BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Unichip CarPlay
      10-13-2017, 03:04 PM   #23
steve@codemybimmer
steve@codemybimmer's Avatar
Hong Kong
665
Drives: 2020 G20 320i M Sport
Originally Posted by InTheSound View Post
Sign me up Should be compatible with '14 F22...
Are you going to sell this off your website in November?
Yep, it will work with both the 6.5" screen and 8.8" on your vehicle. If you have NBT, you will need to remove the glovebox to tuck the MMI box into mounting location but it's not overly difficult.
It will be available on the sponsor classified section as well as on our website available for purchase and I will be sure to announce it.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming
steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca
Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs
      10-13-2017, 03:07 PM   #24
InTheSound
InTheSound's Avatar
Drives: BMW M2 '18
Nice! I do have the 8.8 NBT. Thanks for the update and doing the testing. I?ll watch for your announcement then!
      10-13-2017, 11:17 PM   #25
seancarlin
Drives: 2012 328i
Will it work on a 2012 F30 with the 6.5” screen and no nav? I think that’s CIC. Also, will you ship to the USA from your website?
      10-14-2017, 12:24 AM   #26
steve@codemybimmer
Hong Kong
665
You have HU_ENTRY which is one of the confirmed working setups. Installation will be very simple for you since your factory head unit is small enough to also fit the CarPlay module in the same compartment.
Yep, we ship anywhere within the US and Canada.
      10-14-2017, 12:50 AM   #27
Aevintiri
Aevintiri's Avatar
Drives: 2019 Black 330i xDrive
Nice! Better solution than the 2800$ retrofit from bimmertech.
2019 G20 Black 330i xDrive
      10-14-2017, 12:51 AM   #28
seancarlin
Drives: 2012 328i
Awesome, looking forward to getting one. Thanks, Steve!
      10-14-2017, 03:40 PM   #29
dr.roro
Drives: 2019 G01 X3
Does the CarPlay module work via HDMI? Does it include the MMI or is that an extra cost? Does the iPhone connect into the factory USB port, and if so, can you still use it for music?
      10-14-2017, 08:47 PM   #30
steve@codemybimmer
Hong Kong
665
Display is via LDVS and piggy backs onto your OEM screen. You will need to plug the OEM APIX display cable into the MMI box and there will be another cable to connect back into your OEM screen from the MMI box. To trigger CarPlay, you need to press the No.8 shortcut key on the climate control.
This MMI box is solely for CarPlay and does not have any sort of aftermarket interface.
The iPhone connects to a separate USB port that comes with the MMI box which you can either run to the Glovebox or Armrest. The amperage on this USB port is actually higher than the OEM port so charging is way faster.
Once your iPhone is connected to the CarPlay MMI box, you must change the Audio source on the BMW interface to AUX for audio to work. When you're running on CarPlay, you will be able to browse and play tracks off Spotify, your Music Collection as well as any other compatible apps.
We'll have a video of the device in action next week.
      10-14-2017, 09:44 PM   #31
ooshnoo
ooshnoo's Avatar
Drives: 2014 428i and 2018 X5
2018 BMW X5  [0.00]
2014 BMW 428i  [10.00]
Does the CarPlay work over Bluetooth?
___________________
2014 F32 428i M-Sport
2018 F15 M-Sport
      10-14-2017, 09:52 PM   #32
steve@codemybimmer
Hong Kong
665
Wired over USB directly to the MMI box.
      10-15-2017, 10:43 AM   #33
ooshnoo
ooshnoo's Avatar
2018 BMW X5  [0.00]
Crap. That may be a deal breaker for me. I wonder if a USB bluetooth adapter would work...
___________________
2018 F15 M-Sport
      10-15-2017, 10:48 AM   #34
steve@codemybimmer
Hong Kong
665
CarPlay is too complex to be used over a Bluetooth Connection. The OEM BMW CarPlay uses Wi-Fi.
Personally, I would prefer USB since the wireless version is known to be a bit laggy and doesn't use the full dimensions of your screen.
      10-15-2017, 12:39 PM   #35
otay
otay's Avatar
Drives: 2015 335i
Subscribing!
      10-15-2017, 10:08 PM   #36
arom
arom's Avatar
Drives: 2016 320i xdrive
So in order to use the audio of CarPlay it has to be set to AUX mode? Im that case you wouldn?t be able to listen to FM music and get turn by turn via the CarPlay navigation?
      10-15-2017, 10:35 PM   #37
steve@codemybimmer
Hong Kong
665
Correct. You can still use CarPlay while listening to AM/FM or Sirius XM but you will not be able to hear the voice instructions given by CarPlay if you are using it for Navigation.
      10-16-2017, 09:23 PM   #38
akgambino
Drives: 2013 F30 335xi M-Sport (PWG)
Wait a second... sorry if I'm late to the party here as far as CarPlay goes but are you saying that CarPlay and this device will use your phone for navigation and it will show up on the hu_entry 6.5" screen with no combox and all you need is to have your iPhone hooked up via USB?
I have been thinking about a $2000 nbt retrofit for the last year to get things like album art, Bluetooth music and navigation. Maybe this thing is the way to go!
Is there any chance you can provide a full list of features that this will add to a car with hu_entry? It is really too bad that the iPhone needs to be connected to the car but if you are able to confirm that Tidal would be able to be controlled via idrive so I don't have to touch my phone to scroll through playlists or skip songs while driving oh my I would sure be happy!
Thanks! And looking forward to seeing a video of this is action!
2013 F30 335i xDrive M-Sport 6MT (FBO/BM3 custom tune by HCP, 91 oct, 550i clutch, xDelete)
      10-17-2017, 10:32 AM   #39
steve@codemybimmer
Hong Kong
665
That's right! You can use your existing screen and head unit and this would be an add-on to your OEM setup.
This CarPlay addon will give you all of the features integrated with CarPlay that runs off your phone such as Siri Voice Control integration, Music Playback, access to apps such as Spotify and Tunein Radio and also Apple Maps. Yes your phone has to be connected at all times but you will have Navigation on your vehicle and access to your music without having to spend over $2000 on a NBT retrofit.
You can browse and skips songs either directly from the carplay interface or via the thumb wheel on the steering wheel. You can also navigate through the CarPlay menu using the OEM iDrive controller just like on BMW's version of CarPlay.
Hope this helps!
      10-17-2017, 01:14 PM   #40
akgambino
Hope this helps!
Sounds awesome! And i am pumped that you are in Canada as that might potentially make this even more cost effective for me as far as shipping costs go.
When will you have a comprehensive video showing all the features on a car with HU_ENTRY and more importantly when are they available for sale and what is the cost?
One other question, with CarPlay can you screen mirror or have video playing from netflix or youtube? I imagine some fancy jailbreaking of iphone is likely required, sorry for being a noob
      10-18-2017, 03:35 AM   #41
beanbaguk
beanbaguk's Avatar
Spain
455
Drives: BMW G30 520d M-Sport
Hope this helps!
Steve, as mentioned a couple of times before I'm really interested in this product. Can you PM me with an approximate price and if possible, can I put down a deposit to get my hands on this in the first batch?
Also, I want to add I live in Spain so would delivery here be an issue? In fact, I work in an overseas territory of the UK called Gibraltar, so if delivery is possible there, that would be great as I could avoid the VAT and duty when the unit arrives over here....
Current car: 2017 BMW G30 520d M-Sport, BMW F46 218d Grand Tourer
Previous cars: 1989 BMW E30 316i, 1998 BMW E36 323i Coupe M Sport, 2009 BMW E87 116d, 2013 BMW F31 320d M-Sport
      10-18-2017, 11:11 AM   #42
torqueflite
Drives: 2014 428i xDrive Conv. (F33)
Steve,
Concerned about the Aux audio issue, as if I wanted to use NBT nav (so that I get turn-by-turn in the HUD) and listen to music on CarPlay at the same time, it's a no-go. Is this correct?
Regardless, given the results of your evaluation so far, I'm interested in this product if the price is right. Please keep posting your feedback as you evaluate!
Are you still on-track for 2nd week of November availability? Any idea on price?
Thanks!
      10-18-2017, 08:21 PM   #43
steve@codemybimmer
Hong Kong
665
Yep, you've definitely been following all my posts about this. Ok! I sent you a PM.
      10-18-2017, 08:30 PM   #44
steve@codemybimmer
Hong Kong
665
Originally Posted by torqueflite View Post
Steve,
Thanks!
You just brought up a very interesting test case. It might actually still be possible to have turn by turn directions on the HUD while listening to CarPlay. I'll see if I can test that and report back.
As for pricing, we cannot post that here due to forum rules so you can either PM me directly or wait until we have the corresponding commercial thread in the sponsorship classified section.
Yes, we're still on track with 2nd week of November. Right now, we're sorting out some compatibility issues with iOS 11 with the manufacturer but we will keep you posted.
carplay
