07-13-2017, 07:50 AM | #45 |
Rep 297
Enzo's tune in NY will go into readiness. He said he's had a few people pass emissions with it already. I think it just speeds up the cycle. He showed me on my car when the car is on but not started it shows as not ready, then when you start the car it essentially takes a few secs then goes to ready.
Jadar1752.50 |
07-13-2017, 06:33 PM | #46 | |
Rep 89
Thanks
2015 335i xDrive mpack
JB4, BMS intake, MPE, ER DP, ER CP |
11-08-2017, 05:39 PM | #47 |
Rep 82
11-08-2017, 06:21 PM | #48 |
Rep 801
Doesn’t work on all cars... I used the very same sim that has been used on quite a few F30’s and N55 motor’s and it did not work on my car. Must’ve just been one of the unlucky ones it didn’t work on... I had to swap the downpipe on my F30 N55 XDrive to pass emissions. Quite the pain in the ass, but now I don’t have to worry about it ever again with how I reregistered my car. I guess what I’m trying to say is don’t wait until the last minute like me and have a backup plan.
11-08-2017, 10:00 PM | #49 | |
Rep 89
So ya, I basically had to remove the dp and put it back on and that was a royal pain.
12-08-2017, 09:19 AM | #51 | ||
Rep 160
Thank you in advance |
12-22-2017, 05:39 PM | #52 | |
Rep 103
12-23-2017, 11:33 AM | #53 |
Rep 801
01-05-2018, 06:24 PM | #54 |
Rep 310
where can i find this extension?
2008 E90 M3 6-Speed - Sold
2013 F30 335i MSport 6-Speed - Current |
01-08-2018, 11:26 AM | #55 |
Rep 801
01-10-2018, 07:24 AM | #56 | |
Rep 103
Got a few weird codes like: 12A308 - lambda probe after catalytic converter, dynamics, from rich to lean: slow reaction 12AF20 - no description found I believe the CEL went away, but I never checked for readiness. Couldn't find much info on those errors so I pulled it off for now. Planning on installing again soon for more testing. I'd hate to have to removed the catless for emissions testing. Anyone running the dp fix at all times?
2014 335i xDrive F30 auto, Jb4 FF+EWG wires, VRSF DP,CP and FMIC, BMS intake, Remus Axle-back
SOLD - 2011 335i xDrive 6MT e90, JB4 ISO + ff wires, VRSF downpipe and chargepipe, BMS intake, BMS modified clutch valve, ST S1 coilovers. |
01-10-2018, 01:50 PM | #57 |
Rep 6
They say you can run the catsim/vrsf downpipe fix all the time now as they dont mess with the fuel trims like the n54 dp fix. With that said if i was you unless you have no other way to run to delete the cel and hate seeing it i would take it off and only install it for emissions. Also depending on your tune make sure you flash back to stock or set jb4 to map 0 as most tunes will not allow readiness. Let me know if you get it to work as ive heard with the 2014+ EWG cars have had issues getting it to work.
01-10-2018, 11:22 PM | #58 |
Rep 82
It worked for me! I used posi-taps to connect the iO2 sim to my O2 sensor. Once attached, and the car was running, the green light would illuminate sporadically (not constant, not flashing steadily). Drove for 20 miles. Turned my car off. Started the engine again and the CEL was gone. Passed my inspection! I’m happy to answer any questions anyone might have too. Feel free to reach out.
JaredG_F301106.00 kovalchuk7112.00 |
01-11-2018, 11:57 AM | #59 | |
Rep 1,499
01-11-2018, 09:14 PM | #60 |
Rep 82
I have a 2012. Not sure if it’s pwg or ewg. For the posi-taps, I threaded the exposed wires from the simulator through the female type opening of the positaps, then used the tooth-like part to pierce the corresponding wire on the engine wiring harness
01-12-2018, 10:30 AM | #61 |
Rep 1,499
Ah...if you are 2012 then you are PWG. My wiring is going to be different. I wasn't looking for how to use posi-taps but was wondering if you had a wiring diagram. No worries though since my wiring is going to be different.
01-13-2018, 09:37 PM | #62 | ||
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
I've asked area 7 4 numerous times what the issue is with the newer cars and they only answered once by saying it "should" work. It's nice having a plug n play solution too bad I can't source the terminals anymore.
FBO-PS1 and stuff
hardparker299.00 aps335.50 |
01-15-2018, 01:48 PM | #63 | |
Rep 1,499
DAMMIT!! Well at least I don't have to get smog checked until December 2019. Hopefully there will be a fix for it by then. If not I may just pony up for an Enzo tune.
On a side note I will have a VRSF/CATsim DP fix available soon. Quote:
01-15-2018, 01:50 PM | #64 | ||
Dejan
1753
Rep 4,197
I hate to be the bearer of bad news but the so called VRSF down pipe fix is the same exact one that is made by a r e a 74 then are just rebranding it.
FBO-PS1 and stuff
01-15-2018, 02:08 PM | #65 |
Rep 1,499
Yep I realized that the VRSF is the same as Area 74 as soon as I saw it. Oh well. Hopefully I cna sell it to a PWG owner and recoup most of my expense. It's brand new, never been used.
01-15-2018, 02:10 PM | #66 | |
Dejan
1753
Rep 4,197
FBO-PS1 and stuff
JaredG_F301106.00 |
