01-16-2022, 11:17 AM | #1 |
Rep 4
F30 drivetrain malfunction
I turned the car on coldstar it was about 38 degrees Fahrenheit (note:this is probably the coldest the car has ever seen) I got a a drivetrain malfunction light while I was letting the car idle for about 3 minutes. But I turned the car off and then on again and the light didn't come back, not even the engine light, I drove it for about 5 minutes and still nothing. Also I checked for codes and everything was clear. Has this happened to anyone else ?
01-16-2022, 01:02 PM | #2 |
Rep 496
Yes, it happened to me when I reconnected the battery (after disconnecting it for some work I was doing). I stopped the car, turned the engine off and then on again: never seen the light again and all have been well
01-17-2022, 05:55 PM | #3 |
Rep 4,876
Bah... 38 degrees? Your car would die in my climate. It was -38F a couple weeks ago.
Sometimes there is a communications glitch which can toss erroneous codes. Cycling the power should fix it (like it did for you). As HarryTee mentioned, I've also seen a ton of codes when I've disconnected and reconnected the battery cable. If it comes back, then I'd worry about it, otherwise, it should be fine. |
01-22-2022, 07:42 AM | #4 |
Rep 13
I got this on my F32 428i from time to time, very random, and very rare (maybe twice a year?). Not sure what causes it, but it comes up occasionally. I probably flogged the car too hard. The car goes back to normal once I restart it.
01-22-2022, 10:34 AM | #5 | |
Rep 126
01-22-2022, 11:47 AM | #6 | |
Rep 4,876
I joked with a "I think the car is just telling me to park and wait for warmer weather!" |
