11-26-2024, 11:28 AM | #1 |
Rep 36
How long does it take oil level to update?
Hello, I would appreciate some help.
I’ve had numerous issues with my oil level sensor, that I thought had been fixed until today. My car: 2014 F30 335i Msport, MHD stage 2 tune and supporting mods My main issue was my oil would always read full. I had the sensor replaced a few days ago, and it read 3/4 from full. I added about 200ml of oil today, drove about 15 mins, and it still reads 3/4. I miss the luxury of a dipstick. Has anyone had this issue before? |
11-26-2024, 02:41 PM | #3 |
Rep 36
I just want to ensure that if I need to add oil, the car tells me. If something is not working right, it could cost me the engine if there’s a sensor related problem.
11-27-2024, 07:58 AM | #4 | |
AH3 Owner
276
Rep 409
Drives: BMW 335i ActiveHybrid 3
What comes to the car "telling you when it's time", it always doesn't. I had one instance with another BMW where it told me to quickly add 1 liter only after I manually did the oil level check. I would wager doing the check once a month manually is required. Last edited by NxTH; 11-27-2024 at 09:08 AM.. |
11-28-2024, 10:33 AM | #5 | |
Rep 36
11-28-2024, 11:17 AM | #7 |
Rep 36
11-28-2024, 12:14 PM | #9 |
Rep 36
11-29-2024, 02:57 AM | #10 |
![]() 25
Rep 109
You will get a warning if the oil level is at it’s minimum
Then you fill up with 1 ltr of oil. After a short drive, when the oil is on temperature you will see it’s on max. again. No worries. |
11-29-2024, 09:33 AM | #11 |
Rep 36
12-01-2024, 07:24 AM | #12 |
Rep 36
Okay, thank you. I know that at one point the tune and sensor worked together with no issues but I know sometimes things change.
12-03-2024, 04:50 PM | #13 |
Rep 1
i guess only way to figure this out is to draiFor all the oil, measure the new oil and fill it in. Then, drive a couple of thousand miles, drain the oil, and measure drained and compare
12-03-2024, 08:10 PM | #14 |
Rep 36
