07-28-2020, 03:26 PM | #3565 |
Rep 14
07-28-2020, 03:43 PM | #3567 | |
Rep 14
And then put it in the USB and turned the car on It hasn't said anything about upgrading So i must be going wrong somewhere? |
07-28-2020, 04:53 PM | #3568 | |
Rep 2,365
Drives: E63 645Ci
OTA means over the air updated. This is how your phone is receiving updated... funnily enough, it's not the case on our units anyway.
Kri1083.50 |
07-28-2020, 05:01 PM | #3569 | |
Rep 14
Ok I'm going to try again from the start ive downloaded the latest firmware again Pray for me 😂 And thanks for the help I appreciate it 👍🏽 |
07-28-2020, 05:11 PM | #3570 | |
Rep 14
Sat in my car done everything how you have said but still not seeing any prompt for an upgrade |
07-28-2020, 05:30 PM | #3571 |
Rep 2,365
Drives: E63 645Ci
07-28-2020, 05:38 PM | #3572 |
Rep 14
07-28-2020, 06:49 PM | #3573 |
Rep 14
Just tried with an sd card, and still nothing, how long should I give for the update prompt to pop up and is their anything else you can think to try, at worst I just really need the Bluetooth to work. Thanks again
07-29-2020, 01:25 AM | #3574 | |
Rep 2,365
Drives: E63 645Ci
Fingers crossed this should work. |
07-30-2020, 03:25 AM | #3575 | |
Rep 19
Yes I dont have Nav and I believe you're correct . I have CIC no Nav on a 2013 BMW. I dont have a moving animation on start up on the BMW side of the system. Do you know what those CanBus settings are for and which i should choose for my car ? |
07-31-2020, 01:36 PM | #3576 |
Rep 17
hey guys
if i update the firmware to the latest that i can find here, is there any chance that i might get a split screen option?! my current firmware is from march 19 (i think ... i don.t remember) or the updates are just some minor , security things?! thank you ! Edit: wifi adapter in ... works like a charm now ! thank you for that advice (way easyer than to mess with the bluetooth or other cables ) i just want to split the screen somehow and thats it Last edited by micdarau85; 08-01-2020 at 12:24 PM.. |
Kri1083.50 |
08-03-2020, 03:37 AM | #3578 |
Rep 551
The concern is that it is then no longer possible to share your connection with your mobile phone and have WAZE / SPOTIFY / MAP at the same time as the OBD application ... Unless you have a SIM card available. inside the unit?
I found a nice application: Notification-Toggle on Android, it allows you to shortcut from the pane that you go down = Various settings like Brightness / Volume / BT / Wifi and any shortcut to an application |
08-04-2020, 12:45 PM | #3579 | |
Rep 17
and if i really need to have a quick look i can use my phone |
08-07-2020, 06:43 AM | #3580 |
Rep 19
Has anyone been able to get the idrive controller and the scroll on the right hand side of the steering wheel controls to do the same thing ?
My old mmi box it worked for scrolling through menu options but on my android screen it just skips music to the next song , or movies to the next file . Snapdragon 10 if that helps |
08-08-2020, 05:44 AM | #3581 |
Rep 55
ADAS
Hi guys,
I connect my HU to my iphone personal hotspot. I'm running IOS 14 beta and since then I cannot connect from the HU to the hotspot - it seems Apple have changed the supported wireless encryption from WPA2 to SAE which the HU does not seem to support. I've upgraded to the latest OTA - v3.9.8 but still can't connect. Quick question - do these OTAs upgrade the Android OS as well as the GUI? If so, hopefully a future update will include support for WPA3/SAE as I don't expect Apple will re-introduce support for WPA/WPA2. Final question - what is the purpose of ADAS? Can I disable it? |
08-08-2020, 06:01 AM | #3582 | |
Rep 2,365
Drives: E63 645Ci
08-08-2020, 06:18 AM | #3583 | |
Rep 2,365
Drives: E63 645Ci
As for the updates these are predominantly KSW Car Project related so very little if any goes into underlying Android OS itself. Security patches are outdated and I don't expect Chinese to follow new Google releases very closely. ADAS stands for Advanced Driver Assistance Systems. In this implementation it works with your front DVR camera to record events, but also to provide functionality like lane assistance, collision detection etc. It requires calibration and it's a gimmick imo, nothing like OEM systems. You can safely delete that. |
08-08-2020, 08:02 AM | #3584 | |
Rep 55
08-08-2020, 09:01 AM | #3585 | |
Rep 55
Are there some files I need to delete to reset this? I tried resetting network settings in the main android system menu. TIA |
08-08-2020, 09:55 AM | #3586 | |
Rep 55
Mjam133.50 |
