a fuse but this one doesn't have one from outside and I don't want to open so I can return it to the seller Greatly appreciate your helpful nature and your replies |
07-10-2020, 11:43 AM | #15438 |
Rep 40,762
07-11-2020, 02:37 PM | #15439 |
Rep 41
07-11-2020, 02:49 PM | #15440 |
Rep 40,762
07-13-2020, 02:17 PM | #15441 |
Rep 150
Hi Shawn
Can you please send me the link to latest Psdzdata and Esys for F30 2013 BMW 328xi. I coded this years ago and want to get back into it to try and code a fix BMW has for an issue Thanks! |
07-13-2020, 02:19 PM | #15442 |
Rep 40,762
PM sent.
