04-30-2020, 11:40 AM | #25 |
Rep 259
Why does ST’s website list the part # as 1822000F? What’s the difference in part #’s? Thanks..
04-30-2020, 12:30 PM | #26 | |
Rep 758
X is just height adjustable XA is height and dampening XTA has camber plates, not sure if it does rebound also though.
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
04-30-2020, 07:48 PM | #27 |
Rep 259
04-30-2020, 08:58 PM | #28 |
Rep 758
check what's available for your car, I know for the F30 they don't list the XTA's as available.. maybe special ordered or just not made for the F30, if you really need camber plates you can always add them seperate.
05-07-2020, 10:24 PM | #30 | |
Rep 135
FYI i would put these on a 340i M sport with 403M's |
05-10-2020, 11:05 AM | #31 |
Rep 121
I just had the ST XA's installed and they feel almost exactly the same as the H&R Sports I had on with my EDC shocks. Couldn't be happier. The shop said they had set at 3 out of 5 on damping. Thank you for the review to help with my decision.
DeeM5527.50 SteveInfante604.00 |
05-10-2020, 05:44 PM | #32 |
Rep 135
Does the ride feel harsh? If you hit a bump do you really feel it or do the shocks absorb the bump well? Looking into these since it has the dampening system and would like to stay as close as possible to a stock feel
05-10-2020, 10:36 PM | #33 |
Rep 121
Drove around some more today and I love the ride. Firm but wouldn't say harsh. I think it rides better than my EDC shocks that were lowered with H&R sports. I think the shocks were going out slowly due to the lower height. I had ST's installed at Independent Motors in SD and he also recommended the ST's. He does a lot of autocross with his bimmer and runs them but with camber plates XTA's. Also note I have slightly larger tires 235/40 & 265/35 on 19's. Cali roads are getting bad and wanted some more cushion. My ground to fender height is about 25.75".
07-30-2020, 10:20 PM | #34 | |
Moto Lover
187
Rep 591
Drives: '19 BMW S1000XR
07-31-2020, 12:08 AM | #35 | ||
Rep 758
08-01-2020, 04:38 AM | #36 |
Rep 192
The stiffness adjustment is at the top of the struts for both front and rear right?
So fronts can be adjusted just by opening the hood and lifting the rubber cover out of the way but the rear requires taking the whole shock out of the car? I'm currently torn between ST XAs and BC Racing BRs... |
08-01-2020, 05:01 AM | #37 | |
Rep 758
08-02-2020, 05:16 AM | #38 | |
Rep 192
I believe the wheel wells have to be drilled in order for the cable to pass through for that though right? I'm not so keen on drilling through the metal... |
08-02-2020, 11:59 AM | #39 | ||
Rep 758
08-05-2020, 01:28 PM | #41 | |
Rep 100
"The upper ID of the front spring is 95mm and here are the dimension of the piston rod." |
08-09-2020, 01:01 PM | #42 | |
Rep 17
Ahh okay! Thanks for the info. I'm sure EAS has done plenty of these so I'll give them a call and find out which camber plates do customers usually go for. Hopefully vorshlag plates do fit considering they're compatible with KW |
08-30-2020, 12:03 PM | #43 |
Rep 17
Just an FYI but GC camber plates do indeed fit these coilovers. Had them installed at EAS on Friday and couldn't be happier. For the coilover price and included cost of the camber plates though, I should have just gone with broadway static coilovers...
09-01-2020, 05:46 PM | #44 |
Rep 1,288
First time I heard of these... enlighten me...lol... I was just about to order the ST XA...
Update: they don't make them for f30 xdrive... .... loved the aircup video though... Last edited by FastF30; 09-01-2020 at 06:51 PM.. |
