BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Steering wheel buttons and AC unit not working
      05-22-2021, 04:14 PM   #1
alpha_male
Drives: F31
Hi All
Need some help please. I was installing a reverse camera (non OEM) to my f31 and have now got problems with my steering wheel buttons.
The camera has a decoder that plugs into the quadlock that was connected to the NBT uhead unit.
I connected up the decoder but the idrive screen was blank so assumed i had done something wrong. So I put i back to how it was and now the screen etc is working but none of my steering wheel buttons are working and the climate control / heated seat / radio unit buttons do not work (does not power on).
So i cannot control the radio volume from the head unit nor turn on heated seats / ac / fan.
Additionally none of the steering wheel buttons work, neither horn nor does illuminate. Steering wheel stalks don't work either and wipers constantly on.
message on idrive about cruise control failure.
Checked various fuses but no luck.
I drive controller working fine.
I am sure it has something to do with me installing the reverse camera decoder but I haven't touched any of the steering wheel controls or harnesses. I dont have any diagnostic tools but if anyone has any ideas on what is causing this or what else to check I'd appreciate it.
Did a search and people talking about SZL and clock springs but i haven had the wheel off.
Odd the heater / radio unit wont power on either.
Thanks
      05-22-2021, 04:40 PM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
You probably can't diagnose the problem without an OBD diagnostic tool.
      05-23-2021, 05:34 AM   #3
alpha_male
Drives: F31
Thanks, that was my concern. So i opened up all three fuse boxes today and went through every fuse one at a time. Bonnet and trunk fuses all checked out - no issues.
Then decided to check FEM. Was a bit fiddly to get to but managed to get at it. First fuse i checked (top right when looking at FEM, 5A), was blown. So i yanked one of the interior light fuses out (think trunk) and replaced the blown one. Everything working again - wipers, steering stalk, steering buttons etc .
I have not been able to find a fuse layout for the FEM - does anyone have this ?
Now getting battery discharged messages but perhaps because I had doors open for some time and interior lights were on - lets see.
      04-19-2022, 06:25 AM   #4
agreennz
New Zealand
Drives: BMW F30 320D
��Thanks for this. Was suffering almost identical problem on f30 320D after installing replacement display with inbuilt CarPlay and reversing camera input. Symptoms are headlights on full beam, wipers on full time, cruise Control malfunction error on dash, and no indicators. Fitting was same with wiring into a new quadlock adaptor on the Alpine head unit
Will be checking fuse on FEM tomorrow
      04-14-2023, 05:54 PM   #5
mrjgonzalez
Drives: bmw 335xim
i have also encountered this. no steering wheel controls, no radio, no climate and wipers stay on. any fix for this?
      09-26-2023, 12:11 PM   #6
Sprinterman
Sprinterman's Avatar
Drives: F31 touring
I had this issue also after fitting an led ac climate control surround. The 5amp fuse blew in the FEM. Changed it and everything worked again, apart from the AC heating and the CD player, no display either, but it’s still blowing warm/hot air which is strange. Checked all the fuses but they all look good, I’m guessing the fuse is 20 or 10 amp but not sure. Any ideas? Don’t want to spend money at the dealers if I can fix it myself
Martin
      10-23-2023, 10:32 AM   #7
Sprinterman
Drives: F31 touring
Update, there was a loose wire at the back of the AC/climate control panel, where it had pulled out when I removed the panel, damaged pins, ordered new pins and repinned them. ISTA + had a lot of fault errors regarding the climate control, so I cleared them, all working properly now
Martin
      05-20-2024, 10:51 AM   #8
Kiet_tuan
Drives: f20 2013
Bmw f20 problem aircon buttons not work or any on the steringweel
I have same problem I just need to understand what do I need to do so I can fix it
      05-20-2024, 11:08 AM   #9
Sprinterman
Drives: F31 touring
If you removed the ac climate control panel, check the pins haven’t bent and are misaligned. If so just use a tiny screwdriver, like the ones you use on sunglasses etc to tighten the screw. Sounds like the fuse has blown, read my thread above. It’s the fuse box on the left passenger side for uk, left hand drive it will be the other side obviously. Pull the carpet away and you will see the fuse box. Check the 5 amp fuses
Martin
      05-20-2024, 12:06 PM   #10
Sprinterman
Drives: F31 touring
So you see the fuses,on the left hand side under the glove box, check the 5amp fuses, it’s likely one of the fuses has blown. Replace it and see what happens
Martin
      05-20-2024, 01:19 PM   #11
Kiet_tuan
Drives: f20 2013
How do i come into the box in the glovenox
      05-20-2024, 02:02 PM   #12
Kiet_tuan
Drives: f20 2013
I dont Think there os a fuse box in My glovebox i Got a f20
      05-20-2024, 03:22 PM   #13
Billfitz
Billfitz's Avatar
It's not in the glove box, it's in the kick panel near the glove box.
