08-09-2021, 11:29 AM | #1 | |
Rep 906
Recall 21V-586: High-Pressure Fuel Pump May Fail (N47, N57 engines)
Saw this posted on another forum, figured it deserves mention here.
BMW is recalling a large number of cars with the N47 and N57 motors for HPFP issues. It pretty much confirms what the common-rail diesel community suspected for years on the Bosch CP4 pump. Looks like we're all getting new pumps. Quote:
2014-2016 535d, 535d xDrive 2015 740Ld xDrive 2015-2017 X3 xDrive28d vehicles Good on BMW for doing this. AFAIK, this is first time a manufacturer has acknowledged an issue with the pump. The issue goes back to the late 2000s with VW TDIs having the HPFP cam and roller disintegrating and requiring a full fuel system replacement. For years, VW has tried to blame the failures on bad fuel or misfueling and going as far as recalling cars to affix more "Diesel Only" stickers and misfueling guards. However, VW never admitted to an issue with the pump itself. To put this in perspective, the CP4 pump as been used on many Ford, GM, Chrysler, VW, and BMW diesels, all have had similar issues.
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, M-Sport Pkg
2020 i3 Rex: Capparis White, Giga World Last edited by capt_slow; 08-10-2021 at 11:12 AM.. |
08-09-2021, 01:02 PM | #2 |
Rep 1,797
I saw this a few days back. Pretty good news for sure. 11,000 units seems kind of low...
My nearest local dealer is a disaster, so I'd have to plan this well. The latest updated pump is a good thing to have for sure. I'll try to get a bit more detail as to what will go in.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp -2016 Mini Cooper S, MT. Many plans. Others: -E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe. Last edited by Enabled; 08-09-2021 at 01:25 PM.. |
08-09-2021, 02:33 PM | #3 |
Rep 374
I bet we’ll see nothing of this in the UK…as BMW will probably claim our fuel quality is adequate enough to mitigate failures…we’ll see!
08-10-2021, 12:06 AM | #5 | |
Rep 906
What I am interesting in seeing is the SIB for this recall and see exactly what are the repair steps.
2020 i3 Rex: Capparis White, Giga World |
08-10-2021, 07:23 AM | #6 |
Rep 123
08-10-2021, 07:25 AM | #7 |
Rep 162
Hmmm. I'm within that range.
jeffijaffa3.50 |
08-19-2021, 09:09 PM | #8 |
Rep 421
Drives: 2017 F31 328dx
2017 328D and when putting in my VIN at BMW I’m not seeing anything either.
08-22-2021, 12:54 AM | #9 |
Rep 906
Give it another month. BMWNA wont be mailing the recall letters till Sept 20, 2021, so around then would be when specific VINs would be flagged in the system.
shiftdnb376.50 |
08-25-2021, 08:20 AM | #10 |
Rep 4
My 2017 328d just went full-time with an HPFP issue, it stalled and died on a road trip Sunday and again Monday morning. Check engine lamp is illuminated, and the drivetrain malfunction warning occurred both times. Engine fault 247500 and 247600 are present in Carly, and it idles a bit rough.
I spoke with BMW corporate and they did recommend I bring it in. I called my main dealer and mentioned my call to corporate and they pulled the active recall notice as applicable to my VIN. like others said, it won’t pull for you on NHTSA or BMW sites until after 09/20/21 when the bulletins are mailed out. Before I called corporate I did go ahead and update all contact info which helped both parties ensure the VIN and notice would go to the right address. I hadn’t received the EGR recall notice which I should also address next week when the car goes in. I think the abundance of B5 diesel in the midwest and high humidity has contributed to this, as the drivetrain warning has occurred at 42k, 53k, and 56k miles - but without further incident in those cases. I am at 60500 miles currently. If anything i’m hopeful that the timing of the recall and my engine issue is perfectly aligned so I get little or no bill and the problem is solved. I had planned on running this car to 150k, it was fine within warranty from new but this HPFP saga is disappointing. likely the last diesel vehicle I will ever own. Considering how ugly the iX and i4 are to me, probably the last new BMW I will buy for a long time. Keeping my E36 though and maybe getting an M2 CS.
'17 F31 328d, '14 Cayenne Diesel, '03 Boxster S
08-29-2021, 07:50 AM | #11 |
Rep 368
I wonder if it will be a recall on every model listed. 11,200 units doesn't sounds like it would every car in a 4 year span, covering 5 different models. Maybe they identified a certain lot number of pumps that they will recall. I just rolled past 185,000 on the clock... so I may be on borrowed time with something else breaking anyways.
I did proactively replace the HPFP around 100k though, so if I had an affected lot number, I may not anymore. Last edited by kdog_x; 08-29-2021 at 07:58 AM.. |
08-29-2021, 04:39 PM | #12 |
Rep 1,375
My 328D is booked in for service this week. We shall see if they have clue one about this when I speak to them. To be honest I'd sooner delay the service if my car is on the hit list and get it all done at once.
08-30-2021, 02:37 PM | #14 |
Rep 1,797
No, because the pump characteristics will remain the same. It will be a pump with different coatings on the cam and piston, to protect from corrosion and fuel contamination.
09-02-2021, 04:59 PM | #16 | |
Rep 4
The dealers were notified in late August, so all of them should know about it. With 11,XXX total diesel cars affected however, I am guessing enthusiast market dealers will be more responsive than those who primarily trade in higher-spec/M cars but it's in their systems at least.
09-12-2021, 06:42 PM | #18 |
Rep 906
Nothing on my car yet. Also looks like some affected cars will be given a 10 year, 100K warranty extension (from original in-service date) on the pump too.
09-14-2021, 12:05 PM | #19 |
Rep 6
Drives: 2013 X1 sDrive28i - Base - Blk
yep. but I already fixed it myself...
I had my HPFP go out on me this past February. BMW in Vista CA wanted $12,000 USD to replace the entire fuel system. I ended up figuring out how to fix it myself for about $4,500. I wonder if they will cover that cost? anyone know how this recall will impact owners previously damaged by the pump actually failing?
BMWjunge0.00 |
09-14-2021, 01:57 PM | #20 | |
Rep 123
(BMW of North America, LLC) If you have paid for the repair described in the attached letter, and you would like your expenses to be considered for reimbursement, please contact your authorized BMW center. Expenses paid to repair facilities outside of the BMW center network will be considered; however, the repair procedure must meet BMW standards. Your authorized BMW center will request a copy of your owner notification letter, as well as your previously paid invoice. They will then inspect the vehicle (if it is still in your possession) prior to submitting a claim on your behalf to BMW of North America, LLC for reimbursement. Please note the following: •Only a repair that is the subject of this safety recall is reimbursable. Consequential expenses such as towing, rental, accommodations, damage repairs, etc will not be reimbursed. •The Manufacturer’s Suggested Retail Price (MSRP) for BMW Genuine Parts will be considered as the guideline for reasonable part charges. •Repair labor, taxes and hazardous waste disposal, when previously paid, are eligible for reimbursement. •Expenses for repairs performed more than 10 days after the date of the last owner notification letter sent by BMW are not eligible for reimbursement. Your authorized BMW center should be able to answer any questions that you may have regarding your qualifications for reimbursement of a previous repair. If you qualify for such a reimbursement, your BMW center will also be able to advise you of the manner in which you can expect to receive reimbursement. Your authorized BMW center should be your primary contact on this issue; however, our Customer Relations and Services Department may be contacted at 1-800-525-7417 for any special assistance that you may require. In special situations where your authorized BMW center cannot be of assistance, you may submit your written request for reimbursement to: Customer Relations and Services Department BMW of North America, LLC P.O. Box 1227 Westwood, NJ 07675-1227 If you intend to submit a request for reimbursement to our Customer Relations and Services department, your vehicle (if it is still in your possession and was repaired at a facility outside of the BMW center network) will need to be inspected at an authorized BMW center before a claim can be accepted for consideration. This is to ensure that prior repairs at an outside facility meet BMW standards for recall completion. |
BMWjunge0.00 |
09-23-2021, 10:59 PM | #21 |
Great Teacher
1076
Rep 1,303
Drives: 06 e91 325ix
Still nothing on my 09/14 build date f31d.
Wonder if there were certain batches of pumps only that are targeted.
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
BMWjunge0.00 |
09-24-2021, 08:09 AM | #22 |
Rep 368
I am still curious as to what exactly is different in new pump. Heard a mention of improved coating materials on the roller and other components. Wondering if there are any additional updates. Anyone privy to that information by chance?
BMWjunge0.00 |
