12-11-2018, 11:16 AM | #23 | |
Rep 1,827
Edit: oh wait, you said xDrive. Not sure how much slip you'll get.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
12-11-2018, 11:21 AM | #24 | ||
Rep 5,984
12-11-2018, 11:34 AM | #25 |
Rep 1,934
Sport+ in pre and lci only differ by the feel of throttle response, but that's entirely because the engines are a bit different. Doubt it's the software making it feel different.
In any case, you can definitely step put the rear in xdrive with sport+. I'd done it a couple times when I'm alone in my work parking garage at the end of the day lol. However I JUST recently discovered the sport transmission mode. Thought moving the shifter over just went into manual. Found out when I was doing some breaking in of my new remus axleback
12-11-2018, 11:44 AM | #26 |
Rep 234
Ask a hundred people and you'll get a hundred different answers (even here!).
But I've been wondering, is there a difference between slapping the shifter over to the left or using the Sport or Sport + switch for drivetrain changes. The shifter is certainly more convenient to switch over than fooling around with the mode switch.
2015 Mineral White 335xi Sport trim
12-11-2018, 11:48 AM | #27 | |
2020 Z4 M40i - 2022 M4C Convt
3124
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
That said with reasonable care its easy to drift a RWD.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
12-11-2018, 11:52 AM | #28 | ||
Rep 1,827
12-11-2018, 11:59 AM | #29 | |
Rep 9
PS. I'm loving my bimmer. I graduated to my 335i from a mk7 gti. Can't wait to graduate to a true M |
12-11-2018, 12:05 PM | #30 |
Not stock
472
Rep 617
So today I turned driving mode options such that Sport has no "chassis" enabled - steering was like comfort mode in Sport mode, however, going to Sport+ tightened the steering as well. Just a finding.
2015 BSM 328i Sport Line - BSM
2015 BSM X1 M Sport - BSM 1992 525i 1987 325e |
12-11-2018, 12:07 PM | #31 |
Rep 5,984
Yes there is a chassis mode you can select in sport mode. You can also select drivetrain only.
12-11-2018, 12:08 PM | #32 | |
3124
Rep 5,264
The 340's tires also Continental held up, might have been newer to start. Older 8ZF chart but will give some idea of what is happening. Possible coding variations among models & years.
Kevin
12-11-2018, 12:20 PM | #33 | |
3124
Rep 5,264
If a local club does Auto-X enter the car, you will learn a lot about its handling in a challenging but safe environment. Also with summer tires the cars handing will change (deteriorate) with lower winter temperatures.
Kevin
12-11-2018, 12:37 PM | #34 | |
Rep 9
12-11-2018, 12:38 PM | #35 | ||
Rep 5,984
12-11-2018, 12:44 PM | #36 |
Rep 9
Yeah. I was looking at a good deal on some potenzas and Michelin ps2 until I remembered I had run flats. I guess I'll just buy a donut to use in case of a flat.
12-11-2018, 12:49 PM | #37 | |
Rep 5,984
12-11-2018, 12:50 PM | #38 | |
Rep 337
However, for the fastest gear swaps and to lift the rev limit, go into sport+ and gear lever to the left, then obviously change gear using the paddles. It really is as fast as most dsg's in that setup. |
12-11-2018, 12:52 PM | #39 | ||
Rep 5,984
12-11-2018, 12:52 PM | #40 |
Rep 216
I mostly use Sport because I don't like the orange dash light that Sport+ puts on in my pre-lci. But if someone creeps next to me at a light, and it looks like they might attempt some overtake shenanigans then I will not hesitate to engage SPORT+ (and slam the shifter to the left)
12-11-2018, 12:53 PM | #41 | |
Rep 5,984
12-11-2018, 01:01 PM | #42 | |
3124
Rep 5,264
North Carolina, 18" Monday. Summer tired German cars were TOT. Only thing moving was my 4X4 trucks, 500+ accidents so far. Melt started yesterday, bright full sun, sky is Carolina Blue 47*F, today & driving OK. Changed the 335is in 1500 miles, really bad ride. Kept the 435 & 440 RFT. With adaptive suspension they are no issue. Handling wise will never push a street car into a zone where the spread between get flats & RFT is reached. Summers will start to go away around 40*F, not extreme loss but they are starting to change. Personally I drive them all year round in Sport or Sport+, 6MT in 3rd or 4th I just am more aware when its cold out. Car will give you a be careful warning. Even drive the track tired COBRA all year round.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT Last edited by BEAR-AvHistory; 12-11-2018 at 01:23 PM.. |
12-11-2018, 01:43 PM | #43 |
Rep 406
Question: How does the Sport mode with Adaptive Suspension compare to non-Adaptive suspension with M-Sport?
I can't tell if it's stiffer or comparable?
Specs: '16 340i|6sp MT|Silver Metallic|Black Leather with Oyster Highlights|Aluminum Hexagon Trim. Options: M-Sport|Cold Weather|Technology|Track Handling|Power Rear Sunshade|Driving Assistance |Driving Assistance Plus|Lighting|Harman Kardon|Surround View Pics of my car |
12-11-2018, 01:55 PM | #44 |
Rep 1,827
If you don't have adaptive suspension, nothing changes. EcoPro, Comfort, Sport, Sport+...all the same.
