10-19-2018, 10:06 AM | #1 |
Rep 4,551
Drives: 2015 328d xDrive
Steering wheel heat not working after conversion
Hey all,
I did an M Sport steering wheel conversion on my non m sport 2015 328d and everything works except the heat. My car just has cruise control and heated wheel as options. On real oem is says the correct part number for the heating module is 61317849393 http://www.realoem.com/bmw/enUS/show...diagId=61_5666 The car is giving me an error message though and the heat does not work: Does anyone know what I can do to get it working? Is there coding required? Any help would be greatly appreciated. Thanks. |
10-19-2018, 10:27 AM | #2 |
Rep 10,256
It's worth asking if the M Sport steering wheel has the heating element. There are two versions of the M Sport steering wheel: with and without the heating element.
10-19-2018, 10:29 AM | #3 |
Rep 4,551
The M sport wheel I purchased is heated
10-19-2018, 10:33 AM | #4 |
Rep 10,256
Got it. Thanks for confirming.
I did the same conversion on 2013 BMW 335i xDrive sedan. No coding was required. As long the steering wheel has the heating element and the control module has been installed, the heated wheel feature should work. I can only think that either the control module is bad (if it's new - unlikely) or the connectors have a loose connection. |
10-19-2018, 10:36 AM | #5 | |
Rep 4,551
I bought my module new but it's possible it was damaged or is the wrong part # somehow. Do you happen to have a part number for the module you used? |
10-19-2018, 11:38 AM | #7 |
Rep 4,551
That's a real head scratcher then
10-19-2018, 11:56 AM | #8 |
New BMW owner
139
Rep 621
Drives: BMW 316d, BMW F40 116d
Try your other steering wheel again, if it doesn't work with the old steering wheel then there is a connection problem.
10-19-2018, 11:59 AM | #9 |
Rep 4,551
Old one is long gone (sold) so that option is out unfortunately. I'm going to see if I can get another module, and if that fails I'll have to check wiring I guess
10-22-2018, 10:15 AM | #10 |
Rep 4,551
One more question I should ask is what your option are? Do you have lane change assist (wheel vibration) or just heat?
I just have heat in mine and nothing else so it could be possible we require different parts perhaps? |
10-22-2018, 01:56 PM | #11 |
Rep 1,139
Just to ask, but since you mentioned you bought the module new, did you code it? A used module would have already had the correct coding for the car, but if the module was brand new, it might require just the basic coding to program it with what options the car has.
10-22-2018, 02:21 PM | #12 | |
Rep 4,551
I have also tried going to a bmw dealership to get a diagnostic done or to be told what the problem is and they were absolutely useless in helping. They tried to tell me I needed a new wheel. Not a module. An entirely new wheel. Seriously. I then had my local mastermechanic look at it as well but he's not a bmw specialist so he could only help so much. It's starting to get pretty frustrating. |
10-22-2018, 02:41 PM | #13 |
Rep 1,139
Is that a steering wheel off an M3/M4 that you bought? The part number that it came with is from one of those, but not an F30, which would explain why it would flag as the wrong version if the old one was in at that point, and won't work in the F30.
As for the new module, yes, if it was brand new, it would require coding, otherwise it has no knowledge of what features/options your car is supposed to have. If you aren't comfortable with trying it yourself, I would try to find someone local who could help with the coding. For explanation of what you need, all they would need to do would be to create a Cafd file for the module and VO code it. And yeah, unless you are really, really cool with your dealer or know someone personally who works there, they will usually tell you to hit the bricks when it comes to getting help with retrofits that aren't sold by BMW. |
AndrewC198910931.00 |
10-22-2018, 02:50 PM | #14 | |
Rep 4,551
10-23-2018, 07:32 PM | #15 | |
Rep 4,551
Went to coder. He said the module does not show up in ESYS (or whatever program he was using) so according to him it's a hardware related issue. Wheel needs to come apart again and be inspected by someone else I guess. What a PITA. |
10-30-2018, 09:40 AM | #16 |
Rep 4,551
Update: Issue solved! The problem was coding. Initial coder I went to was wrong I guess. Someone else looked at it and fixed it.
11-08-2019, 04:10 PM | #17 |
Rep 67
Do you know what they coded exactly? Would be helpful as I'm looking to update modules and looking at those two part numbers as options.
11-08-2019, 04:25 PM | #18 |
Rep 4,551
11-09-2019, 08:30 AM | #19 |
Rep 173
Drives: BMW 340i Touring, Aston Martin
Code in FEM:
CODDT_BYTE_00_SZL_LIN = LHZ_aktiv LIN_VARIANTE_LRE = lre_tlc_lhz LIN_VARIANTE_SZL = szl_4Band LRE_Verbaut = aktiv |
