BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N47 and N57 Turbodiesel Engine / Drivetrain / Exhaust Modifications > 328d High Oil temps
      09-12-2021, 01:34 PM   #1
Esthedikf30
Drives: 2014 328d
328d High Oil temps
Hello
Before I go and spend the money, does anyone know if high oil temps can be because the water pump or thermostat are going out? or can it be another issue
please help if you ran into this problem
thank you in advance.
      09-12-2021, 05:34 PM   #2
Enabled
Drives: 328xd Wagon, M2 Competition
Can you describe a little more as to what is going on? We need a lot more info.
Also why do you believe your oil temps are so high? If your oil temp is high, what is your coolant temp like?
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp
-2016 Mini Cooper S, MT. Many plans.
Others:
-E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe.
      09-12-2021, 06:11 PM   #3
Esthedikf30
Drives: 2014 328d
Yesterday the oil temp needle reach the 3/4 line (250-260F) and prompt a warning. The car was recently leaking water from the Pipe Union on the water pump. I fixed that and bled the cooling system. I have no existing leaks anymore. Drove the car on 90 degree weather through LA traffic, the temp went up and kicked in the fans for the oil cooler.
Regarding the coolant temp, I am not able to check unless I have an OBD2 scanner.
      09-12-2021, 10:43 PM   #4
eugene89us
Drives: 2018 BMW 328d
I believe you can see coolant temperatures through the "secret menu" on the dashboard screen. Instructions are online, including how to get your code to unlock the menu (based on your VIN). Simple to access with long press of the dash button.
      09-12-2021, 11:42 PM   #5
Esthedikf30
Drives: 2014 328d
Okay I will give that a try. Im guessing if my coolant temps are high, I'm having some water pump or thermostat issues.
      09-13-2021, 05:24 AM   #6
opinion914
Drives: F31 N47
Is there a separate thermostat for oil (not engine coolant) in the oilfilter housing?
      09-13-2021, 10:18 AM   #7
capt_slow
capt_slow's Avatar
Drives: 2017 F31 328d
YI fixed that and bled the cooling system.
Out of curiosity, what was the exact process you used to bleed the system?
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, M-Sport Pkg
2020 i3 Rex: Capparis White, Giga World
      09-13-2021, 05:07 PM   #8
Esthedikf30
Drives: 2014 328d
I filled the expansion tank, let the car run and warm up, then I opened the bleeder screw for about 30-40min.
      09-13-2021, 07:03 PM   #9
capt_slow
capt_slow's Avatar
I wonder if there is an air pocket somewhere in the system that is causing the temps to go up. The coolant system is supposed to be vacuum filled and I'm not sure the procedure you used would be an acceptable alternative.
      09-13-2021, 09:39 PM   #10
Esthedikf30
Drives: 2014 328d
I inspected the car again today and found a new leak. I didn't see this one when I initially fix the first leak.
BMW Connector - Genuine BMW 11127810707
This is where the leak is coming from.
Thank you for all the help, after I replace the part i will take it to the dealer to get the coolant vacuum filled.
      09-22-2021, 12:14 PM   #11
n00bkiller944
Drives: '14 328d M Sport
Not sure you need to vacuum fill. I believe you can crack those bleeders and run the electric water pump with a scan tool to bleed. Do a bit more research but I am sure it can be a DIY
      09-22-2021, 11:26 PM   #12
capt_slow
capt_slow's Avatar
Isnt the water pump on the N47 mechanical and belt driven?
      09-23-2021, 09:05 AM   #13
dreaming.haze
Drives: 328d xDrive wagon
capt_slow - Correct on the mechanical driven water pump. You will need to bleed the old fashioned way with getting things up to temp and refill OR vacuum fill things to circumvent that process.
      09-23-2021, 09:56 AM   #14
andreigbs
Dr Drei
Drives: X3d
'16 X3d  [0.00]
I'd also recommend setting the heater fan on max heat while refilling. You need to purge all air out of the system, which includes the heater core.
GLK 250 // 126xxx miles // 36 MPG // Mobil1 ESP 5w30
