09-24-2018, 04:36 PM | #1 |
Rep 512
Drives: 320i M Sport Shadow Edition
TPMS iDrive Display
Hi All,
My new car 320i 18 plate has ID6 and TPMS which I've not had before. I reset my tyre pressures as 1 had dropped below the threshold and after the reset the Bar Pressure on each tyre was shown but the values are lower than what I got from my manual gauge.
Jason |
09-25-2018, 01:51 AM | #2 |
Rep 3,860
1. Mine is pretty accurate and reflects pumped pressure. I suspect your manual gauge isn't good...
2. Yes, you can, but you need to code it. It is nothing you can enable from the menus.
jbeer154.50 |
09-25-2018, 02:15 AM | #3 |
Rep 512
Thanks for that, I have some other coding to do so will add it the list
09-25-2018, 10:42 AM | #4 | |
Rep 3,967
Mine are usually within 1bar of what my digital compressor shows. |
jbeer154.50 |
09-25-2018, 02:15 PM | #6 |
Rep 512
Update: borrowed a friends digital tyre inflator and the pressure display matches the car so my trusty gauge is off 😢 time to go shopping for a new toy 😃
09-25-2018, 05:59 PM | #8 |
Rep 512
09-26-2018, 02:02 AM | #9 |
Rep 13,043
Drives: BMW M340I G20
The last two cars I've had the pressure shown in the idrive is 2 PSi lower than a couple of accurate gauges I have.
Current car.M240i. Previous.MINI JCW. E92 325i. 435d M235i.M135i. 635d Coupe, E92 M3 manual, E92 M3 DCT Competition Pack. E92 335i, Porsche Cayman S Gen2, 135i Coupe. E92 320d, MK5 R32. MK5 Golf GTi,MK5 Golf GT-TDI,E46 318Ci. |
jbeer154.50 |
09-26-2018, 02:04 AM | #10 |
Rep 512
Mine are now spot on between the car and 2 different digital gauges
09-26-2018, 09:50 AM | #11 | |
Rep 2,511
Three wheel sets presently with TPMS. I go for 0.15 Bar over by compressor, then deflate, if required, using the above gauge to 0.05Bar over by the gauge and cold temperatures by TPMS are still 0.1 Bar low. However, the cars drive best like this and tyre wear is even.
Driving i4 M50 (G26)
Previous 340i Touring MSport (F31) |
09-26-2018, 10:33 AM | #12 | |
Rep 13,043
09-26-2018, 10:50 AM | #13 | ||
Rep 2,511
340i Touring as door card +0.05 Bar. Michelin Digital Gauge has a resolution of 0.01 Bar. Winters are 18's and square. So, running with F2.25 R2.65 Again 0.05 bar over the door card. The 0.05 bar just gives a little grace for the cooler days and helps stop the run flat cold tyre bumpiness. Wife's Mini has go-flats. But, the same +0.05 Bar seems to be beneficial.
