12-27-2019, 06:40 PM | #1 |
Rep 2,354
Michelin Cup2 - initially disappointed...
Hi
Just changed to Cup2 from AD08R and I feel the car is all over the road while braking hard. This was not the case at all with the AD08R. I assume this is because of the softer tire wall? Grip is great but that wobbly floaty feeling - also during quick lane changes........I am disappointed to be honest. I am running factory spec 225 and 245 section on 7.5J and 8J wheels. Can something be done with tire pressure? I am not tracking the car at the moment so what would you recommend for pressure for normal/fast street driving? Thanks
(A Dane in China) |
12-27-2019, 08:07 PM | #2 |
Rep 465
Are you driving 135i? If yes, you need camber plates for negative camber,
I tracked 135i for 6 years and in stock form that car was understeering like a bus. I never used these tires but I hear they are very good when pushed hard. Sticky tires need negative camber, especially on that car. I was running -3.5 front and -2 rear plus other suspension upgrades and only then I was able to use sticky tires and get all the benefit they provide. If you are not tracking your car you are wasting really good tires. For the street I would recommend bridgestones re 71 R tires. Hope this helps
"Racing is life. Anything before or after is just waiting." Steve MCQueen
zinner559.00 |
12-27-2019, 09:43 PM | #3 | |
Rep 2,354
Will added camber help on the floaty steering and breaking feel?
(A Dane in China) |
12-27-2019, 10:09 PM | #4 | |
Rep 465
Sticky tires added to soft suspension will only make things worse.
12-27-2019, 11:12 PM | #5 | |
Rep 1,597
Polo088161605.50 |
12-28-2019, 05:31 PM | #6 |
Rep 16
Drives: BMW 325d f31
Never drove ad08r but I had cup2 and there are very good if warm, what is Your tire temp? I noticed that they just start to grip around 40C and when they reach 60C they're doing great. They don't grip at all when cold in daily driving situations.
12-28-2019, 08:52 PM | #7 | |
Rep 3,943
12-30-2019, 12:37 AM | #8 |
Rep 2,354
Listen...
I am NOT interested in track use feedback. I experience this in situation driving on the street. Examples: Fast lane changes and especially braking hard from around 200kmh.
(A Dane in China) |
12-30-2019, 02:45 AM | #9 |
Rep 2,354
To prove my experience... Guess there is nothing to do about that. I suspect the tire wall is so soft because these tires are primarily used on super cars with 20-21" low profile (take 911 GT3 as an example). A stiff sidewall would remove any sort of comfort.
(A Dane in China) Last edited by harkes; 12-30-2019 at 03:44 AM.. |
gmx166.00 |
12-30-2019, 07:35 AM | #10 |
Rep 3,943
01-06-2020, 12:22 AM | #11 | |
Rep 143
01-12-2020, 08:07 AM | #12 |
Rep 1,127
I saw mention of a RE71R as a street tire and I would like to toss in my two cents on that tire.
1) it's loud, transmits all the road into the cabin. 2) It's is not a good tire for the rain, hardly any tread. 3) It needs temp to be at it's best, otherwise it's on the hard side. I use these tires on the track and Pole Position S-04 on the street. The S-04 is a nice tire for the street with some grip. |
harkes1075.50 |
01-12-2020, 09:16 AM | #13 | |
Rep 2,354
(A Dane in China) |
01-14-2020, 12:20 PM | #14 |
Rep 3,185
RE71R is an amazing street tire. I ran it on my E90 for over 40k miles. For the dry traction it is very good in the wet. Only time I had to be cautious was with standing water. You need to keep the tire pressure around 35psi to keep heat, but it heats up fast.
01-14-2020, 04:30 PM | #15 |
Rep 1,127
What wheels are you using with that tire combo?
01-14-2020, 07:41 PM | #16 | |
Rep 3,943
You got over 40k miles from the same set of RE71Rs? |
01-14-2020, 10:58 PM | #17 |
Rep 3,185
01-14-2020, 10:59 PM | #18 |
Rep 3,185
01-15-2020, 08:25 AM | #19 | |
Rep 1,127
I am using Apex ARC-8s with that tire and I drove 5 hours to Road Atlanta on them and it was not as enjoyable as a more street oriented tire would be. I was wondering if maybe the NVH issues came from the tires or the wheels. |
01-15-2020, 12:50 PM | #20 | |
Rep 3,185
01-29-2020, 11:54 AM | #22 |
Rep 5,506
This is my experience from tracking my M3.
I ran 4 sets of AD08R before, they are good tires. Going to Cup 2, the cup 2 has very soft sidewalls compared the to the Yokohama tires. You should be running a higher tire pressure and more negative camber to compensate for it. I changed to Yokohama Advan A052. Much better track tire than AD08R or Cup2. I'm averaging 1-2 seconds faster over the Cup 2 on a 2 min track and it lasts longer. Compared to AD08R, it's a bit softer sidewall but a lot more grip. A052 also is strangely very quiet on the street if you want to drive it normally. It is just as quiet and civil as the AD08R.
Auto Detailing Enthusiast!
Solidjake945.00 |
