04-12-2019, 06:01 AM | #1 |
Rep 44
Which Smart Battery Charger is Best for my Needs?
Hello everyone,
I am new to the forum, but have been reading the threads since a while and believe that I will enjoy learning more and also sharing info here as well. Have 3 cars with 45 AMP 74 AMP and 90 AMP AGM (BMW F30 320 battery) batteries and would like to charge them from time to time as sometimes they sit for some weeks. After some research I have found out that there are 4 options: 1- NOCO Genuis G3500 2- Suaoki 1A-4A charger 3- Noco Genius G7200 4- Suaoki 7A Charger. As I understand the 3.5A Noco and the 4A Suaoki have very similar characteristics as they both work with 6V/12V batteries and have automatic charging capacity between 1A and 3.5 and 4A. If I am not wrong comparing to a 4A charger the 7A charger seems to have more chance to repair a dead battery when it tries to desulfate a dead battery with high amperage charge. However 7A version of both brands are unnecessarily more expensive and work between 3.5 and 7A current. So in this case choosing 4A version makes more sense as it will be able to charge 90 or even 95AH battery which F30 uses in anyway, and it will be better for the battery as lower amperage will be better for the battery. Any experience with those chargers? Which one would you recommend? I really prefer to pay as minimum as possible as long as my needs are met. Many thanks in advance. |
04-12-2019, 07:37 AM | #2 |
Rep 15,966
You don't want to let the car sit for weeks and then recharge the battery with a high capacity charger, you want to put it on a maintainer that keeps if from losing charge while it sits. This is what I use, though I doubt it's available in Europe:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
04-12-2019, 08:05 AM | #3 | |
Rep 44
Local availability doesnt matter because I will get it in anyway with help of someone travelling from the states or uk. |
04-12-2019, 09:56 AM | #5 |
Rep 15,966
In trickle mode it won't run at more than 2A anyway, so there's no point in spending more than you have to for that. I bought the one I did because it cost no more than pure maintainers that only had 2A or less trickle capacity.
04-13-2019, 12:29 AM | #6 | |
Rep 44
And is it really able to recover and fix a dead battery as good as an expensive Noco or Suaoki? Is the reason of price difference only marketing? Last edited by nightbreaker; 04-13-2019 at 12:40 AM.. |
04-13-2019, 08:18 AM | #7 |
Rep 15,966
It is switchable between 2A for maintaining and 8A for fast charging. I've never used the 8A setting. When I'm not driving the car for an extended period in warm weather or if the overnight temperature goes lower than -5C I plug it in on the 2A setting, so my battery has never needed a fast recovery charge.
04-14-2019, 02:13 AM | #8 |
Rep 387
Bill, I’m curious. It has been years since I’ve used one of these. Last time I used one I connected the red terminal to the battery, black to ground, as you would when jump starting. I’m wondering if you can connect it to the jump start contacts under the hood?
04-14-2019, 06:15 AM | #9 |
Rep 7,483
Yes you can and you should- according to the owners manual.
04-14-2019, 06:23 AM | #10 | |
Rep 44
So when you charge the battery instead of connecting the charger cable directly to the battery you connect the cable to the + and - terminal screws under the hood? The advantage in that is not to loose adaptation values. |
04-14-2019, 09:04 AM | #11 |
Rep 15,966
I permanently wired a quick connect to the under hood charging posts, the connector extending out of the lower radiator grill. That allows me to plug my trickle charger in my garage into the car without opening the hood or trunk, which I do regularly in the winter.
04-16-2019, 01:26 AM | #12 | |
Rep 44
But I am afraid that it might cause the car to loose all adaptations and maybe even the remote door lock function might not work after a long disconnect. Secondly I decided to buy a max 4 amp charger as I believe it will be highly enough for my 45, 74 and 90 amp car batteries. As I understand the repair mode of NOCO is just useless and the NOCO G3500 has no difference from BOSCH C3 charger even as both actually only have 3 stages...Fast Charge,Slow Charge and Stand By...And the other stages are just marketing game to fool customers to pay extra money for a simple smart charger. What do you think? |
04-16-2019, 07:50 AM | #13 |
Rep 15,966
Disconnecting the battery will only cause the clock to require resetting, but there's absolutely no reason to disconnect the battery. There's also no reason to connect the charger to the battery, that's what the charging posts under the hood are there for. 4 amps is more than enough to supply current to those components that draw power while the car is not being driven, preventing the battery from discharging. I had a NOCO 3500, it died after only a year, so I wouldn't recommend it. Reviews of the C3 aren't good, and it's too expensive. Even a 1 amp charger will charge a 90 amp battery from dead to full charge, it just takes 90 hours to do it. The only reason to have a high current charger is if you need to charge a dead battery. By using a maintainer you'll never have a dead battery.
04-17-2019, 04:32 AM | #14 | |
Rep 44
As I see the 1 AMP chargers are recommended for bike batteries which makes me get confused. Is that just marketing to get extra dollars on 4 amp or 7 amp charger sales? |
04-17-2019, 07:18 AM | #15 |
Rep 15,966
Connecting the charger to the posts is electrically identical to connecting it directly to the battery. 1 amp chargers are recommended for bike batteries because that's all a bike battery needs to fully charge a dead battery overnight.
04-19-2019, 03:21 AM | #16 |
Rep 44
Thanks for the info. If all difference is the long duration of charge in case of getting the 1 amp charger, then I will get it to charge my original 90ah AGM battery which already is at 12.8V. So it should not take more than a day hopefully.
04-19-2019, 07:16 AM | #17 |
Rep 15,966
With BMW I'd still go with 2 amperes. The reason for that is the same as the reason for using a battery tender: the electronics are never off. I haven't bothered to measure the current draw when the car is just sitting, but I know it's there. My 2A charger supplies the current that the car draws when sitting, with enough capacity left over to bring the battery back to a full charge after a short drive, even when temperatures drop below -10C. A 1A charger might do so as well, but since I don't have a 1A charger I can't say so from personal experience.
04-22-2019, 08:22 AM | #18 |
Rep 345
04-22-2019, 09:13 AM | #19 | |
Rep 3,926
NOCO's chargers don't seem to be able to supply enough amperage to be worthwhile although some of them are compatible with lithium ion batteries found in the M cars. |
04-22-2019, 12:14 PM | #21 |
Rep 345
I didn't pay 120 for mine, got it on eBay for quite a bit less. CTEK is the OEM for a lot of high end auto makers chargers, so that's why I went with them. They make some less expensive models as well that would work.
05-04-2019, 05:39 PM | #22 |
Rep 1,907
I have just bought a ctek msx 5.0 smart battery charger due to a battery message telling me to drive a distance for it to charge, I do around 4.5k miles a year & would like to know shall I charge & recon or just give it a normal charge?
Happy Motoring
Evdok |
Machinebuilder277.50 |
