BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > OEM HUD Retrofit
proTUNING Freaks
      10-15-2020, 04:28 PM   #111
allerena
Drives: 435i xDrive
Hi deneyer I have a question about the cutting. when you cut the dashboard do you have to also cut the side vent duct? I am talking about the one that goes from the windshield to the drivers window? I know that you must change the air duct for the driver side face upper vent
Thank you.
E9x picture game: 1 point
      10-16-2020, 12:41 PM   #112
deneyer
Belgium
25
Thank you.
Yes it has to be cut also, but once you place the left airduct (HUD option) it covers the middle airdunct almost completly
      10-16-2020, 12:43 PM   #113
allerena
Drives: 435i xDrive
Thank you.
Yeah but doesn't it leave the duct useless since it now has a giant hole and won't direct air to the side window??
      10-16-2020, 03:11 PM   #114
freespirit
freespirit's Avatar
53
Drives: f30 2016 BMW 328i
Thank you.
Yes it makes the duct useless and also no airflow to windshield which makes it dangerous during rainy and snowy days. That's why I have replaced the dashboard with hud version though I cut the original dashboard and retrofitted HUD initially.
Click appreciate if this post has helped you
Retrofits: NBT evo ID6, 6wb cluster, heated steering wheel, HUD, Kafas2 with LDW, SLI, HBA, FCW and pedestrian warning, LCW, Surround View and Parking Assist.
      10-21-2020, 04:57 PM   #115
deneyer
Belgium
25
No it still works unlike what freespirit says probablly cut to much then. I didnt change the dash and cut the hole, only thing i changed was the airduct leading to the left side(64229218500). For the frontwindow air, you have to cut the hole bit by bit so it fits with minimum space (if you put the hud cover on top of dash it closes the opening for the front window airduct almost completly) and everything works great even the defrost front window (i didn't take a photo of that to show sorry)
      10-24-2020, 01:04 PM   #116
freespirit
freespirit's Avatar
53
Probably you're right sir.
The airvent thats close to windshield with HUD is around 1 to 2inch and without HUD seems to be around 4inch.
When I did the retrofit, unfortunately I didn't find any guide like this showing difference between the dashboards with and without HUD. I thought there's no way i can fit the HUD without cutting the vent. Though I have managed to seal the vent and fit the HUD, I was worried about the air leaks. So went with new dashboard with HUD and found a good deal for just 250 bucks
Excuse my handwriting in the pics ... posting it from passenger seat while my wife is driving... you know how bumpy and shaky the ride would be
      11-06-2020, 05:42 PM   #117
chrbmw
Drives: BMW F31 and BMW Z3 M Coupe
Can anyone confirm if it is necessary to cut the ventilation duct to fit the HUD?
This retrofit is getting more and more expensive! just found out I needed to replace my cluster also. If I have to replace the dashboard, I almost feel like backing out of this retrofit!!
Parts needed so far:
HUD 62309865042
Cable for HUD ---------------
Screws for HUD 11119143167
Dashtrim for HUD 51459239336
Sound isolation for dash trim 62309236820
Windscreen 51317258072
Rain sensor 61356814596
6WB Cluster 62109442850
And now maybe also Dashboard!!
I regret starting this project. But once I have started I must complet the job.
Is it even worth trying to cut the old dashboard?
And also is it necessary to replace air duck 61119322250?
      11-22-2020, 10:28 PM   #118
Mysta
Drives: B58
How'd you program the cluster after you finished up?
      12-09-2020, 08:29 AM   #119
allerena
Drives: 435i xDrive
So I went ahead and got a dashboard, the cutting was definitely not an option. The dashboard is completely different when it comes to the ducts and stuff, not just a matter of replacing one duct.
https://youtu.be/EL9BHmBM2qA 20:47 mark.
Episode 2 of that serie shows the wiring, parts and all you need to make this work. Coding is next.
      01-11-2021, 07:14 PM   #120
nnniiiccckkkyy
Drives: BMW f30 320d/Bmw f36 430i
Her are some pictures
I want to do the same retrofit. I am only unsure about the air vent. Did you have to replace it?
Thank you in advance
      01-12-2021, 03:22 PM   #121
deneyer
Belgium
25
Not true like i said i did it with my f34 if you cut it correctlly it does work and fit perfectlly! Dash is the same only difference is the airduct for the front window that is different en the side airvent is an other one to cause you have the hud hole in the dash.
But if you have any idea of what you are doing and a little handy you can use the original dash and save money there, cause its just plain stupid to spend money on that when you know what all the rest costs!
Watch added pictures, picture 1 the hole i cut in original not hud dash and you can see the hole in the airduct on the left side. The second picture with the hud dash trim on it fits perfectlly you see that the duct is completly closed by the trim!
      01-12-2021, 03:26 PM   #122
deneyer
Belgium
25
Watch my previous post, i only bought the hud version vent for the driver side vent, the airduct for the front window i cut till the hud trim fitted on it
