03-25-2021, 03:32 AM | #1 |
Rep 255
So I know the B58TU HPFP can be noisy when on Gen 1 B58s, but not sure if this ticking is excessive or maybe a different underlying problem with my B58.
You can hear the sound in the video below. During idle, ticking is fine and seems normal for the most part, but when under light acceleration this is what you hear from outside. (Oil level check was being run in the video, but it is the same sound I hear driving in a parking garage from the sound echoing off the walls but at a slower tick than in the video) https://youtube.com/shorts/e2mByijYtGs |
03-29-2021, 06:54 AM | #2 |
Rep 216
Sounds somewhat normal, Make sure it was installed correctly as it needs to be lined up perfectly otherwise, listen for a change
Sleeper340i94.50 |
03-30-2021, 05:28 PM | #4 |
Rep 255
04-03-2021, 07:10 AM | #6 |
Rep 282
hearing this noise would make me worried , its really high .
I had this pump on my N55 and currently on a b58 . never had or have such excessive ticking . maybe you have a different problem aswell
M140i DP , OPF delete , MHD stg2 93oct , xhp stg3
04-13-2021, 06:33 PM | #8 |
Rep 255
Thanks for the assurance guys. Was worried because my cars been burning through oil and recently been smelling some random smells in cabin on occasion in the morning going to work but guess that's a whole separate thing not related to this. Logs are very clean too.
04-14-2021, 01:21 AM | #9 | |
Rep 532
Sleeper340i94.50 |
04-14-2021, 08:09 AM | #10 |
Rep 282
ill try to record a sound and post it here .
cars been sitting cold for a few days now . is it the same for you between a cold and a hot engine ?
04-14-2021, 11:50 AM | #11 | |
Rep 113
I have the B58 TU pump and the VTT turbo (not the higher powered GC). I see u have dorch stage 1, I'd love to grab dorch stage 2, i can't find any available anywhere currently. Any ideas to get my hands on 1. I'd sell my supra pump on here once I can find the dorch to replace it. |
04-14-2021, 02:59 PM | #12 |
Rep 282
cold start noise warm engine idling . quite a difference compared to the topic starters video
04-14-2021, 08:02 PM | #13 | |
Rep 255
To your question above, the sound is definitely louder on colder starts and tends to go away for the most part while driving. But the thing is I'm on very low partial throttle when it makes this sound like say if you were driving in a neighborhood or parking garage. The sound from my vid was recorded during an oil level check and during cold startup it's just a very loud click which gets better while driving. Are you running stock pump? |
04-14-2021, 08:04 PM | #14 | ||
Rep 255
04-15-2021, 02:44 PM | #16 |
Rep 255
Must be blind wonder what causes the difference with the pump sound then as looks like other people have same sound as mine.
Have u tried listening while cruising say 20mph or lightly holding a rev around 1500? Wonder if u would get the same sound as my video or not. It is kinda hard to hear unless in an enclosed ish space. |
09-23-2021, 12:52 PM | #18 | ||
Rep 255
But I'm actually replacing my engine. My pistons turned out to be going bad as they were leaking oil into cylinder 3 and I also had scoring on my cylinder walls as well. Wonder if the pistons made the sound. Unfortunately I'm not sure what the exact culprit is as there could have been other underlying problems as well with the engine. |
09-23-2021, 12:55 PM | #19 | |||
Rep 19
09-23-2021, 04:53 PM | #20 | ||||||||
Rep 255
09-23-2021, 06:51 PM | #21 | |||||||||
Rep 19
09-28-2021, 08:34 AM | #22 |
Rep 947
Mine sounds like this too. Get your head close to the center of the valve cover, there should be a small black device that ticks constantly (Its got lines going to and from it) it vents fuel pressure or something like that. That contributes to a lot of my noise.
