BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > OEM HUD Retrofit
      04-17-2017, 11:21 PM   #45
SMiGGs
Drives: Msport
so all that is needed is just a heads up display, and an extended cluster?
Also, any pics of the cutting, im willing to do a full DIY, with coding, if you guys have any pictures?
      04-21-2017, 04:48 PM   #46
jalami
Drives: f30
Me too.
There should be a template for cutting.
http://i66.tinypic.com/n3riwy.png
      04-22-2017, 01:52 AM   #47
soso2222
Drives: Z4 35is, F31 330xd
That's right! And don't forget a Video-Kabel
      04-22-2017, 03:31 AM   #48
SMiGGs
Drives: Msport
Cool, totally went over my head, but my car already has the extended cluster.
One more question, you said check my existing cluster. What should i be looking for, i know its HUD connector, but how does it look? Is it the HSD wire. I can pull off my cluster and give it a quick check, before i buy all these items in my cart off ebay.
      04-22-2017, 03:56 AM   #49
soso2222
The blue connector on the picture
      04-22-2017, 07:21 AM   #50
jalami
Drives: f30
It is confirmed that it can be cut????
HUD installation, it is necessary to remove Instrumentenboard??
      04-22-2017, 10:54 AM   #51
soso2222
1. yes
2. yes
      04-22-2017, 04:35 PM   #52
jalami
Drives: f30
Originally Posted by soso2222 View Post
1. yes
2. yes
OK. Thanks.
Finally you need fsc code?
      04-23-2017, 12:17 AM   #53
soso2222
OK. Thanks.
No FSC code is needed!
      04-26-2017, 09:05 PM   #54
SMiGGs
Drives: Msport
Cant find a reasonably priced HUD, if someone finds one, pm me or reply on here, and ill gladly purchase it, and do the diy, dont mind cutting things up lol.
Also another question, all-every year HUD modules should be compatible correct? There isnt any funny business, like bmw updating the their hud modules for the 14's?
      04-27-2017, 12:49 AM   #55
soso2222
Yes, all HUD models are same.
I got mine on eBay for 400. It was brand new!
      06-27-2017, 12:21 AM   #56
Nomana
Nomana's Avatar
1289
Anybody has list of parts needed?
Cheers
      07-17-2017, 06:31 AM   #57
JamesGama
Drives: 435iGC MPerformance
Hi there,
New to here but I am looking at doing this retro fit to my 435iGC I have the windscreen HUD and all the other parts listed just wanted to get in touch to ask a few questions on it.
Thanks for the help. 😀
      08-16-2017, 06:10 AM   #58
PhreakShow
Drives: F31
Do you know if it is possible to not only cut a hole for the HUD, but also for the center speaker?
      08-21-2017, 09:59 PM   #59
valley_nomad
Drives: 2013 F30 328i
http://f30.bimmerpost.com/forums/sho...&postcount=100
      12-09-2017, 12:16 AM   #60
Jhnblckwood
Drives: F30 2014 320i xdrive
I bought a 6wa cluster with hud, what if I retrofitted hud but didn't change windshield, would it totally not work at all? Sorry if this is such a dumb question but if I have to change my windshield then this is a non starter unless a rock hits me n then I have to change anyway. 2014 f30 idk if windshield I have would work. Anyone?
      12-09-2017, 03:18 AM   #61
soso2222
It works with a normal windshild as well. You will get double pictures thow!
      12-12-2017, 03:57 PM   #62
Jhnblckwood
Double pictures?
      12-12-2017, 04:03 PM   #63
PhreakShow
Drives: F31
There are two main reflexions. One while entering the glass, and one while leaving.
      12-12-2017, 06:01 PM   #64
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
It's actually caused by the 2 layer laminated glass, you get a reflection off each layer. An aftermarket HUD reflector will fix that, it has a mirror finish so that you only see the reflection off it and not the glass behind it.
      12-12-2017, 06:25 PM   #65
Jhnblckwood
Oh ok. Thanks ��
      12-12-2017, 06:30 PM   #66
Jhnblckwood
Sorry but jus wanna double check this is correct. Also i read in real open starting in 2013 hud hardware changed. Does that mean u must get hud from any bmw 2013 or newer? Thanks
