BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > OEM HUD Retrofit
      01-25-2017, 12:14 AM   #23
soso2222
Drives: Z4 35is, F31 330xd
Thank you for a valuable input!
      01-29-2017, 02:56 PM   #24
soso2222
I made it today in 5 hours! I love my new HUD!
This Retrofit was really difficult! The F10 wire doesn't fit at all! I head to cut off all the noses from the plug (cluster side) and turn it clockwise 90°. The other plug (HUD-side) is covering a power connector, so it was a lot of tinkering! Cutting a hole in a dash was pain in the ass!
Left air duct has to be changed.
And you need not only 3 bolts for HUD (part number: 11119143167) but also 3 nutīs (part number: 64509123157)!
CU and thank you for support!
      01-29-2017, 03:10 PM   #25
evdok
evdok's Avatar
Drives: 330D M/SPORT xDRIVE INDIVIDUAL
Great for you bud, wish i was that brave.
Happy Motoring
Evdok
      01-29-2017, 04:18 PM   #26
kzg1969
kzg1969's Avatar
Scotland
676
Drives: X3M Comp / Focus RS
great job....i wouldnt even know where to start!!!
      01-29-2017, 04:23 PM   #27
soso2222
Thank you!
basically you have to remove dash and cut a hole in it. Thats it!
Hier is a todo list....
      02-02-2017, 09:54 AM   #28
roxxor
roxxor's Avatar
600
Drives: 2020 530e
So after attempting this yesterday, I am fairly certain that the F30 HUD will not work with the F01/F10 6WB Digital Kombi. I connected the power/ground wires for the F30 HUD, connected the HSD wire to the Kombi, coded the FEM/NBT/DKombi, made sure the checkbox to turn it on was selected in iDrive, and.... nothing. I tried changing the position of the HSD wire, rotating it 90 degrees at a time, nothing on any of the 4 rotations.
My theory is that because the F01/F10 HUD uses CAN line connections, it does not send the correct signals to the HUD through the DKombi to the HUD via the HSD(a.k.a. Apix) wire, while the F30 does. In the coding I was reviewing, there is an option to choose if the HUD is connected via Apix or CAN. The problem there then lies in that the F30 HUD unit does not have a CAN connection, so there is no way to be able to use that option. The alternative would be to try to fit an F01/F10 HUD unit in the car, but without actually buying a unit and test fitting it, there is no way to tell if it would work, let alone fit into the mounting spot correctly.
Personally, I enjoy having the 6WB more than the prospect of having the HUD, although that could be because I have never experienced the HUD. Either way, I will most likely be passing on trying to further attempt to get it to work with the 6WB in the F30.
      02-02-2017, 02:05 PM   #29
soso2222
Too bad
      02-08-2017, 12:06 AM   #30
soso2222
Hi everyone,
i have a problem with my retrofited HUD. By daylight it is to dark even at max. brightness! Did i miss something? Do i need some extra coding?
Thankīs
      02-09-2017, 11:14 PM   #31
soso2222
Originally Posted by soso2222 View Post
Hi everyone,
Thankīs
Problem solved!
I had to swap an old RLS with an RLS HUD-version (Partnumber: 61359293279) and initialise it with RG!
      03-13-2017, 11:09 AM   #32
jpcampa
Drives: BMW F31 M
Problem solved!
Hi... any little guide or DIY??
      03-15-2017, 01:38 PM   #33
Animal Farm
Drives: BMW F30/Volvo XC90II T6
Post some pics of the end results! We're all suckers for these things
cdwalls580.00
      03-20-2017, 02:57 AM   #34
soso2222
DIY for swapping RLS?
You have to remove internal mirror and swap an
RLS. Thats it!
      03-20-2017, 02:59 AM   #35
soso2222
Iīll do it today!
      03-22-2017, 11:39 AM   #36
jpcampa
Drives: BMW F31 M
RLS. Thats it!
No... :-) Sorry... I refer to the HUD retrofit DIY...
      03-29-2017, 10:42 AM   #37
Animal Farm
Iīll do it today!
That looks awesome! Great job!
      03-29-2017, 02:11 PM   #38
f30GTR
f30GTR's Avatar
49
Drives: 2014 AW F30 335i M-Sport MT
Can i safely assume that a new cluster with the right connection to the HUD is required?
      03-30-2017, 12:47 AM   #39
soso2222
Yes, you need a new cluster with HUD-connector. But before you swap it, i recomend you to look at the back of your cluster. Maybe it is allready with HUD-connector.
      03-30-2017, 01:38 AM   #40
soso2222
It will be difficult. I was warking alone and didn't made any pictures. Basicly you have to remove dash, cut a hole in it, connect HUD with cluster and install it. Than do some coding. Thats it!
      03-30-2017, 03:25 PM   #41
f30GTR
f30GTR's Avatar
49
I am pretty sure it doesn't. BMW has different part numbers for HUD cluster and no HUD. Did you end up replacing your cluster?
      03-30-2017, 03:35 PM   #42
kevinjt
kevinjt's Avatar
142
Drives: 335i M-Sport 14'
That retrofit is great! I really like to have HUD very handy for me.
      03-31-2017, 12:39 AM   #43
soso2222
Yes i replaced my cluster, i had a basic-cluster thow, so i replacred it with extended one, it was one of many retrofits i did
      04-14-2017, 04:22 PM   #44
jalami
Drives: f30
Up
