09-08-2019, 08:31 PM | #1 |
Rep 6
Any chance BMW will activate full screen CarPlay for iOS 13?
Hoping to avoid going aftermarket activation for full screen CarPlay as my car is a lease; sounds like the aftermarket path is a bit more permanent.
Anyone think there is any chance BMW would activate full screen CarPlay for existing systems after iOS 13 releases? |
09-09-2019, 08:43 AM | #2 |
Rep 1,686
Drives: 2014 428i and 2018 X5
It doesn't matter what we think. We have no control over it.
09-22-2019, 08:51 AM | #4 | |
Rep 2,180
09-23-2019, 09:10 PM | #5 |
Rep 1,031
Drives: Like a bat out of hell.
iOS13 Carplay in my other vehicles allow split screen for navigation and music but it defaults to Apple map. It won't do that for Waze or other navigation app.
09-24-2019, 01:24 AM | #6 |
Rep 1,976
Drives: 2020 G20 320i M Sport
If you open your map version screen and it says N, O,P, Q or R after NBTevo_XXXXX it's possible to install a patch to enable Fullscreen Apple CarPlay through an aftermarket solution. Unfortunately, this is not available through official BMW channels.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
09-26-2019, 03:02 PM | #7 | |
Rep 394
Since i know if I change the very appealing "carplay fullscreen = aktiv" all I get is a stretched image not more real estate. |
09-27-2019, 07:55 AM | #8 | |
Rep 61
I believe what the patch does is modify one file that tells iDrive the screen resolution is higher. BMW absolutely could enable this via update, but their software update policy is "buy new car". |
09-27-2019, 08:48 AM | #9 | |
Rep 1,976
These aftermarket solutions access the QNX portion of the head unit and changes an INI file that manages the resolution of Apple CarPlay. Just coding fullscreen carplay to aktiv will only give you the result you describe.
dianebrat109.50 |
09-27-2019, 02:04 PM | #10 | |
Rep 2,180
The patch or coding only works if the firmware is updated to version N or later. So the firmware version does determine the CarPlay capability of full screen. That you have to code/patch it to work is another matter. No need to buy a new car.
09-30-2019, 07:53 AM | #11 |
Rep 61
Right - I was being somewhat facetious just to make the point that BMW will never enable this feature via official update, it will always have to be done by patch. Their view is pretty much if you want it, you can buy a car with iDrive 6.1 or whatever version has it enabled, even though that's completely arbitrary.
