Login
05-12-2020, 07:10 PM | #89 | |
![]() 53
Rep 234
![]() After reading through the diagram multiple times, I understand that Brown wire in the picture below goes to A173*7B pin 32 and Red/yellow wire goes to A71*1B pin 10 please confirm so i don't messup. Thanks in advance ![]() |
05-13-2020, 10:15 AM | #91 | |
![]() ![]() 25
Rep 224
05-13-2020, 10:37 AM | #92 | ||
![]() 53
Rep 234
Click appreciate if this post has helped you
![]() Retrofits: NBT evo ID6, 6wb cluster, heated steering wheel, HUD, Kafas2 with LDW, SLI, HBA, FCW and pedestrian warning, LCW, Surround View and Parking Assist. |
05-16-2020, 02:17 PM | #93 | ||
![]() 53
Rep 234
05-17-2020, 03:27 PM | #94 | |
![]() 53
Rep 234
05-18-2020, 02:23 PM | #95 | |
![]() ![]() 25
Rep 224
I also had this problem when i retrofited snap-in the hsd cable was wrong and didnt fit so i cut it so it would fit but i had a short circuit, had to turn the cable 180° and then it worked. |
05-18-2020, 10:05 PM | #96 | |
![]() 53
Rep 234
Seller also confirmed to rotate the cable by 180 degrees. Now the problem is i had to trim the hud side connector as well. Can you please help to figure out which pin is voltage and which is ground on the hud? After 180 degree rotation Can you please tell if the voltage and ground wires look correct or should they be swapped. Thanks ![]() |
05-19-2020, 10:04 AM | #98 | |
![]() ![]() 25
Rep 224
05-20-2020, 12:51 AM | #99 | ||
![]() 53
Rep 234
![]() Thank you so much for the help ![]()
05-20-2020, 09:59 PM | #100 |
![]() 22
Rep 103
Is there any reason I wouldn't want to use an HSD cable like this?
https://www.ebay.com/itm/HSD-Wire-LV...EAAOSwC19bEP37 Figure it needs a little modification but appears like it would work. |
05-20-2020, 10:47 PM | #101 | |
![]() 53
Rep 234
For hud you need a cable like this https://www.ebay.co.uk/itm/333352572725 or https://www.ebay.com/itm/264653504384
05-30-2020, 02:58 PM | #102 |
![]() 53
Rep 234
Installed HUD today and everything is working fine except the brightness on a sunny day even with full brightness setting in idrive. I have RLS sensor hud version ready but do you suggest installing it now or after windshield replacement?
Any suggestions please. Thanks ![]()
05-30-2020, 03:27 PM | #103 | |
![]() ![]() 25
Rep 224
The only thing that the HUD windshield does is make what you see 1 image instead of 2 images slightly over each other witch makes it little blurry |
05-30-2020, 03:35 PM | #104 | ||
![]() 53
Rep 234
05-31-2020, 05:20 AM | #105 | |
![]() ![]() 25
Rep 224
So they allready changed the original sensor to another windshield, and i removed that sensor myself and changed it with the HUD sensore if you follow how to do it there are no problems. |
07-14-2020, 03:10 AM | #106 |
![]() 15
Rep 81
ok! Before I start another thread. seeing you guys seem to know whats going on with huds and whatnot. Ive got electrical gremlins in the vehicle at the moment which started with LCI tail upgrades. remove the battery, now my hud does not work. I have unticked it from the Idrive, but now I cannot tick it again! any ideas?
07-14-2020, 10:27 AM | #107 | |
![]() 53
Rep 234
09-03-2020, 02:51 AM | #109 | |
Rep 16
09-08-2020, 02:41 PM | #110 |
![]() ![]() 25
Rep 224
