10-05-2021, 11:33 PM | #27 |
Rep 906
My VIN is still clear of any recalls according to BMWUSA's website. I'm really interested to find out if this really is a bad batch of pumps or what.
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, M-Sport Pkg
2020 i3 Rex: Capparis White, Giga World |
10-07-2021, 06:27 PM | #28 |
Rep 1
Best news!
This is the best news! My 2014 BMW 328d was out of commission for about 7 months while they replaced fuel pump after fuel pump. Fuel injector after fuel injector. Turned out it was the HPFP, it's just that the shards of metal were not detectible after it blew out the entire fuel system. $9,000 later I finally got it back in June of this year. I'm hoping BMW doesn't give me too many problems about reimbursement. I've never seen BMW techs so stumped.
Has anyone had any experience trying to get a repair replacement after a recall was issued? I also had the CVJ joint go out on this one. It was right after they had issued the recall about 2 weeks prior. But letters hadn't gone out yet or anything. BMW was absolutely awesome in handling the situation in that case. So I'm hoping this will be the same. I will say - definitely get that HPFP fixed. It was a mess to fix once it went out. And there are some good 1 micron external particulate fuel filters that exist now, that I HIGHLY recommend as well. |
BMWjunge0.00 |
11-29-2021, 10:19 AM | #30 | ||
Rep 313
In one of the links, they had a breakout of cars affected: 328d Sedan, 2014-2018 - 2,773 affected 328d Wagon, 2014-2018 - 1,333 535d Sedan, 2014-2016 - 509 740Ld Sedan, 2015 - 13 X3 28d, 2015-2017 - 199 X5 35d, 2014-2018 - 6,389 (!) Recalled Components: – part number – 4-cyl. (7810696), 6-cyl. (7283473) Owners who have had this remedy performed at their own expense prior to the recall notification may be eligible for reimbursement according to BMW Group’s reimbursement plan in accordance with 49 CFR 573.13 and 49 CFR 577.11. |
BMWjunge0.00 |
11-29-2021, 02:31 PM | #31 |
Mini Cooper, Present F15 Owner
Rep 90
I had bought O2 sensors before I had the recall/extended warranty work done for the DEF pump issues. They replaced the O2 sensors along with the pump and other work at BMW's expense. I hadn't installed the new ones I had bought yet but I couldn't return them (a no-no on Amazon.com for electronic devices). So, if I keep the car long enough to need new O2 sensors, I've got 'em sitting on a shelf. I don't see my VIN number in the recalls yet (2015 model - built 11/14) and I would expect this vehicle will fit the criteria.
I will be very, very happy if they replace my HPFP under a recall or even an extended warranty. I've got 77K on my wagon and after all it's been through with the emissions system (and the guibo/transfer case issues) it would not surprise me if this went, too. Last edited by Chukker; 11-29-2021 at 02:35 PM.. Reason: incomplete response |
BMWjunge0.00 |
12-09-2021, 12:29 PM | #32 |
Rep 3
Dealer replaced HPFP
'17 328d, F31.
Dealer installed pump #13517824477. Don't know if it is the same old pump spec as original, or if it is a new for low-sulfur-US-diesel design. Using stanadyne lubricity anyway. |
12-09-2021, 05:21 PM | #33 |
Rep 59
I wonder if I'd still be able to take advantage of this since my 328d is deleted and tuned and 151k miles. I've already replaced the pump once..
Edit: 2014 328d, I guess my vin isnt effected anyway, just checked on the website and it says 0 open recalls Last edited by Morrob95; 12-09-2021 at 05:27 PM.. |
BMWjunge0.00 |
12-10-2021, 12:33 AM | #34 | |
Rep 906
New pump is 13517824477
12-22-2021, 09:31 AM | #40 |
Rep 229
So I contacted my BMW advisor. My 2014 has a extended warranty for the hpfp if in any case if it goes out. This should back us up until the recall is readily available.
12-22-2021, 10:03 AM | #41 |
Rep 1,800
The HPFP isn't simply waiting to go out, they are susceptible to contaminants. That's what this latest recall is focused on, one internal component that is getting an update, for cars that have the pump with that variant inside.
It's not a general HPFP recall. It's likely selected by serial numbers.
BMWjunge0.00 |
12-30-2021, 05:21 PM | #42 |
Rep 421
Drives: 2017 F31 328dx
I got a message on my trip home to see family for Christmas that the remedy was available through my infotainment system. I need to make an appointment.
01-02-2022, 08:43 PM | #44 |
Rep 421
BMWUSA if you have a profile set up there or you can use a site like https://vinrcl.safercar.gov/vin/
