10-08-2019, 06:11 AM | #1 |
Rep 266
Has anyone done a LCI tail retrofit?
Wondering if it's a similar process to the f30 LCI retrofit? Can't find any diy at all. Hoping someone has some kinda info on this. Thank you!
12-03-2019, 11:51 PM | #2 |
Rep 1
I've searched and only found very few members that have done this LiteBlue Login.
01-25-2020, 03:40 AM | #5 | |
Rep 266
01-27-2020, 08:40 AM | #6 |
Rep 48
Hi, I've done it. If you have some questions, feel free to ask. Not fully though (I still need to run the inner indicator wires), but everything other works just fine.
01-27-2020, 10:18 PM | #7 | |
Rep 266
So far I was able to install both outer tail lights. I have the euro spec with amber turn signals, they look great btw. I just need the lci harness for the inner lights. |
02-01-2020, 02:40 AM | #8 |
Rep 266
Just an update. Waiting on new connectors to come in so I can wire up the inner tails. This whole process is actually rather simple, just needed the right part numbers.
02-02-2020, 02:40 AM | #10 |
Rep 266
Cheers mate!
I just wrapped the inner tails with a light smoke. Really excited about this project haha. |
02-13-2020, 09:57 AM | #12 |
Rep 105
I like the look of the car as well. Mine is still stock silver and although I don't usually like much in the way of mods, the car seems a bit bland to me. Thinking of adding some carbon fiber or something at some point. I've never been a spoiler fan, but I like the look of the carbon fiber spoiler on the GT.
03-04-2020, 02:31 PM | #13 |
Rep 471
Drives: G20 330i xDrive M-Sport
11-22-2020, 03:49 PM | #15 |
Rep 7
11-22-2020, 04:16 PM | #17 |
Rep 16,054
Canbus has nothing to do with the need for coding. I doubt there's a single LED retailer than even knows what canbus is. Some LEDs have circuitry that prevents errors, but none have circuitry that removes the need to turn off the cold and warm voltage checks, or to change the voltage from pulsed to constant.
11-22-2020, 09:07 PM | #18 | |
Rep 266
Not sure if coding was necessary but I did go ahead before installing change all my lights to led with Bimmercode. No error messages when I actually installed. |
11-26-2020, 12:13 AM | #21 |
Rep 48
Congrats Good luck for the inners. I've had to lower the headliner in the back a little to get a good access for routing the 2 wires needed for inner turn signals. If I remember correctly there are 2 big clips from the headliner to the roof ( reachable with plastic trim tool ).
11-29-2020, 05:52 AM | #22 |
Rep 12
Thanks for the tips , waiting for connectors and pins (inner lights) , i found out i have to change Trim Drip Rail left and right , parts number 51497443809 and 51497443810 (ordered allready ) .
