06-27-2017, 02:54 PM | #683 |
Rep 4
Forgot to note I had my tone settings from the head unit at 0 for treble and +3 for bass. I was listening quite loud approx. 80% when the burn smell came up. Would it be helpful to reduce the tone to 0 and increase the bass from the dsp?
Thanks! |
06-27-2017, 04:08 PM | #684 |
Rep 2,180
You need a trunk sub and a mono amp.
06-27-2017, 05:39 PM | #685 |
Rep 4
06-28-2017, 02:42 AM | #686 |
Rep 120
Morning, everybody,
Look what I encountered with my F31 LCI OEM amp: It doesn't have 4 bolts anymore, but just 1. There are 3 weird pins. I take it, you suppose to "move" bracket of the pins in order to remove, but I tried hard and no success. Any quick suggestion on technique how can i take it off, please?
Honda Accord -> Subaru STi -> E93 -> F30 + F15 -> F30 -> F31 LCI -> G31
06-28-2017, 07:19 AM | #687 | |
tends to get irritable
202
Rep 798
AC Schnitzer/Eibach/M Performance/RaceChip/Compustar/Drone/BimmerTech/FireTV/Helix/Dynaudio/Micro-Precision/Jehnert/Audiomobile |
antah16.50 |
06-28-2017, 02:19 PM | #688 |
Rep 120
Great advise! Helped me. I tried it harder today and moved it.
Another question (I already asked bimmer-tech, but maybe you can answer quicker) - I can hear quite interference noise from speakers when open up the car with bimmer-tech amp. Is it possible that it is caused by mode switches? I didn't touch them, but i think they are not all off?
06-28-2017, 02:51 PM | #690 | |
202
Rep 798
06-28-2017, 03:32 PM | #691 |
Rep 120
Hi! If advanced = Harman/Kardon, then this upgrade is not for you, i'm afraid. But relax, you already got decent sound then
06-29-2017, 08:52 AM | #692 |
Rep 793
06-30-2017, 02:40 AM | #693 | |
Rep 120
You asked for benefits: to be honest, there was no WOW effect when I plugged it in, however, there are tonns of settings you can play with and if you are great in all equalisers - you can achieve great results. What I was surprised with - mic measurements can't set proper time adjustment! You still have to use tape measure to check it.. what a shame!
12-23-2017, 01:33 AM | #694 |
Rep 793
hi guys does anyone know if the oem hifi amp is removed it causes any issues with bmw software updates to the car? as I want to get mppk fitted which will include recoding to the ECU.
02-04-2018, 08:56 AM | #696 |
Rep 206
Hi,
I'm new to the F generation BMW, but not to tuning the Helix/Match DSP products and I must admit that I never used rear channel signals in the centre channel. Out of curiosity I must ask why? // Chris |
02-04-2018, 06:03 PM | #697 |
Rep 21
Question for you audio pros. I replaced my stock tweeters. Since i didn't replace the center channel i just muted it in the amp so the lesser tweeter wouldnt affect the sound. All remaining speakers are stock. Was this a good solution to remove the center channel?
02-16-2018, 02:24 PM | #699 |
Rep 8,942
You need a mounting bracket, wiring harness and tune.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
04-23-2018, 06:01 AM | #700 |
Rep 3
Hey guys, I ordered this amp from Bimmertech, should arrive this week. I read the whole thread and also original Helix manual, asked Bimmertech support but still didn't get an answer for one question.
In the manual there is a config with front/rear speakers + match PP sub (I suppose 4 channels are used in the mode one channel per coil, there are two woofers with 2 coils each so it makes sense to me). In current harness config channels F-G are used for woofers, is there a possibility to drive them by rear channels so A-D channels will drive the front completely. What I want to do is a classical setup of front speakers + trunk sub from one amplifier. I don't need center/rear speakers and to me it looks like a possible setup with this amp (of course the harness should be re-wired for this but should be very easy). Is there any problem with this configuration? Did anybody try something like this before? Cheers from Munich, Alex |
04-26-2018, 03:39 PM | #701 | |
Rep 59
Hi Alex,
I checked our inbox for any emails that might have been from you with the stated questions but couldn't retrieve it. I do recall talking to someone about a similar matter but at the time I believe the questions were different or I understood them differently so I don't know if it was you or not. Firstly nothing is impossible. Rewiring the harness will be possible. Cars that don't have an amplifier at all do have the woofers wired in with the front midranges and you could do that but it would pretty much kill any benefit of using a DSP amp. Secondly the tonal balance might be off or almost certainly would. The whole point of a system based on our premium amp is to have active crossovers on the woofers, front, rear and center speakers with time alignment and EQ. If you sacrifice that to install a trunk sub with four coils then you'd be defeating a lot of the benefits that our amp has to offer. On top of that wiring in a four coil woofer you'd need to be extra careful not to wire one of the coils out of phase which wouldn't be hard to do even if you're paying attention. I'd be checking that with a mic or scope for sure. You'd be much better off getting a dedicated sub + mono amp fed by the RCA output of our amp that does have DSP on it to enabling you to tune such a sub perfectly. And it would be a reasonable solution that has been done millions of times before because it's the way to go when you want seismic bass . I understand that urge and have a German made Audio System 12" woofer box lined up for installation in my car any weekend now . It cracks my spine just thinking of picking it up. But it's the right thing to do when matched up with some DSP and a 700W monoblock There are many options out there - the one you proposed sounds doable but in my opinion just feels plain wrong that's why I'm against it. I hope others will agree. Quote:
04-27-2018, 04:14 AM | #702 | |
Rep 3
To be honest I'm not sure I understand what you mean. Rear amp outputs have the same crossovers and configs so I don't see a problem to use them to drive the woofers under the seats. I also planned to use Match subwoofer designed for this app, I don't know if they use all four channels or only two. I believe they use all four, otherwise it just doesn't make any sense to me. I installed the amp, configured to my taste but not impressed that much so far. Without additional subwoofer the difference is not really serious so I'm thinking how I can do this easily and with less investments. Just don't want to cut any cables until I get some confirmation that my idea is completely stupid and technically not feasible with this amp. I am 3 times champion of my country in SPL competitions so I have some idea, so to say. But there is not enough information about this amp, even Helix manual has very limited amount of information to make some conclusion. That's why I am looking for practical experience here |
04-27-2018, 01:40 PM | #703 |
Rep 59
Nice talking to you earlier today Alex.
After a quick chat it became apparent I previously somewhat misunderstood what Alex is aiming to do which is to unhook the rear speakers and center, hook up the under seat woofers to the channels that were previously driving the rear speakers, and use the remaining E,F,G,H channels to drive the four voicecoil Match sub. It's a bit weird, but technically feasible. Here is the main connectors pin assignments to allow rewiring: I don't have a pinout for E,F,G,H but knowing German engineering I bet all of the positive polarity outputs on those channels will as well be on the side where the clip of the 8-pin molex plug is. Hopefully I'll be able to get a pinout schematic next week. I think I posted it recently but anyway here are the standard channel assignments: A Front Left midrange (all cars) and tweeter*(if you have them) B Front Right midrange (all cars) and tweeter*(if you have them) C Rear Left midrange (all cars) and tweeter*(if you have them) D Rear Right midrange (all cars) and tweeter*(if you have them) E is for center channel (if you have one) F is for Left Woofer under seat G is for Right Woofer under seat H is not connected Let us know how it turns out. Maybe you'll start a trend. |
04-27-2018, 10:59 PM | #704 |
202
Rep 798
Not needed if using a Match subwoofer but may still be helpful ..
audiotec fischer, bimmertech premium sound system, bmw amp upgrade, bmw hifi |
