04-24-2017, 01:32 PM | #1 |
Rep 174
Drives: 2014 F32 435i xdrive 6 speed
Greasy looking car - Sapphire black
Hey guys - just got this last month and only in the sun did I realize the paint looked like this. I can't wipe or wash it off...wondering how do I get this off? Assume this is from a crappy wax job?
The car was pre-owned so don't think I can ask them to take it off. |
04-24-2017, 02:32 PM | #2 |
Rep 87
Your car is not greasy and does not have film of fluid. The clearcoat is marred up causing micro-scratches and swirl marks. These scratches give your car that kind of halo appearance.
Your car requires a cut-polish to remove the damage. You can look up in the detailing subforum how to remove it yourself or look up a reputable car detailer in your area to help you remove it. |
BrettKA7566.50 |
04-24-2017, 03:07 PM | #3 |
Rep 536
Drives: 2013 335xi Alpine White
Wow - previous owner did not know what they were doing - or maybe it was the dealer's "detailing" crew...
That being said, yes, only a paint correction will get rid of this. Good luck. |
04-24-2017, 03:30 PM | #5 | |
Rep 5,776
2013 335i Msport Black sapphire/Coral red. MHD. stage 2--e30 VRSF DP, ER CP, Dinan Shockware. VRSF 12mm/15mm spacers. Cobra dashcam. Various codings.
Last car: 2011 335i Msport. JB4. Vrsf CP |
04-24-2017, 05:28 PM | #6 |
Rep 174
Thanks - I figure I should be able to "buff it out" but as I haven't waxed a car in 20 years, not sure what's out there. I'll research more but thanks for the initial advice here.
04-24-2017, 05:43 PM | #7 |
Rep 2,193
Research detailing & holograms - plenty of info about this common issue:
http://www.meguiarsonline.com/forums...QF0xhipujfs.97 https://www.autogeekonline.net/forum...polishing.html
04-27-2017, 12:17 PM | #8 | |
Rep 536
05-25-2018, 11:27 AM | #9 |
Rep 174
So an update to my greasy car. I finally had a chance to fix it for the spring. Thanks for all the advice here and also found a lot of info on Reddit.
Here's what I did in a nut shell - bought almost everything from Amazon except for the waxes. - Two bucket wash with new microfiber wash mitts - Clay bar - Clean up using alcohol wash - Meguires Ultimate Compound with Chemical Guy Orange hex pad using the Porter Cable DA Polisher - Meguires Ultimate Polish using white hex pad - Meguires Spray on Detailing wax (got lazy) I got out all the swirls, and lots of scratches, but some still remain but fairly minor. Took 4-5 hours over two days. The DA polisher is amazing, so easy to use. Overall, not 100% perfect but good enough to my liking. I was parked one day near a pizza joint during lunch where a bunch of high schoolers were coming towards...saw a few people staring, a few others saying "clean", etc, etc. Anyway though I would share my success story! |
05-26-2018, 03:33 PM | #10 |
Rep 2,193
Excellent - good work!
05-27-2018, 11:12 AM | #11 |
Rep 1,101
I have BSM 335 and I give my car a good polish twice a year. Usually my spring polish it 3 step and my fall is just a light polish seal. My paint looks great.
M105\lake country cyan cutting pad M205\lake country tangerine light polish pad jescar/menzerna power lock sealant. All steps using my porter cable RA polisher. |
06-05-2018, 01:40 PM | #12 | |
A family of bimmers
2745
Rep 7,741
jmg18657.00 louielouie534.50 |
06-07-2018, 02:16 PM | #14 | |
Rep 14,107
Drives: G82 M4C X-Drive
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 Last edited by jmg; 06-07-2018 at 04:53 PM.. |
wdeerfield2745.00 louielouie534.50 |
06-07-2018, 09:43 PM | #15 |
Rep 16,052
+1. I just did a full recon of my three year old F34, as there were enough scratches in the paint to justify it. I rubbed it out with Menzerna 400, then Menzerna 2500, finished it off with Power Lock. I normally do Power Lock each spring and fall. Last year I also used Menzerna 2500 in the spring. I only did the 400 because I had to go that strong to get rid of the sanding marks where the paint was repaired, and then 2500 to get rid of the swirl marks left by the 400, which look like the pictures at the top of the thread, but not nearly that bad.They obviously did a quick rub out to try to make the paint look fresh but probably did it in less than an hour, then didn't follow it up with a machine polish to get rid of the swirls.
wdeerfield2745.00 |
06-11-2018, 05:59 PM | #16 |
Rep 1,487
Drives: 2108 X3 xDrive30i
This is clearly the result of some idiot improperly using a buffer that was either dirty or using a buffer on an improperly cleaned car. Take it to the best auto detailer you can find. Preferably one who works on high end cars. They will be able to make it look streak free. Good luck.
06-11-2018, 06:00 PM | #17 | |
Rep 1,487
06-11-2018, 10:43 PM | #18 | ||
Rep 174
06-12-2018, 02:31 PM | #19 | |
Rep 5
06-12-2018, 03:11 PM | #20 | |
Rep 348
