02-22-2019, 08:25 PM | #67 | ||
Rep 765
02-27-2019, 01:56 PM | #68 |
Rep 235
Anyone know what would happen if the switch was omitted altogether? Would it default to always on or would it be possible to code the switch out so it is always on?
09-02-2019, 07:53 AM | #70 |
Rep 3
Hi guys,
I'm driving a F31 model with a manufacturer date 10.2016. I also want to retrofit the LCW and I have a question regarding the coding. Is it necessary to save the FA into the Car (VCM) for the initialisation of the flexray or is it enough to code only the LCW without a safed FA? Is it coincidence when an initialisation of the flexray failed via Rheingold? Because some guys had to activate the flexray port for the LCW separately via Tool32?!Or was it only a bug in Rheingold? Has the F31 always enough free Flexray Ports (The 5 series has depending of the euipment only 4 ports) ?? Thanks in advance |
10-29-2019, 02:19 AM | #71 |
E36fiend
285
Rep 637
Drives: 2014 435i xDrive
Anyone know what would happen if everything was installed except for the mirror electronics? Would the steering wheel still vibrate?
10-29-2019, 05:47 AM | #72 |
Rep 12
Hi guys,
I am going to retrofit this 5AG and also surround and side view cameras. I already collected most of the requested parts except cables and connectors. My biggest issue are the connectors now. I really do not know where are you looking for the order codes of the connectors. Even my BMW dealer was not able to help me. I sent him the picture of the connector that I need from TIS and I was told that they could not find it in the system. The reference numbers of connectors on TIS pictures are different from the BMW order numbers unfortunately. And then I open this forum and I finally found all connectors needed like 61138373630 including corresponding codes of pins... Realoem or similar online catalogues show the connectors greyed-out without the code. Could you tell me the secret where to find them? |
10-29-2019, 10:52 AM | #73 | |
E36fiend
285
Rep 637
Is that what you're looking for? |
10-29-2019, 01:20 PM | #74 | |
Rep 12
What is the part number of POS 2 and 4? https://www.realoem.com/bmw/en/showp...diagId=66_0338 |
10-29-2019, 01:28 PM | #75 | |
E36fiend
285
Rep 637
01-09-2020, 05:35 AM | #77 |
Rep 47
Hello, are there any cables / wiring needed from the mirrors to the FEM unit?
Mine are electronically controled, but non foldable. Last edited by RokasLTU; 01-09-2020 at 05:41 AM.. |
01-09-2020, 03:20 PM | #78 |
Rep 47
06-14-2020, 11:26 AM | #80 |
Rep 563
Do I need to Flash a used HC2 module
Roxxor. I liked your DIY and I understand you could not cover all the details.
Guys I know this is an old thread but help me out if you can. My 2014 F10 came from factory with Blind spot (HC2/SWW) installed. A few months ago it started acting up until it finally died. ISTA-d shows SWW in Red (ECU not responding). I picked up a master and a slave HC2 from a 2017 F10 (attached pics) and have a few questions (search did not answer these). 1. Could I get lucky by plugging in the used HC2 and they work 2. If not what do I need to do on a macro level to make them work. I have Esys and have done coding but not flashing - doing a Search gave me some guides on what to do on flashing. 3. Would I need to get the HC2 software to be compatible with my car by flashing 4. Would I need to also code it in some way to match specific values to my car like VIN etc.. 5. I imagine this would be the same process for most ECUs whether new or used? Again I am not looking for details just an overall sequence of what I would need to do. Thanks.
More power please
06-16-2020, 04:49 PM | #81 |
Rep 563
Done, was not had at all.
Following Shawn Sheridan: inject CAFD into ECU and VO Code it. Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on FEM_BODY => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level shown => Select OK => Right-Click on FEM_BODY (the ECU itself not the underlying CAFD) => Select CODE. The only thing I did additionally was to select "single flash" so that I could choose my Factory I-level and Target I-level. After finishing I ran ISTA-D and it had some errors for flexray initialization so I ran the ABL and now all modules are Green on the tree. Was looking at $2000 at the dealer, but only cost me $150 for the used HC2s plus my time. So happy for all the help you guys provide.
More power please
06-18-2020, 04:12 PM | #82 |
Rep 379
Can someone give pointers on how to source side mirrors? I don't see any in ebay with below features
heated BSD power folding auto dim auto tilt on reverse Thanks.
Click appreciate if this post has helped you
Retrofits: NBT evo ID6, 6wb cluster, heated steering wheel, HUD, Kafas2 with LDW, SLI, HBA, FCW and pedestrian warning, LCW, Surround View, Parking Assist and ACC with Stop |
07-05-2020, 03:28 PM | #83 |
Rep 379
Guys can anyone help me with below issue
Installing/Wiring the Driver Assistance Switch: - Locate the 54-pin Connector A173*7B on the FEM, and connect the 3 wires in the following pin slots: - Power (Red) to Pin Slot #37 - Ground (Black) to Pin Slot #39 - Signal (Yellow) to Pin Slot #38 The DIY guide says use pin 37, 38 & 39 on A173*7B connector. But in my car I see those slots are already occupied. Do anyone know which other system might be using those slots or those wire are lying somewhere unused on the driver side? if yes, how and where to find them? Just an FYI ... I don't have LCW or LDW from factory. Thanks in advance for the help! |
07-06-2020, 01:49 AM | #84 | |
Rep 533
07-10-2020, 08:46 AM | #85 | |
Rep 742
EDIT: Look at this photo...you see the bulge wrap in the middle of the wire? unwrap that and take a look there. https://i.ebayimg.com/images/g/jq8AA...L~/s-l1600.jpg
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) |
freespirit82.50 |
07-10-2020, 10:03 AM | #86 | ||
Rep 379
Thank you so much though
07-10-2020, 12:05 PM | #87 |
Rep 742
I did the same thing you did lol. Order the pins and connector kit from my local BMW for 15$, crimp them to the wires, ran them all when i went to check the FEM, it was already populated. Went back to the switch area and probably spent a good 30 minutes looking for that wire
07-10-2020, 05:02 PM | #88 | |
Rep 379
Now I'm in a similar treasure hunt for A173*8B pin 47 & 48 PT Can high and low used for Kafas2 ECU. I see they are prewired but donno where the other ends are hidden I can wiretap them but my OCD won't allow me :
5ag, blind spot detection, lane change warning, steelerfan |
