06-17-2015, 10:55 AM | #23 | |
Car OCD
263
Rep 595
Drives: 2017 EBII F36 430d M Sport
I do not have a square setup for now, but I may go for one for the track. I'll take a look at the AZ thread with delight. I have been active on AZ a few years ago and enjoyed modifying my S4: http://www.audizine.com/forum/showth...r-Gray-Project . After several months, and being about to take it to the track, I test drove a Cayman R and could not resist to its appeal.
2017 BMW F36 430D M Sport Estoril Blue, 2002 E46 M3 Imola Red & 2006 Porsche Cayman S Artic Silver
More about my ride @ ATLBlue's 2014 F30 Journal. Instagram Inline6_ATL |
06-18-2015, 08:30 AM | #24 | |
Rep 1,730
I would switch into a cayman on a dime if it didn't have the negative connotation out here. There are so few nice cars around where I live/work that people assume a Cayman is as exotic as a Lamborghini. It's already bad enough with 4 rings.
UNDRSTR
06-18-2015, 09:59 AM | #25 | |
Car OCD
263
Rep 595
Enough threadjacking, let's go back to the track
06-19-2015, 07:37 PM | #26 |
Car OCD
263
Rep 595
Repeat post from my journal, but thought I might as well do it in the tracking forum...
Track pics orgy Not sure how much is too many... so I am posting a lot of pictures of my track weekend at Barber Motorsportspark
06-19-2015, 07:39 PM | #27 | |
Car OCD
263
Rep 595
You stated:
07-11-2015, 03:52 AM | #29 | |
Car OCD
263
Rep 595
07-19-2015, 03:13 PM | #30 | |
Rep 1,363
Enjoyed your post btw Last edited by casualDIYer; 07-19-2015 at 03:20 PM.. |
07-21-2015, 12:26 PM | #32 | |
Car OCD
263
Rep 595
This, combined with slightly wider front tires and using a firmer setting for rear coilovers has definitely reduced understeer.
07-21-2015, 02:50 PM | #33 | |
Rep 10,509
What do you think of going to zero toe for the front? |
07-21-2015, 06:59 PM | #34 | |
Car OCD
263
Rep 595
I already gained a bit of negative camber when I lowered the car and the F8x control arms are about 10mm longer than the F3x, so it is conceivable that the combination of the F3x parts + F8x control arms gives more negative camber than a complete F8x suspension that also has other F8X specific parts. I have been satisfied with a bit of front toe out and the car still feels perfectly stable at high speed. This being said, I have only been to Atlanta Motosportspark and Barber Motorsportspark with the F30 and they are lower speed/curvy tracks. Maybe zero toe or even a bit of toe in would be beneficial when I go to Road Atlanta (faster, more high speed slight direction changes). Now to be honest, I do not have a lot of expertise in alignement and rely on my local tire shop that works on a lot of track cars
07-21-2015, 07:58 PM | #35 |
Rep 10,509
07-23-2015, 09:42 AM | #36 | |
Rep 1,730
Center tread depth is 8/32". My events are all run clockwise (which I assume is pretty normal) so some of my inside tire wear is very low I will probably get the tires flipped and remounted backwards (the ZII is directional) so that I can chew up the other side Not that it helps since the car is different, but here's my alignment sheet (keep in mind I have front camber correction with adjustable upper control arms).
UNDRSTR
08-13-2015, 08:05 AM | #37 |
Rep 518
For what it's worth, I just returned from NJMP with my 328i (RWD, non-DHP) and was pleasantly surprised by the lack of understeer exhibited with a square 245 tire setup and Dinan springs. No other suspension modifications.
2003 M3 | SMG | KW V1 | Apex ARC-8s | 3.85 LSD | Cobra Nogaro | S2R Tuning Sunroof Delete | Billy Boat Section 3
08-17-2015, 08:27 PM | #38 | |
Rep 10,509
Those pics look a lot like dunlop ZII tires, and that also makes a difference in terms of compound/wear. I'm switching to RE11 on my F80, hopefully I will get more life out of the tires, and if not, will add camber I'm hesitant to make many more changes since Randy Ppbst posted up that 1:32:XX lap during a recent magazine comparo on a completely stock F80 M3 at big willow. Why bother making changes if I'm still so far off the pace? Part of the issue is that my attachments aren't bronzed enough to fully commit in T8/T9 on greasy/squirmy PSS tires.. clear sign as to why he is a pro and i'm an avg joe |
08-18-2015, 03:24 PM | #39 | |
Rep 1,730
And regarding pobst...yea...he also gets to destroy other people tires and not give two fucks about rotating them or having the discount tire guy scuff the wheels. He gets to just move on and take a 991 GT3 RS out there the next time... So with that said, my tire choice is primarily for longevity, cost and then performance last. If you really wanted to kill lap times, then running some hoosiers or pirelli slicks would probably be the short term drug. But running street tires will help you long term to become a better driver
UNDRSTR
08-19-2015, 09:18 PM | #40 | |
Rep 10,509
I was super disappointed to be almost cording the front PSS on my F80 after a handful of DEs, when the ZII on my Z435 were barely worn after the same number of events. Both cars stock and similar weight |
09-24-2015, 09:13 PM | #41 |
Car OCD
263
Rep 595
Uneventful trackday at Atlanta Motorsports Park.
I'll do something about my tires eventually. I ran both the Michelin PSS and the stock Potenza. The PSSs were consistently about 1s quicker while the Potenza felt more planted and easier to control. I will look into something different when the time comes to replace one of the sets... Short video... with music to cover the wind noise.
10-07-2015, 12:02 PM | #42 |
Rep 749
Drives: 2016 528i Executive Edition
Love this thread. Thank you for sharing!!
I hate that up here in the PNW, we can't have track days throughout the year (well, i'd prefer to only go on non-rainy days). Makes me wish I lived down in California where track days all year round are the norm... |
11-01-2015, 03:07 PM | #43 |
Rep 937
It's nice to see that the Msport can take the heat, I was worried about the oil also. I guess thinking about it more... on the Msport cars aren't those oil coolers on each side where the fog lights would normally be?
I might take my 335 out for a single day and see how the performance BBK holds up with the stock pads. Also aren't there any PFC 01 or 08 that will fit the calipers?
F80 M3-DCT MaxPSI CH, BM3 with F80 Paul E85 and Custom Rom track tune MCS 2Way Remotes
Signature SV104 E46 M3 F85 X5M https://www.instagram.com/fastmacm3/ |
11-01-2015, 11:17 PM | #44 |
Rep 766
My 328ix at Lime Rock back in September. I did three track days this year, Thompson, Lime Rock and finished the season Saturday at NH Motor Speedway. Car has the stock 330mm P337A brakes. Less than ideal but I upgraded to stainless brake lines, Hawk 5.0 pads and Motul RBF 600 fluid. I've also run the Hawk Street Race pads but the dust and noise were unbearable those stopping power was mind boggling. The Hawk 5.0 pads have been fantastic trading some stopping bite for little dust and little noise. Lime Rock and NHMS are relatively easy on the brakes with plenty of time to cool between braking zones but experience no fade at either with this setup. I'm currently running 255/40/18 PSS square and have been quite happy but may look at going to a dedicated track tire and keep the PSS street only especially as I anticipate doing far more than three track days next year. The car is lowered on DINAN springs but no other suspension mods have been made. Now besides just craving more power the number one issue on the track I've been having is with bouncyness. The car overall is pretty planted but the rear end can get a bit squarely/bouncy on some bumps. There is no lip spoiler on the trunk and I do plan on adding one but wondering what else should I consider? Bilstein HD's maybe?
Well weathered leather, hot metal and oil, the scented country air.
Sunlight on chrome, the blur of the landscape, every nerve aware! 2014 328ix EBII - Sport AT, Light Pkg, Blk Dakota, Moonroof, Navigation, Heated Seats, HK Audio, Driver Assist, Sport Pedals, Dinan Springs, Bilstein B8s, M-Performance BBK |
