06-30-2021, 01:17 AM | #1 |
Rep 12
F30 Radio AM/DAB
Hi,
AM and DAB radio is not used in my country therefore I would like to code out/disable these options so they do not appear in the iDrive (and head-up), would anyone know the coding options for this purpose? Thanks |
06-30-2021, 10:42 AM | #2 |
Rep 12
I have successfully disabled DAB radio, however cannot disable AM radio. I have coded the following:
3002->RADIO_BAND_KW -> changed from aktiv to nicht_aktiv But the AM radio is still in the list of options, is there something else that needs to be coded? Or is it not possible? The firmware version is NBT_Evo_X. |
atzebmw588.00 |
07-04-2021, 02:52 PM | #3 |
Rep 12
Ok, finally solved it myself. Turns out it was not enough to disable RADIO_BAND_KW, it is also necessary to disable RADIO_BAND_MW, now the AM radio is no longer in the list of source options, but the FM radio is still present
atzebmw588.00 |
10-11-2021, 03:12 AM | #4 |
Rep 16
FM without RDS names
Hi all,
I managed to change the frequency from Japan to ECE using iPhone app BimmerCode, but my FM now without RDS names is there anyway to get the RDS names (channel name) to be present beside each frequency? Thanks You |
