03-03-2021, 04:19 PM | #420 |
Rep 6,759
I can get one if there is any recommendation. My Samsung has the classic mic/headphone jack so it should not be a hard burden.
Any idea which mic to get?
2018 F80 Santorini 2019 Z4 3.0i 2022 X2 M35i |
03-03-2021, 04:53 PM | #421 |
Rep 2,180
03-03-2021, 06:10 PM | #422 | |
Rep 13
You misread - I said it increased damping. Higher electrical damping corresponds to a lower Qes number. |
03-03-2021, 09:21 PM | #423 | |
Rep 500
https://cross-spectrum.com/measureme...ated_umik.html |
03-03-2021, 09:45 PM | #424 | ||
Rep 16,065
If you want to learn something ask. If you want to argue I'm not going to waste my time. |
03-04-2021, 09:37 AM | #425 | |
Rep 13
You were quoted above. I guess there must be two Billfitz's, my apologies.
03-04-2021, 11:04 AM | #426 |
Rep 16,065
Good for you, newbie. I may have designed speakers for the company you work for. I've done so for better than 20 manufacturers since 1972.
03-04-2021, 11:36 AM | #427 |
Rep 13
03-04-2021, 11:49 AM | #428 | |
Rep 6,759
Meanwhile, I may try to do a comparative test with whatever I have in hand as soon as the weather warms up a bit.
03-04-2021, 02:32 PM | #429 |
Rep 16,065
That mic is pretty much the same as this:
https://www.parts-express.com/Dayton...ophone-390-808 It's also back-ordered, probably a C-19 thing. |
05-06-2021, 05:24 PM | #430 |
Rep 30
Based on advise from the thread, I upgraded the under seat woofers with 4 ohm Eathquakes and a little Kicker KEY 500 amp pushing 300 watts @ 2 ohm to them. Really woke the system up - drums and bass are much tighter and sound awesome and way less boomy. It can even dig fairly low when needed – for example, the opening notes of Gary Clark Jr's "This Land". Does it go as low as my 15" Velodyne sub in my HT? No but that's really not what I'm looking for inside a car – done too much ear damage already. Thanks to all!
07-09-2021, 04:48 PM | #431 |
Rep 216
First, this is a great thread, appreciate all the time people have put into it, learned quite a bit but I'm still very much an audio novice that can ask a stupid question at any moment. That said, I'm upgrading the sound in my 2021 X5 optioned with the base HiFi (got caught up in the recent HK delete). My initial plan was to install the Audiotec Match UP 7DSP amp myself and see how things sound but for a number of reasons I'm now thinking about installing the amp and front door speakers with Focals and possibly the under-seat woofers. Perhaps a dedicated subwoofer down the road. FWIW, I'm leaving the rear doors and center OEM speakers in place. Given my new plan is a bit more involved I've talking with a local installer who is both an Audiotec dealer and a Focal dealer so they are knowledgeable in the equipment I want. They are suggesting I use Gladen under-seat subs over leaving the OEM subs in part because they believe the OEM subs are 8 ohms and the amp is rated at 2 ohms. Are they 8 ohms? I've seen pictures of these subs that say 2 ohms on the label but I read somewhere in this thread that the label may be misleading/incorrect. Even if they are closer to 4 ohms, if I'm not going to get much if anything from upgrading the under-seat subs, I can use that money for the dedicated sub now. If I do keep the OEM woofers could they be damaged by the increased power of the Match amp? Perhaps I'm thinking too hard and should just go with the Gladens. Thoughts?
07-09-2021, 06:47 PM | #432 | |
Rep 1,425
2017 X5M - Current
2017 F31 Wagon - Current 2014 M5 ZCP - Retired 2011 135i Coupe - Retired 2007 335i Sedan - Retired |
VertigoAtHome136.00 |
07-09-2021, 10:02 PM | #433 | ||
Rep 16,065
07-10-2021, 12:39 AM | #434 | |
Rep 216
So that leaves the last decision on whether to install a dedicated subwoofer that I could mount in the wheel well (ditch the small spare). I had a powered Alpine sub (I believe it was either 8 or 10 inches) in the boot of my 911 that was unbelievable good, transformed the sound system. FWIW I listen to music by Tom Petty, Mark Knopfler, Neil Young, Joe Bonamassa, etc. I prefer a very tight base rather than a booming base you might want for rap music. Thinking about a JL Audio 12 in enclosed sub with one of their mono block amps. Any guidance here? |
07-10-2021, 08:03 AM | #435 |
Rep 16,065
I'm running an almost stock Hi-Fi system. The only changes I made was to add tweeters to the rear doors and to add real crossovers to the mids/tweeters. I listen to Classic Rock at sensible levels and this arrangement suits me just fine. It also helps that I know there's no such thing as magic speakers, no matter what the advertising may say. The Focals you mentioned, for instance, are no better than stock. If I was dissatisfied with the bass I'm getting I'd switch to Earthquakes and power them with another amp, but Classic Rock doesn't go that low, so I'm good there. I'd add a stand alone DSP to improve the EQ, but they don't exist. The DSP in the Match UP is nice, but I don't need the extra power, so it's not worth it to me.
Also, I'm not sure of what you have. You said it's the base Hi-Fi, but Base and Hi-Fi are two different systems. I can't tell where you're located either. North Georgia could be just south of South Carolina, and it could be just south of Russia. |
johnung4526.50 |
07-10-2021, 10:08 AM | #436 | |
Rep 216
Lastly, given what you've said I may be better off doing this in stages as I first thought and as eleven11 suggested. I appreciate your your input! Last edited by VertigoAtHome; 07-10-2021 at 01:26 PM.. |
07-10-2021, 02:24 PM | #437 |
Rep 16,065
The Base system, not sold in the US, has a head unit only, with no external amp. In Europe and most other locales the Hi-Fi is an optional upgrade.
The OEM has no true crossover. A crossover divides the signal, sending the midrange frequencies to the midrange driver, and the high frequencies to the tweeter. BMW, and most OEM for that matter, sends the full range of frequencies to the midrange, while filtering, barely, the midrange frequencies from the tweeters. This explains in greater detail: http://www.bcae1.com/xoorder.htm The main reason for the distortion of the tweeters at high volume is the inadequate filtering of the tweeter signal. The OEM tweeter filters are 1st order, the tweeter filters I designed, built and installed are 3rd order, along with 2nd order low pass filters for the midranges. I've measured the response and Thiele-Small specs of my OEM drivers. I haven't come across any replacement mids or tweeters that are any better. Part of that is because data isn't available for most replacements, part of that is because the OEM mids and tweeters are high quality. It would be a different story if they were of the $10 variety, but they aren't. A perceived lack of mids often translates to too much lows and highs. Turn those down and it may help. Without question the EQ of the Hi-Fi option is its weakest point, but without replacing the amp there's nothing you can do about it. |
07-11-2021, 12:33 AM | #438 | ||
Rep 216
Yep exactly, hoping the Match UP 7DSP will be an improvement. Thanks again for your help, I'll post back once I make more progress on modifying my sound system. |
07-11-2021, 08:26 AM | #439 |
Rep 16,065
The Focal does appear to have a real crossover, but I can't say how good it is. On the midrange data sheet it indicates a 6dB/octave crossover at 4kHz. The drivers do have specs and response data, and they're virtually identical to the OEM.
Here's the thing. For a given enclosure size and type there's a fairly narrow range of specs that give the best possible result. These Focals fall within that range, but so do the OEM. |
07-19-2021, 03:25 PM | #440 |
Rep 20
Awesome thread - but one easily gets to the point of not being able to see the wood for trees in this read information overload - would be nice with a kind of wrap-up of the recommendations given.
I have a base (European) system which I'm looking to upgrade, and so far had settled myself on a complete Mach-package upgrade:
But after reading the thread i started doubting whether I would be better of with a pair of the Earthquake SWS-8Xi...? Billfitz Am I fooling myself, believing that there are some synergies in choosing components from the same manufacturer for the complete system (some kind of expected balance) or should I be free to pick & match as i please? And if so - I assume your answer would be the SWS-8Xi over the Match UP W8BMW-S? (I listen mostly to electronic/dance music) |
