BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Heated Steering Wheel Function Retrofit discussion and sharing
      11-18-2020, 09:25 AM   #243
DJSF3014
Drives: 2020 m340i
Originally Posted by 320if30 View Post
Originally Posted by Daggers View Post
Really sorry to drag this up from the past, but I’m retrofitting the heated wheel and have what I thought was everything. However, I have nowhere to plug in my little single black wire from the control module.
Any ideas?
I’ve reused my wheel loom so I’m wondering if it’s not present on that (item 5 above needs swapping maybe).
I’ve added the button, added the wheel, added the module, coded and get “steering wheel heating activated/deactivated” on dash as expected - just no heat!
Edit to add. 100% it is that I don’t have the correct loom. For anyone else stumbling on this thread in years to come, f you’re interested Part 32307848337 is what I’ve ordered - steering wheel loom for cars with lane departure/heated wheel. 👍
What if you do not have lane departure warning on car. I added heated msport wheel (car was standard with msport), button and module. coded via bimmercode and light comes on button but no heat. The module does have another single wire coming off it with no place to go. I assume this would be for vibrator? please help.
Yes that is where it would go. Did you ensure you bought a heated steering wheel? That's the only thing that would make sense I do believe that just the heating element would work without the vibrations assist.
      11-18-2020, 09:46 AM   #244
320if30
E36M3 2/5 garage queen X3 3.0si
Drives: 2013 328I M SPort
It is for sure a heated wheel. Should I shut off the vibrate in Bimmercode?
I feel like its in my head that the wheel gets somewhat warm, but I just don't know. I feel my brothers F80 wheel and it is very warm. You would think since the light is working that it should heat the wheel either way.
any help would be much appreciated.
this is what i coded
FEM_BODY
3140 PFLinSteeringWheel
CODDT_BYTE_00_SZL_LIN = LHZ_aktiv
LIN_VARIANTE_LRE = lre_tlc_lhz
LIN_VARIANTE_SZL = szl_4Band
LRE_Verbaut = aktiv
      11-18-2020, 09:52 AM   #245
DJSF3014
Drives: 2020 m340i
FEM_BODY
LRE_Verbaut = aktiv
I don't know about the coding but I would code out vibration just to cancel that as a possibility also the heating element controller could have gone bad multiple threads about that.
      11-18-2020, 09:54 AM   #246
320if30
Controller, as in the Module? black box
      11-18-2020, 09:55 AM   #247
DJSF3014
Drives: 2020 m340i
Yes that entire thing has been known to fail and you gotta get a new one.
      11-18-2020, 09:58 AM   #248
320if30
Crap. well that sucks. I bought off ebay.
thank you for your help
      11-18-2020, 11:30 AM   #249
DJSF3014
Drives: 2020 m340i
Sent you a pm.
      11-20-2020, 12:46 PM   #250
320if30
Originally Posted by doughboy View Post
I bought a 4 way plug then I can plug the heater controller into that via it's black 4 way socket that would normally go into A83*4B plug.
Then via new leads (made from pin and socket tails soldered back to back) from the 4 way to the to the yellow 6 way airbag connector pins 1&3.
Will solder later and heatshrink it up. Just need some time to fit it now...
Thanks
what does the single black wire connect to? Can someone please confirm this?
      11-20-2020, 01:13 PM   #251
320if30
figured it out. it needs to be jumped to the blue wire on RH side. Either direct into SZL or at controls.
BIG THANKS TO HAWKO!!!
      01-24-2021, 07:58 AM   #252
GreyF31
Drives: BMW F31 2013
How to connect to LIN
Could someone help me with connecting the Steering Wheel Electronics Module to the LIN?
I found one with 4 connectors on the wiring harness, and one that connects to the module itself. Below pictures from the wiring harness and the connector to the controls on my steering wheel.
Doughboy wrote about this in post 140, but I didn’t understand.
For Power I used the solution of david51.
      12-29-2021, 06:54 AM   #253
SZYMQ89
Drives: F25
Originally Posted by gotomoto View Post
So i tried to do this. connected the cables as instructed. got a new heating button and not working. ISTA gives the error below. I tried my friends steering column switch. still not working. anybody has an idea?
Was this error resolved?
      01-16-2022, 09:25 PM   #254
thatalpineguy
Drives: 2017 340i M-Sport
I have been having issues with no heat. Can you elaborate on this?? What is the function of that wire?
      01-17-2022, 02:34 AM   #255
mrsofa
Drives: bmw f30
Hello, I have a question, on my 2017 f30 I retrofitted a heated m sport steering wheel, when I try to plug in the Switch for turning on the heating into A83*5B on the SZL it has no pins in only the hole is present...
The car does not have LDW or lane asist or radar cruise control. New gear change pedals work tho.
      01-17-2022, 12:27 PM   #256
thatalpineguy
You have to find a new SZL that supports the heated steering wheel.
      01-24-2022, 10:28 AM   #257
hj45265
Drives: BMW F22 M235i
Heated Steering Wheel Button
Hi, my F22 has lane departure warning and I plan to retrofit the heated steering wheel function.
I wanted to install a generic button (OEM is too expensive imo). As I understand the original button has 3 pins: LED Power, button power and ground.
Does anyone know if I need a actual button (just a electrical signal when pressed) or a "switch" button?
      01-24-2022, 10:42 AM   #258
doughboy
doughboy's Avatar
1543
Drives: 2018 M2 Comp 6MT
It's just a momentary make push button contact, i.e. it is closed when you press the button then it opens again.
      01-26-2022, 02:51 AM   #259
Michalt
Drives: BMW F31
Originally Posted by david51 View Post
did you encode like that ?
Added to VO 248
right click and code
FEMBODY
ICM
KOMBI
I did everything according to this post and unfortunately the heating doesn't work. The problem is that I can't buy SZL anywhere for F31.
My SZL is not prepared for heated steering wheels. According to the instructions, the power pins were blown, I used the pins in the airbag plug, the power supply of the module is, however, the coding is done, and the heating does not work. Maybe there is another solution?
The entire heated steering wheel assembly is operational. Because it currently works for me on SZL with F33, but I have no rear wiper and FLA function.
      01-26-2022, 07:24 AM   #260
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Originally Posted by blackdevil View Post
Hi, thinking about doing this retrofit and have a question.
The control unit has 2 connections with white surrounds, the 2 pin goes to the lane departure and the 4 pin goes to the heater pad, the steering I've seen only has 2 pins coming out of the heater pad, is this the right steering wheel ? If so, what are the 2 other pins from the control unit for ?
Thanks in advance.
you can buy a szl model F30 it is the same as F31
      01-26-2022, 08:12 AM   #261
Michalt
Drives: BMW F31
David, F30 doesn't have a rear wiper.
      01-29-2022, 09:35 AM   #262
Ally18
Drives: F30
Hi could anyone say if 9253751 szl would support heated steering wheel or is it a new one needed ?
Think I've found answer and it's no
      01-29-2022, 09:46 PM   #263
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Yes you are right
here are the compatible models
https://bimmercat.com/bmw/fr/parts/i...1146/appliance
you have to check and tick according to the options you have to have the right reference
https://bimmercat.com/bmw/fr/search/...0d/ECE/61_5559
      01-30-2022, 02:21 AM   #264
Michalt
Drives: BMW F31
Yes you are right
Thanks, I know it all.
Nevertheless to find SZL to F31 / F20 / F25 it is a problem
f30, heated, heating, steering, wheel
