10-02-2021, 06:19 PM | #442 |
Rep 430
Not read through the whole of this thread. So apologies if this has been asked before.
Some are using 245/35 and 265/35 tyres. What pressures are you running for non run flats? I am running 36psi all round on my 330d at the moment, but find the ride a little harsh over bumps. About the same as the run flats I was using before. I was expecting a slightly softer ride. Thanks in advance |
10-05-2021, 05:55 PM | #443 |
Rep 379
Any experts out there to advise on how did you install 245/35 and 265/35 without poke on f30? Lowering the car? Negative camber etc?
Click appreciate if this post has helped you
Retrofits: NBT evo ID6, 6wb cluster, heated steering wheel, HUD, Kafas2 with LDW, SLI, HBA, FCW and pedestrian warning, LCW, Surround View, Parking Assist and ACC with Stop |
10-05-2021, 08:19 PM | #444 |
Rep 274
The tires themselves can also be a factor. If you compare the same tire sizes across multiple manufacturers, you will see that the section and tread widths will vary. As an example, I replaced my two rear 285/30/20 MPSSs with 275/30/20 Falken FK510s, and the Falkens are slightly wider.
freespirit81.50 J555567.00 |
10-20-2021, 09:52 PM | #446 | |
Rep 143
Car appears to be in immaculate condition....just tint via wrap overlay or paint match the front (orange) side markers, which will allow the eye not to be distracted by it & will uniform the entire look - - even more!! |
10-20-2021, 09:55 PM | #447 |
Rep 143
10-21-2021, 11:13 AM | #448 |
Rep 4
These are the OEM 437M, so the fronts are 9" and the rear 10". No need for spacers at all, they are as agressive as they can be.
11-11-2021, 05:02 AM | #449 |
Rep 296
Anyone running these on a bagged car ? Wondering if the fronts and rears will both tuck when aired out.
Also concerned about inner clearance as my OEM 442M tyres (225/40) are very close to the bag on the front, running a 5mm spacer on an 8J ET36 for a final offset of 31 437M is 9J ET29 which will give slightly less inner clearance again. I'd rather go OEM over the less aggressive replicas though just for overall strength and lightness. Last edited by _baz; 11-11-2021 at 05:07 AM.. |
11-12-2021, 03:45 PM | #450 | |
Rep 166
11-12-2021, 03:47 PM | #451 | ||
Rep 166
11-12-2021, 03:48 PM | #452 | |||
Rep 166
11-16-2021, 03:48 PM | #454 |
Rep 3,179
11-17-2021, 08:59 AM | #455 | |
Rep 296
I believe the OP used his OEM tyres: 225/40 front 255/35 rear and didn't have an issue from what I've read. From reading specs on certain tyre brands 225/40 falls within the suggested range for a 9" wheel and 255/35 can be fitted to a 10J Only issue I would be a little concerned about is if you used run flats as the stiff sidewalls may not flex as much as a regular sidewall. These are probably the sizes that ill be going with on mine. More clearance and less chance of scrubbing. Plus the added benefit of using them on my 442M if I decide to switch wheels back to stock and i can then throw the horrible run flats in the bin. |
Bens3000.00 |
11-17-2021, 09:27 AM | #456 | ||
Rep 64
11-17-2021, 10:17 AM | #457 |
Rep 2,146
Drives: F80 M3
I ran firestones on mine and they were a great sticky tire, great value for the price.
Instagram: http://instagram.com/e90nate
Bens3000.00 |
11-17-2021, 08:23 PM | #458 |
Rep 3,179
If you actually did, your front tires will be 25" and rears 27" diameter. Fronts probably won't have enough sidewall to stretch it on to the 9" rim. Not only will it look horrible but will be harsh over every pebble.
Bens3000.00 alohasurftoad3007.50 |
11-18-2021, 07:47 AM | #460 |
Rep 2,146
Drives: F80 M3
I ran the factory 225/40/19 front and 255/35/19 rear it was great with a slight stretch
11-18-2021, 09:04 AM | #461 |
Rep 64
11-18-2021, 09:10 AM | #462 |
Rep 2,146
Drives: F80 M3
this is what you wrote " 225/35/19 and 255/40/19" hopefully the middle numbers are flipped then you are fine haha
437m, f30, rims, wheels |
