BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F34 3-Series GT (Gran Turismo) Forum > New wheels and springs.. what's best?
      07-25-2021, 02:41 PM   #1
HailCezarGT
Drives: BMW 328i GT
New here. Want to put wheels in my new purchase 2016 328i GT. Would love 20" wheels and obviously lowered. But will settle for 19" lowered if it rubs. What do U guys suggest for lowering springs? also 19" staggered like 19x8.5 front 19x9 rear. I just can't stand rubbing. I did it with my last car and I went thru 7 tires in two years. Please help
      07-25-2021, 06:01 PM   #2
admranger
Retired Curmudgeon
admranger's Avatar
Drives: ‘19 X3M40i, ‘18 m550i
I have always liked the Eibach pro kit springs on my cars. I don’t have them on my E34 though.
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS
      07-25-2021, 10:15 PM   #3
Call me the breeze
Drives: 2018 BMW 430i Msport
If you have xDrive which I assume you do if you are in the US, staggering and lowering more than 1" are a no no
      07-25-2021, 11:20 PM   #4
HailCezarGT
Drives: BMW 328i GT
Why is that? Bad roads? I'm in FL roads here are great.
      07-26-2021, 09:54 AM   #5
Velocifero23
Drives: 2015 335i GT
Curious as well as I am looking at wheel set ups currently.
There seems to be a lot of back and forth with what is acceptable with this car.
      07-26-2021, 11:46 AM   #6
shiftdnb
Drives: 2017 F31 328dx
Plenty of people with Xdrives are driving staggered and lowered with Eibach and even H&R springs. What you don't want to be is more than 1% difference in diameter of your wheels and I believe the number for drop is you don't want to drop the car more than 1.5" because of the CV axle. When you lower the car it changes the angle of the axle and they can snap on a bump.
      07-26-2021, 10:22 PM   #7
Call me the breeze
I guess it depends on what you mean by staggering. If you mean different size wheels and tires between the front and back, that is bad. However if you are only referring to width, that is possible but also has its challenges.
For the xDrive to operate correctly the outside tire diameter has to be identical so that the transfer case can distribute power correctly. If all 4 wheels are 20"s and you run 9" width in front and 10" width in back, that is fine if you match the aspect ratio of the tires to achieve exact diameters. That is not always the case so you have to get the technical data on the tires to be sure. The other challenge is long term wear. With 4 matching tires, they can be rotated to maintain even wear. With staggered tires the fronts and rear cannot be switched. The primary drive wheel (rear) will wear faster so it is essential to monitor tire diameter over time to not destroy the transfer case. Here is a video on staggering on an xDrive. It can be done as long as you check all the boxes.
Lowering also requires attention to detail. The front axles have extra drive shaft components that take up room and have to maintain a certain alignment and camber with the control arms. That is the primary reason xDrive cars ride a little higher than non-xDrive. I've read a bunch of articles that say 1/2" lower is good to go. 1" or greater and the front drive wears prematurely.
xDrive is a really advanced design but it does have its limitations when it comes to mods.
      07-27-2021, 10:07 AM   #8
rambleon84
Drives: 2015 f34 GT 2013 Focus ST
I've been happy with AC Schnitzer springs, running stagger 19s in summer:
View post on imgur.com
      07-27-2021, 11:04 AM   #9
HailCezarGT
Drives: BMW 328i GT
It looks perfect.
      07-27-2021, 11:05 AM   #10
HailCezarGT
Drives: BMW 328i GT
Thanks for the info. Also, I meant the tire width not different size wheels. I might do HR springs and 19x9 or 19x10 all around
      07-27-2021, 05:12 PM   #11
HailCezarGT
Drives: BMW 328i GT
I'll post pics once done. I'm thinking about two weeks max
      07-28-2021, 07:44 AM   #12
Gran_Turismo
Drives: 328i GT M Sport
Does anyone know if we can run the rear 598m 19x9 ET42 wheels as a square setup? Would they work fine up front as well? Thanks
