BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > F30 Coilovers Options - Comprehensive Overview
      11-11-2018, 06:44 PM   #177
Mkswoosh
Mkswoosh's Avatar
93
Drives: 2018 340xi tanzanite blue
Originally Posted by Logicoeur View Post
The Bilsteins, imo, are just better all around. The adjustment knobs are on the bottom of both shocks for the PSS10s. They also use a progressive spring across the lineup which has to be very closely tailored for the car/shock its used with. Bilstein also uses an inverted shock in the rear, like Ohlins, which are also an arm, and a leg lol. But they are worth it. If you need daily comfort and track ready coilovers you can't go wrong with either of these two.
KW uses linear springs, and sometimes two on the same shock to make a pseudo progressive setup. For your application I wouldn't spend the extra money for the Bilsteins. The Kw coilovers will be more than great to replace the base suspension, lower the car, and give it the driving experience it should have had from factory.
Man, i really appreciate your opinion. making my decisions A LOT easier. If i do go coils setup. I'm most likely just going to adjust it twice maybe 3 times a year. so easy access on adjustment shouldn't be too much of a reason for me. yeah that stock setup from factory just gives bmw a reason to go back and get more money from us. thanks for the response man.
      11-11-2018, 08:21 PM   #178
Sweeney921
Sweeney921's Avatar
98
Drives: 2000 BMW E39 M5
Be prepared for lots of wheel alignments! Rule of thumb is to have one done every time ride height is changed.
2017 BMW 330i Sport Wagon - M-sport, EBII, THP, DHP
Supersprint cat-back exhaust (resonated, dual outlet) - H&R rear sway bar - ER charge pipe
Waiting for: Bootmod3 - xHP Flashtool - xDelete
      11-11-2018, 10:04 PM   #179
Logicoeur
Logicoeur's Avatar
991
Drives: F30 335i xDrive
This. If you're adjusting height 3x a year you'll need 3 accompanying alignments.
The adjustment knobs I mentioned on the Bilsteins are for dampening/rebound adjustment. Bilstein knobs change both simultaneously, Kw v2/3 is the same (rears require removal of the shock from the car), and both offerings of Clubsport give you separate adjustments for both rebound and dampening. Clubsports are for hard core racing and they're $$$$.
      12-02-2018, 08:43 AM   #180
ricardofors68
ricardofors68's Avatar
326
Drives: '15 F10 M5
Originally Posted by obert View Post
Just did this install today. Need to adjust the height front and rear but I am happy with the ride quality and look. The rear is already low and I have almost another inch left on the rear before it as low as possible.
Next will be getting my car alignment done. Not to concerned right now due to the tires I have will not be the permanent ones.
Let me know how you like yours.
Installed mine back in Feb. Dec 2nd today and couldn't be more pleased with the BC items. Put almost 20k miles during this period and haven't suffered any fading or suspension quality degradation. Only time it scrapes the tires in during my morning commute with 5 not little kids inside and don't want to crawl over train tracks. etc. not a fault of the coilovers, just my preference and driving as the mood strikes.
They are also holding their appearance very well.
'17 C7 Vette GS (bye) / '15 F31 328 ix (sold) / '08 E92 335i (sold)/ '08 E92 M3 (RIP)/'01 M5 (sold, sniff)/'07 M5 (sold)/ '15 M5
Bt130915.00
PF49er0.00
      12-06-2018, 10:20 PM   #181
bursf9
Drives: 2014 bmw 328i m sport
These all seem legit though, i would get the most expensive one if i had money..
F36GC_NYC159.50
      12-09-2018, 02:18 PM   #182
Watsey
I think he means adjusting the damper resistance 2-3 times a year, not the ride height.
      02-04-2019, 10:50 AM   #183
Mkswoosh
Mkswoosh's Avatar
93
what's a recommended lube or whatever for the threads to adjust height? asking because i want to prevent it from seizing and not able to adjust later down the road.
      02-05-2019, 08:17 PM   #184
Logicoeur
Logicoeur's Avatar
991
Boeshield T9. Get it on Amazon, or online. It's a sprayable parrafin that dries to a film. I've used it on several coilovers through several NE winters with salt.
      02-10-2019, 07:25 PM   #185
Alpine-F80
Alpine-F80's Avatar
Drives: 2017 M3
Lol you must be a marketer's dream...
      02-13-2019, 01:35 PM   #186
zole2112
Modder of everything I own
zole2112's Avatar
147
Drives: 2013 335i Xdrive
Update on my CATuned coilovers. I've been driving on them since June 2018, I did soften them a bit, from 20/30 to 15/30 for the winter. Still really quiet. My son's 2014 EVO coilovers make a hell of a lot of noise even with everything tight so I'm really happy with my CATuned coilovers compared to his.
This is where I'm at with my summer wheels/tires, although I have my winter wheels/tires on now.
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
      02-13-2019, 01:37 PM   #187
zole2112
zole2112's Avatar
147
I used this as well, I raised my car a bit for winter and had no issues. T9 works great!
      03-20-2019, 11:35 AM   #188
deadserial
Drives: 2018 320ix
Anybody with ST Coilovers on their xdrive?
      04-10-2020, 11:42 PM   #189
Llamabeast
Drives: 2013 335i M Sport
2013 335i  [0.00]
https://www.ohlins.com/product/road-...2012-2017-f30/
Any feedback for these?
      04-11-2020, 03:21 AM   #190
andino
Drives: F31 328i xdrive
Originally Posted by Llamabeast View Post
Best out of box coilover for the f3x that I've driven. They don't go very low if that's what you want though. But great performance and comfort for daily driving and still capable on track.
2016 328ix F31 - SOLD!
2006 997.1 C4S
      04-11-2020, 04:15 PM   #191
Llamabeast
2013 335i  [0.00]
Just want performance right now don't care for looks at the moment. Also will these help with the pitch of the car? Speeding up and braking.
      04-15-2020, 12:40 PM   #192
FaRKle!
Dampers control the rate of weight shift, so you should notice a difference with brake dive and squat, and control that a bit since the damping is adjustable.
-My YouTube Channel for some of the best DIYs and in depth information
Please don't PM me for suspension recommendations unless interested in paid private consultations.
      05-16-2020, 05:23 AM   #193
CheddyWap
Drives: 2016 F30 328i
Hi, I'm new to the forum and also new to working on cars. Looking into upgrading my suspension and I was wondering if anyone has installed Air Cups to their coilovers?
F30B580.00
      05-29-2020, 10:21 PM   #194
TOchris
Drives: 2016 BMW 340i xdrive
I think I will go with the KW's
      06-13-2020, 09:59 AM   #195
itsrichierich
Moto Lover
itsrichierich's Avatar
187
Drives: '19 BMW S1000XR
Anyone have some coilovers for sale?
      08-25-2020, 10:16 PM   #196
UGA99
Drives: '14 335i xdrive 6MT
Originally Posted by zole2112 View Post
Thought I'd add my input since I just installed coilovers on my '13 335xi. After reviewing this thread and every other source I could find, I was trying to balance cost and performance as well as adjustability, I ended up going with CATuned coilovers. I paid $1200 and they have 30 degrees of dampening, very easy to adjust with the fronts using a supplied allen key through the top threaded rod and the backs with a collar located just above the bottom mount. The shock/strut height as well as the rear spring height are easily adjustable and are easy to rotate to the desired height. I installed these along with a rear sway bar (front will be installed in the next few weeks), rear subframe bushing inserts and rear upper adjustable camber bars.
The installation was pretty easy, I used a lift since I have access to one. After install I dropped it and drove it then measured and put it back on the lift to make the proper adjustments. I have no noise coming from the coilovers so far which is nice. I am set at 20 on the dampening so I set it pretty stiff. handling is night and day from what it was.
For me it was a great decision to go with the CATuned vs the KW v3 from a price standpoint. Time will tell how it progresses but so far so good!
Update 2 years later? Looking to get come coilovers for a 2014 335xi I just bought but don't want to spend an arm and a leg
      11-01-2020, 09:30 PM   #197
kylebm3
kylebm3's Avatar
Drives: 2009 BMW M3
Just ordered BC coils today!
      11-06-2020, 02:55 PM   #198
TheFanatic
TheFanatic's Avatar
Drives: BMW 340i
The KW HLS coilovers are finally available for the f30 340i xdrive! Anyone run these in a different car? If so how were they and what coil level can they be compared to the V1, 2, or 3?
https://www.kwsuspensions.com/produc...-19299299.html
