05-22-2024, 12:14 PM | #1 |
Rep 2
VLAND white black tail lights Problem!
I bought Vland LED Tail Lights a couple days ago but when I installed,I encountered an error. left turn signal flashes and other side is normal. Do you know how can I fix that. I'm attaching the video
Video: https://streamable.com/jw5s6g |
05-22-2024, 02:03 PM | #2 |
Rep 548
Are the other lights in the same light assembly work normally?
Remove the light, check the plug. Make sure all pins in the plug are sat correctly. RE-connect. If problem stays, return the light for replacement.
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12 2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0 2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1 |
05-23-2024, 10:28 AM | #3 |
Rep 2
Other lights are normal, I tried all these but it’s still same
