03-21-2020, 04:45 AM | #46 |
Rep 296
03-25-2020, 10:26 PM | #47 |
Rep 585
100 - 150 in 2.85 sec
100 - 200 in 7.12 sec (99.2 km/h to 199.3 km/hr) 4048 RPM in 4th = 99.2 km/h and 6212 RPM in 5th = 199.3 km/h M140i stock hardware, MHD Stage 2 95_102 with E30 fuel blend, xHP Stage 3, plus DIY MAP spoofer (like JB+) https://datazap.me/u/ozbmr/ozbmr-mhd...o=0&mark=40-81
Tesla Model 3 Performance 0 - 60mph 3.1s
M140i LCI Mineral Grey Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s Quarter mile 10.93@127mph |
janea120728.50 |
03-25-2020, 11:39 PM | #49 |
Rep 585
May depend on your tune, for me Sport+, Manual starting in 4th gear, changing into 5th at about 6500 - 6600 RPM
03-29-2020, 12:09 PM | #50 | |
Rep 106
EDIT ! I got 8,24 in my latest verison from Pureboost. I have recived 8 files and we are done now.
M140 Sunset Orange 2018. M719 Jet Black. Maxton sideskirts and spoiler, Ksb front splitter, RK Tuning diffuser, TPI spacers, MHD Stage 2, Xhp stage 3 , Wagner 300 cell cat, MPE silencer , Quaife LSD.
Supra pump and OTS E30, Spool ethanol analyzer (E35) https://theone1973.imgbb.com/ |
03-30-2020, 02:48 PM | #51 |
Rep 133
is faster than from 3rd gear? remain in manual mode or go in D?
03-30-2020, 02:56 PM | #52 |
Rep 133
b58
03-30-2020, 04:03 PM | #54 | |
Rep 585
Remain in manual mode changing in 4th at 6500 - 6600 RPM is fastest
janea120728.50 |
03-31-2020, 02:18 AM | #55 |
Rep 106
M140-2018 2WD
MHD Stage 2 Xhp stage 3 Wagner 300 cells BCS mid pipe + MPE Costume tune by PureBoost ( 98RON/93Octane only ) I pull from 4th to 5th. Same car with same setup and 102 Aral fule is low 7 Octane is everything on this engines...I have got 8 different versions from Pureboost.
OzBMR574.50 |
04-06-2020, 11:02 AM | #56 |
Rep 458
Finally got to do some additional 0-60mph (0-100kmh) testing and hit a best of 3.43 (3.6). My previous best was 3.7 with 1500DA. Also been playing around with the xHP custom launch control and it definitely has helped. I'm thinking at -1500DA this thing has a 3.2-3.1 in it, but I wouldn't know since the HPFP wants to crash.
2019 M240i M Performance Edition / xDrive / ZF8 / BM3 Stg 2+ E30 / xHP Stg 3 / Dorch Stg 2 HPFP / Evolution Racewerks Catless Downpipe / MPPSK Exhaust / FTP Drop in Filter / FTP Intake Pipe / FTP Chargepipe / NGK 94201 Spark Plugs .022 / Michelin PS4S - 225/35/19 + 245/30/19
OzBMR574.50 |
04-06-2020, 01:28 PM | #57 | |
Rep 686
Drives: Your mom crazy
Garage List 2020 BMW M340i CURRENT [10.00]
2003 BMW 330i RIP [10.00] 2011 BMW 335i SOLD [10.00] 2016 BMW 340i SOLD [10.00] 2020 BMW X3M RIP [10.00] |
Once I get this turbo install dialed in I might be interested in a little bit more detail on how you worked through the launch control adjustment.
2020 M340i
DAW UF-X; Wagner intake manifold/port injection; ID1050xds; Precision Raceworks St2.5 LPFP ECUTEK; Wedge Performance E70 tune KW V2; BC Forged EH173 |
04-06-2020, 01:41 PM | #58 |
Rep 458
Still on the stock Pirelli run flats with close to 20k on them. Definitely shoot me a pm when you are ready about xHP custom launch control.
Supr3me555.00 |
04-06-2020, 04:50 PM | #59 | |
Rep 458
04-06-2020, 08:09 PM | #60 | |
Rep 1,361
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
04-06-2020, 09:43 PM | #61 |
Rep 458
Hey man thanks! I havent gotten any new 1/4 or 100-200. My previous best in 1500DA was 11.8 at 117mph and 9.66 100-200kmh but my car has significant throttle closure issues. I will definitely try to get both times again soon.
04-06-2020, 09:47 PM | #62 |
Rep 458
I just broke my record again. It was nice to finally try it in negative DA even if it was by very little.
OzBMR574.50 |
04-06-2020, 11:38 PM | #63 | |
Rep 585
I'm using it because I had already made one up myself prior to the general availability of flash tunes and it effectively enables me to adjust the torque/load/boost targets on the OTS tunes. e.g. the MHD Stage 1 E30 map has a base torque/load target that typically generates 16 - 17 PSI. Having a JB+ type device connected to the charge pipe sensor allows incremental increases in boost e.g. I'm currently running 18 - 19 PSI on that tune and ran another 100 - 200 in 7.3 seconds this morning. JB+ and similar do mess with the reported boost, load and torque data coming via the MHD logging software so I'm rescaling boost based on MAP volts data in my logs. The 100 - 200 times and Virtual Dyno results prove the benefit. Using it on the car when it was stock I got a 12.49@114MPH with a 2.07 60ft, could have been an 11.9 with the Hoosiers and a 1.77 60ft My DIY version has a resistor and a potentiometer (creates an adjustable resistor) in a little black box that tucks under the engine cover. I sourced the male and female connector plugs, M & F contacts and wire seals from companies in Germany and USA. All up about $20 - $30 in parts and it was an interesting side project.
04-07-2020, 12:41 AM | #64 |
Rep 49
Hi
It's been time for some stock times so many don't feel theirs is slow, 340i rwd , 8 speed - bone stock - dragy. 0-100 = 5,09 100-200 = 13.02 100-200 = 12.55 return 1/4 mile = 12.97 |
04-07-2020, 03:50 PM | #65 | |
Rep 458
04-07-2020, 07:23 PM | #66 | |
Rep 585
If the BM3 E30 maps are like the 93 maps with high load/boost overshoot around 3000 RPM then you may already be at the limit of the HPFP and adding more boost will just result in a HPFP crash. Do you have any current BM3 Stage 2 E30 OTS logs you can share? PM me if you'd prefer.
