05-24-2021, 09:01 AM | #23 |
Rep 5
If anyone get it solve, pls share
My 320i N20 have same issue that Misfire cyl2, change coil, good spark plug, check injectors, replace injector gasket, vacuum pump work well with no oil leak, boost solenoid valve still perform, compression test are 185+/-1 It still shake when load. No idea, anything else to check further |
06-25-2021, 05:13 PM | #24 | |
Rep 360
Stock or tuned? Have you read the ECU with ISTA and done any data logging? |
09-06-2022, 01:19 PM | #25 |
Rep 4
Drives: Bmw 428I Xdrive
I’m having the same issues but I changed the injectors plugs coil packs. But when boosting I still have the same result haven’t done a compression test but doesn’t misfire while idling. Any help is appreciated coded the injectors they were a (215) eu6 injectors so the correct injectors. I’m starting to think it’s a valve issue.
09-06-2022, 01:21 PM | #26 | |
Rep 4
02-06-2024, 01:51 AM | #28 |
Rep 4
n20 missfire issues
so it all started out as a misfire under load, i had inspected the spark plugs and had gotten plugs and coils, cylinder 3-4 are misfiring. on a cold start it would be fine, once you put any load above 2,500rpm the missfire worsens. compression tested all 4 cylinders dry=155psi wet=160psi. is there a way to clean the injectors?
Thank you for your help. |
02-28-2024, 01:00 PM | #29 |
Rep 2
Hi to all on this forum. I am from South Africa and love following you forum for the last couple of months now. I really need some advise on my BMW F30 328i. Hope to get some answers here.
